Question about Singer 3HV100 Portable Upright 3 In 1 Vacuum
I have not used my sweeper for a long time and I have forgot how to install the vacuum bag. Can you help me?
I have the singer 3HV1000 sweeper and I have cannot figure out how to put the dust bag on the sweeper. Need you to tell me how?
How do I disassemble a suction blower connector from the hose on a sweeper?
Here is a walk through on installing the attachment hose, just reverse to remove the hose:
Vacuuming Bare Floor with Kirby vacuum
800-775-6586
GoodVac com
Oct 04, 2014 | Kirby G5 Bagged Upright Vacuum
How to install inside on/off switch on hoover windtunnel bagged sweeper
This switch is subject to a recall. Find a local Hoover service center and have it replaced. Completely Free.(YAY!)
Good Luck!
Aug 21, 2012 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuum has no suction
I would say that the best way to improve suction with any vacuum is to clean all the filters, If it is a Bagged sweeper check for holes and possible replace the bag. Hope this helps some!
Good Luck and Best Wishes!
May 05, 2011 | Kenmore Vacuums
I have a fantom fm709k vacuum and apparently they do not make the bags for them anymore....what bag can be used in place of it...
Take the old bag and take it to a sweeper shop they can match it up but beware of them trying to sell you something you don't need.They will try and sell you a new sweeper cause the bags are no longer available ,let them know up front you just want to match it up and not interested in the new stuff.
Apr 05, 2011 | Vacuums
My vacuum stop suction
Usually, the tube leading from the sweeper head up into the bag gets plugged. Remove the bag and the bottom cover plate of the sweeper to check the air passage at the rear of the sweeper. Use a hooked wire to dig out any clogs and check the air tube coming into the bag for any clogs on that end. Take the vacuum outside without the bag and turn it on to make sure the air is moving freely (it's likely to be quite dusty for a moment or two). Don't allow the bag to fill completely to help prevent re-occurrence. Hope this helps!
Nov 21, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
I need to replace the belt I bought a new belt and I can't get the belt back on
On this page
http://www.totalvac.com/videos/kirby-vacuum-cleaners-videos.htm
there is a video at the bottom on changing belts on a Kirby
Sep 23, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Agitator stops when sweeper is pulled backward
If you have made no changes to the vacuum's setup and are using it on same carpet you have previously used it on with no problem, then the most likely cause is the agitator/beater bar's drive belt is worn or on some models may have a tension adjustment which is set too loosely. This can also be caused by having the vacuums height adjustment set to low for the carpet or flooring you are using it on, causing to much drag when the vacuum is pulled backwards for the agitator to overcome.
The vast majority of agitators turn in a forward direction, as if it would pull the vacuum forward, when you pull the vacuum backwards the drag is increased.
So...First check height adjustment (a no cost fix), then check out the tension adjustment (if present on you model, some engage when top of vacuum is tilted back after stepping on the release pedal) Lastly, consider changing belt especially if you have had the vacuum awhile or if it gets a fair amount of use or it you seem to need to use it on a low height setting all the time to vacuum up debris.
Hope this helps!
Dec 19, 2007 | Kenmore 34923 / 34925 Progressive Bagged...
How to change a Hoover Elite sweeper belt
on the bottom there should be a few screws take them out and a cover should come off the belt is right there. hope this helps
Dec 18, 2007 | Hoover Elite U5061-900 Bagged Upright...
Singer 3HV100 Portable Upright 3 In 1 Vacuum Logo
Top Singer Vacuums Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
Are you a Singer Vacuum Expert? Answer questions, earn points and help others
