Question about Berkel Spiral Dough Hook for FMS20 Mixer 12 Quart Bowls
I am in need of a Berkel BX20-T dough hook. Where can I find one? THanks
Need dough hook for BX20T Berkel mixer. Where can I find one
    New Friend:
I need one too. Did you ever find one?
Posted on Jun 03, 2014
I cant locate a manual. I do not know how to remove the bowl.The Berkel BX20t Mixer
Hello Angela, can you please construct a new query and post again. please include details of the make and model of the mixer, that way we can search
Jul 18, 2015 | Food Mixers
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
Dough hook stuck immediately after use
I just got my dough hook unstuck! The problem was the bolt at the top of the dough hook. This bolt is used to adjust the height of the dough hook. This bolt came loose while mixing and went up towards the mixer. The force of the spinning actually tightened this bolt against the mixer so when I tried to release the dough hook by lifting and turning, it wouldn't lift. The bolt was in the way! The solution is to loosen this bolt. You'll need a thin wrench that's about 15 mm. You can test loosening this bolt on the other attachments since they loosen in the same manner. You'll have to bend the white shield down slightly to get the wrench in there. It's a tight squeeze even with a thin wrench. Hold on to the lower end of the dough hook and turn the wrench counterclockwise when looking down at it. Once you loosen the bolt, you'll be able to turn the lower portion of the dough hook to lower it. Then you can lower the bolt further. Once you have them low enough, you can remove the dough hook like normal - lift and turn. Sure beats boxing it up, shipping it for repair and paying for shipping both ways!
May 03, 2010 | Cuisinart SM-55 Stand Mixer
What is the correct dough hook to get for my 'OLD' A200 Hobart?
Check with your local Hobart office.
www.hobartservice.com Click on "Locate an Office" and enter your Zip.
Jan 20, 2010 | Hobart A200 Stand Mixer
Need to know the part number for a dough hook for a hobart a200c stand mixer. What number would be stamped on the hook?
A 20 qt "E" dough arm is S-23467. A 12 qt is S-62886.
A 20 qt "S" sweet dough beater is R-8022.
Jan 05, 2010 | Hobart A200 Stand Mixer
The dough hook is stuck in the beater shaft of kitchenaid mixer
It sounds like it got overloaded when you last mixed dough. It will only come off the way it went on. If it has been bent on, it may need a bit of gentle encouragement.
Jun 15, 2009 | KitchenAid KSM50PR Professional Series...
I need replacement beaters for a dough hook stand mixer
Information from manufacturer stating replacement parts have been exhausted.
Jan 30, 2009 | Food Mixers
Need to Raise the stop height of the bowl on the H600
I should have know this was a scam to sell something.
Thanks, but no thanks.....
Dec 09, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart a200 mixer won't mix
The bowl holds 20 quarts--are you overloading the mix?This mixer is not made for medium/heavy pizza dough.Depending on the pounds of dough,water and other ingredients will affect the mixer in some way.
Nov 09, 2008 | Hobart A200 Stand Mixer
Berkel Spiral Dough Hook for FMS20 Mixer 12 Quart Bowls Logo
170 people viewed this question
Top Berkel Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Berkel Food Mixer Expert? Answer questions, earn points and help others
