Question about Cfm Daikin R410a Split System Air Conditioner
IN MODEL DAIKIN II INVERTER VRV MODEL RXYQ14MAY1 SL NOAOOO273 WHEN SWITCHED ON AC IS WORKING ON SINGLE COMPRESSOR IT IS NOT TAKING LOAD ON OTHER 2 COMPRESSORS I AM NOT GETTING SUPPLY TO CONTRACTORS FR
SOME PEOPLE ARE SUGGESTING THAT IT IS PROBLEM WITH PCB I WANT THE EXACT SOLUTION
4 Suggested Answers
farfield
  • 462 Answers
SOURCE: will you tell me the electrical diagram of 12
Remove a door Usually the wire diag is on a cover. I do not under stand why you have so many model numbers. Unless its a generic label used on all the models. and in this case the diagram will most likely be for all them too with foot notes showing the differences. If this helps PLEASE GRADE ME ACCORDINGLY. IF not I need more information.
Posted on Mar 02, 2009
hvac1960
  • 2133 Answers
SOURCE: I have a Daikin Ducted
E5 Outdoor activation of compressor over heatprotection or motor lock.
Dear friend! Replacing spares for defective will not solve problem. But, you must know why it happened?
In your unit,Condenser unit was completely dust blocked. First clean it. And also replace running capacitor. If recently replaced, ignore it. Check motor for bearings. It's mechanism locked due to bearing worn out or weaken capacitor. Ask repairman to check with amps meter for fan and also with compressor. And also loose wiring if any. Compare with unit specified amps.Hope problem would solve now.
Posted on Jan 07, 2011
ar1965
SOURCE: VRV 3 Daikin 2 pipe system. does any one know
no communication between indoor and outdoor units
Posted on Aug 12, 2012
Daiking inverter ac work slow after one year
Low refrigerant issue need to refill refrigerant
Jul 14, 2016 | Inverter Heating & Cooling
U3 problem for vrv daikin
U3 Is a failure to carry out check operation, transmission error
This is a self diagnosis the unit does before starting to ensure both PC boards are communicating with each other. Check wiring is correct on the units, usually means one PC board has failed
Oct 28, 2013 | Daikin BRC2A71 - Simplified Individual...
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
May 04, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Red light blinking and no cold air provide
Indoor fan motor is not running. Check and replace it.
Aug 17, 2012 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Daikin VRV J2
This is a fault with one of the standard compressor’s current sensors.
It occurs when the units PCB asks the compressor to run but then doesn’t recognise that the compressor is drawing any current. This can be due to a fault with the compressor contactor not coming in or a fault with either the Main PCB not giving an output to the contactor or not receiving the signal from the current sensor, or it could be a fault with the current sensor itself.
Mar 18, 2012 | Heating & Cooling
Daikin error code H6 Outdoor Compressor motor position detection sensor error
sir
daikin inverter air conditioner we are replace the indoor pcb then next it gone out door pcb,next we are replaced outdoor pcb also then compressor not working oftre last we are replaced compressor then it will be giving H6 ERROR CODE please give me suggestion
Feb 16, 2011 | Heating & Cooling
Will you tell me the electrical diagram of 12 floor standing vrv daikin?the model of indoor units are fxlg63mave and the outdoor units are rxyq12p7ylk rxyq10p7ylk rxyq8p7ylk
Mar 02, 2009 | Cfm Daikin R410a Split System Air...
Cfm Daikin R410a Split System Air Conditioner Logo
32 people viewed this question
Top Cfm Heating & Cooling Experts
Dan Webster
Dan Webster
David Payne
David Payne
Donni Steen
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
