Question about Electrolux Dryers
EIMED60LT Dryer won't start
Power is connected and electronic controls are functional, drum turns freely by hand, just prior to the problem a shoe got wedged inside the drum and stopped rotation - this was corrected and restart was ok. Shoe got stuck again and the dryer paused itself again - restart attempt was unsuccessful - no the humming sound and no rotation of the drum when the start is pressed
  • 1462 Answers
SOURCE: The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
Posted on May 23, 2007
  • 1462 Answers
SOURCE: Rythmic thumping sound
probably the rear bearing or the drum shaft
Posted on Nov 16, 2008
dragonsthatk
  • 547 Answers
SOURCE: Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Posted on Feb 20, 2009
  • 66 Answers
SOURCE: press the start button on dryer, it hums but wont
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Posted on Dec 27, 2009
heatman101
  • 43501 Answers
SOURCE: Dryer making a loud clunking noise each rotation,
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Apr 01, 2010
What is an error code e-68 on a galaxy series dryer mean
E68 error code is a stuck button error code. You can try to wiggle each button on the control panel to make sure they are all functioning freely. If so, then unplug the dryer and leave it unplugged a couple minutes then plug the dryer back in to clear the electronic panel's error code. If the panel still shoes E68, then you'll need to replace the panel. Part#134557201
Hope this helps!!
Jun 13, 2016 | Dryers
Dryer stopping mid cycle
You have to test several parts, common causes are defective termic sensor, or fault program control.
Post model number for more details
Jun 01, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Dryer will not start
check door switch. listen for timer clicking .also belt could be off drum
Apr 12, 2014 | Electrolux 8 cu ft Stackable Electric...
Maytag ensignia
follow this steps and fix it. God bless you
Drive Motor
The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer stops the motor might be defective. If the dryer stops and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. Also try rotating the drum by hand with the belt off, it should rotate freely. If the drum doesn't turn freely, determine what is causing it to bind. The dryer motor can't be tested easily. If the drum turns freely and the blower wheel is clear, and yet the dryer still keeps stopping mid-cycle the motor may be defective. it will need to be replaced. It is not serviceable.
Enter your model number to see parts for your dryer.
Help me find my model number
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
Drum Roller
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If they are worn out or start binding the motor can get overloaded and the dryer stops. If the dryer stops mid-cycle, check to be sure the drum turns freely with the belt removed. If not, check the rollers. Do not lubricate the rollers or roller shaft, lubrication will attract lint and cause the roller bearings to wear out faster. If the rollers don't turn freely, replace them. The roller shaft can often be reused, unless it has worn down. Clean the shaft thoroughly before installing the new rollers.
Drum Support Roller & Axle
This dryer has drum support rollers.There will always be two supporting the rear of the drum and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely. If not, check the rollers and rollers shafts. If they are worn or do not turn freely they will need to be replaced.
Drum Slide, Glide, or Pad
The front of the dryer drum is supported by small pieces of plastic-like material. As the drum rotates, it slides on these plastic pieces. If the dryer stops mid-cycle, it may be that one or more of these plastic slides or glides has worn out. When they wear out the drum can start binding and put strain on the motor. The motor then shuts down and the dryer stops. Check the glides for wear and replace as needed.
Drum Bearing
The drum bearing supports the rear of the dryer drum. Over time this bearing will wear out and may cause several different problems. If the dryer stops during the cycle it may be that this drum bearing has worn out and is putting too much strain on the motor. If the belt is removed and the drum spins freely, the drum bearing is probably not worn out. If the drum bearing is worn out, there may be some grinding or squealing, and the drum will be hard to turn.
Drum Support Bearing
Dryness Control Board
The dryness control board shuts off the dryer when the clothes have reached the level of dryness selected by the user. If the dryer stops too early, the dryness control board might be defective. This is not very common and other possibilities should be checked first.
Jul 21, 2013 | Maytag Dryers
Error code 52, Dryer won't start
You have a motor error. Remove any load from dryer and check if drum turns freely by hand. Check L1 power supply voltage, motorwindings, and motor thermal protector (if motor thermal protector has tripped,it may take up to 30 minutes to reset). If error persist, replace the motor with this new one.
Oct 15, 2012 | Dryers
Electrolux E52 error code Dryer
Hello drew_wedemey -Typically error code E52 indicates that the unit has a faulty motor. If the drum does not turn freely by hand, then I highly suggest contacting a professional to accurately diagnose the following; motor windings, L1 power supply voltage and the motor thermal protector.
Sep 30, 2012 | Electrolux Dryers
Put shoes in dryer and it stopped. When I turn it
Could be broken belt does drum turn freely by hand if so the belt gone
Mar 31, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryer will not start, but does have power. The light and heating element are working, but the drum and blower are not functioning? Door switch is working properly, and there were not any previous...
The components to check include the motor's start switch & capacitor, if so equipped, the push to start switch, & all associated wiring. Check to see if motor & drum turn freely. Does the motor hum when starting is attempted?
Jul 15, 2007 | Roper RES7646KQ Electric Dryer
Dryers Logo
43 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
