Question about Dishwashers
Nobel stainless dishwasher. water comes in but keeps pumping and does not go into cycle. for example, if we put the washer on towas dishes and leave it over night, in the morning it will still be pumping water into the machine.obviously it does not over fill because i am assuming it goes out the overflow. please help
  • 1 more comment
  • kozanss Jun 18, 2009
    ran machine through cycles with no problems now. the only thing is that it is not heating up the water at all but it is still running the cycles. i had thought that if the water does not heat up then it wont continue to wash.but as i said it is now running cycles but no hot water and dishes not very clean
    how do i know if it is the thermostat or the element??
  • kozanss Jun 24, 2009
    thanks, great help. i still havent replaced the paet suggested but i beleive it is right.
  • 583 Answers
Lookout the following things:
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
also check out things below:
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
keep me updated .thanks please do not forget to rate this solution.
Posted on Jun 17, 2009
  • livetech Jun 18, 2009
    its the element to be blamed.
    thermostat goes bad in 1 of 100 cases and have bit different symptoms.
    plse do rate this solution positively
I HAVE A BOSCH DISH WASHER SGS43A32GB/01 WHICH APEARS TO FLOOD NEAR THE END OF CYCLE
check base for leaks or holes. This is a very thin sheet of stainless steel that gets easily punched if some heave shart or pointed cutlery is falling onto it. also check proper operation of float switch underneath it.
Feb 01, 2012 | Dishwashers
2 year old stainless steel dishwasher making weird sounds
are u hearing any metal grinding sounds or is it making a noise like something is breaking theres a pump located down the bottom of the unit and depending on how you wash your dishes for example if you wash them before you insert them into the dishwasher or if you put them in with food on them would consitute your next course of action if you do insert them with food on them then you would need to check the pump and the chopper area you might want to call a technician if the problem persists. hope this helps try running it through the full cycle if tere is something wrong you will get an error code
Jul 13, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
Need an instuction manual for nobel dishwasher wqp12 efmsa
Possibly an element or thermostat problem.The dishwasher rely's on the thermostat to tell it wether it can progress through the cycle or not.The washer will stay washing in the one spot until desired temperature is reached then the washer will progress on.
Oct 07, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
No water spraying in washer, and no error code
Either:
1. not enough water gets into the dishwasher. open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
Good luck,
Vlad
First Choice Appliance
Jun 10, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dish washer wont drain
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Feb 02, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Food on dishes
Dish washers are not good at removing food debris.  They filter the water somewhat but in the main, they recirculate whatever was on the plates when you put them in plus the detergent.  The rinse takes all grease and solubles away.  Scrape your dishes of as much as you can before putting them in.  Use a good detergent in the amount specified.
Nov 26, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Leaving white residue on dishes salt ok any ideas please
A white residue could be some type of water hardness or residual detergent. Wash dishes by hand and dry, does white residue remain? If yes, there is too much detergent in machine. If no, water problem. Consult with a local water expert
Aug 19, 2008 | GE Adora GHDA656LSS Stainless Steel...
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
HElp Dishes not coming clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
102 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
