Question about Euro-Pro Stitch Art 8660 Mechanical Sewing Machine
My back stitch wont reverse
There is a thing to flip up and down but doesn't do anything
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
Has the machine been unused for a 'long' period of time? Some of the Janome machines did a similar thing - the oil becomes 'sticky'on the mechanism attached to the reverse lever. Can often be fixed by removing the free arm cover and spraying a little Innox (using the supplied straw) in the area where the lever operates. Work it back and forth .... it may come good. It could need tobe dismantled if it wont free up however. Good luck! :)
Posted on Apr 29, 2014
Brother AE2500 reverse sewing lever is too stiff to move , how does this work please, bacause in the CD provided with this sewing machine , this lever (plastic) for doing reverse is being moved down t
Try turning the flywheel and operate the reverse lever at the same time. Some machines need to be at a certain point in the stitch cycle for the reverse lever to be used.
Dec 26, 2014 | Brother Sewing Machines
I have a Janome Newhome 672. Cleaned and oiled it, works great. But, the decorative stitches will not form correctly. The reverse is not engaging. How can I fix this. Also, the button hole knob h
In most cases Laurie, with decorative stitches selected some machines can't sew in reverse. Your stitch length is too long or too short to make the decorative stitches sew correctly. So many things could be wrong. I'd need more info to get you going again.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Oct 22, 2014 | Janome Sewing Machines
My sewing machine will only sew in reverse
The stitch length lever on some machines will back stitch when the lever is in the uppermost position. Bring the lever down to an appropriate stitch length and your machine should stitch forward.
Oct 11, 2014 | Singer 3116 Simple
Husqvarna prisma 980
since the sewing machine was given to you, it might be a good idea to have the sewing machine serviced to see if there is a problem with the reverse and stitch setting.
Aug 14, 2013 | Sewing Machines
Thread wont loop, it doesn't sew?
It loops, it's just that your shuttle isn't catching the loop. The loop is formed on the upstroke of the needle on the back or "scarfed" side of the needle. If the shuttle point doesn't catch that loop, no stitch.
First make sure you have a fresh needle. If still no stitch... take it in for service. (clean, lube and time)
Oct 03, 2012 | Brother SE-270D Computerized Sewing...
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
I have an sx 2122 new home machine. My reverse stitch is not working properly. Everything is running in reverse. I am not holding the reverse stitch down and it still goes in reverse. I bought my...
Hello
I'm thinking it's that you have to hold it down the whole time you want to stitch in reverse,if not,
The most common cause of machine misbehavior is - believe it or not - the needle. So swap it out. I don't care if it is brand new --- sometimes they are bad from the manufacturer. It is such a simple fix and one that you need to learn right now -- when in doubt -- change it out!
Be sure to install the needle the right way. There is a flat side that needs to hit the adjusting screw so that it doesn't wiggle around when sewing.
Next - be sure that you have threaded the machine correctly - go back and look at the owner's manual and re-thread the machine -- leaving about a 2-3" tail after going through the eye of the needle from front to back.
Now - for the bobbin -- is this the bobbin that came with the machine? If you purchased new ones - are they the right size - it doesn't go well with the wrong size bobbin. OK - now, did you wind it on the machine or by hand? If you did it by hand -- is it evenly, tightly wound. Are you using standard thread or are you trying a specialty thread?
Did you put it into the bobbin case / holder going the right direction -- machines can get pretty finicky - so make sure that it is unwinding the correct direction. It must turn counterclockwise. If the bobbin is in backwards or upside down - easy to do on some machines, and impossible on newer models, it can cause a great deal of trouble.
Also, make sure that you have not inadvertently bumped the tension adjuster for the bobbin. This can be a stick like adjustment at the top of the machine - may be an adjustment on an LCD screen - it varies depending on the model.
Again leave a 2 - 3" tail and put it in place correctly.
Make sure that the presser foot is up - and that the feed dogs are engaged.
Now - using the hand wheel on the right side of the machine - and holding on to the upper thread tightly - move the needle up and down once to bring up the bobbin thread through the throat plate of the machine. The bobbin thread will be caught up and a loop will be visible between the presser foot and the base plate. Gently pull both threads up and to the back of the machine - out of the way of your sewing.
When you begin working on a piece of material - hold both threads firmly to the back and take the first few stitches slowly to make sure that they are not going back down the throat of the machine. Be sure NOT to try to start at the very edge -- begin about a 1/8 to 1/4" in from the edge. If you are doing quilt work and only using a 1/4" seam - then back up after starting and come forward again. If you are using a traditional 5/8" seam allowance - no worries
Aug 02, 2011 | New Home Sewing Machines
Pfaff 1222's 3 stretch stitches sew wrong and backwards only.
It sounds like the feed mechanism needs oil.
Feb 24, 2010 | Sewing Machines
My model 210 is stuck in reverse. Can you help?
The only thing you can do to possible free the mechanism is to turn the lower dial back and forth a bit, from the position where it is in permanent reverse to the numbered area on the dial. Make sure the selector is not on the buttonhole position. That machine doesn't really have a history of that issue but anything is possible, especially if it has sat for awhile and not been used. If moisture was present where it was stored, it's possible the feed linkage is slightly rusted and simply stuck.
Oct 07, 2009 | Husqvarna Viking 1
Pfaff Hobby 1142 Reverse stitch lever twisted doesn't work
Take it back to the Dealer.( He probably has a guarantee on the work he did). Let him show you how it works. If he won't do this then it is definitely time to find a more reputable dealer. If you paid for a repair it should have been repaired.
sewman7
Jul 01, 2008 | PfaFF Hobby 4260
Euro-Pro Stitch Art 8660 Mechanical Sewing Machine Logo
78 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
