Question about Freezers
Kenmore freezer upright model 253 loose door handle
  • 62 Answers
SOURCE: Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Posted on Jan 06, 2008
22yooper
  • 828 Answers
SOURCE: Freezer won't run
There is no reset switch. There is a thermal overload protector mounted on the compressor. Does the compressor hum and then give a click sound. If so your compressor has failed. If the compressor is cold (Room Temperature) and it does not try to run your thermostat may be bad. If so remove the temperature control and jumper the two main wires that connect to the control. Unit should be unplugged to do this operation. Insulated the wires so they do not contact any metal surface. Plug the freezer back in. If it runs and cools replace the thermostat.
Posted on Jul 06, 2008
  • 1779 Answers
SOURCE: door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Posted on Aug 08, 2008
larryyb
  • 291 Answers
SOURCE: Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Posted on Jul 08, 2009
Controlfrk
  • 304 Answers
SOURCE: Kenmore 253 9280413 freezer keeps running
The coils are embedded in the outer walls and will make the cabinet feel warm outside when the compressor is running. It needs about 4 inches of clear air space around all the outer case walls to properly get rid of its heat. If you have items stored too close to the outer walls they will act as insulation to keep heat from being dissipated. This can cause long run times.
A unit that has lost freon gas due to leakage, while unlikely, can also extend run times. Normal temperature should be about Zero when the dial is set to halfway.
Good Luck
Posted on Sep 17, 2009
Kenmore frostless freezer, Model 253-9280413. Food is properly frozen but both outside walls and the top are extremely hot to the touch, particularly the wall to the left of the door which is so hot you...
If your condenser grill is extremely dirty or air flow is not adequeate there will be heat transferance to the cabinet itself.
Highly recommend that you clean your condenser grill (the grill underneath the cabinet) and vacuum as much as you can then blow it out with an air compressor.
Jul 17, 2011 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Need a manual for 253-9284215 Kenmore Upright Freezer
The first three number are who made your refrigerator, Gibson (Frigidaire) Below are the model numbers that the user manual falls under, Click Here=> 253.9284215
KENMORE Upright Freezer Model: 25321711103, 216769200, 25321402101, 25321741102, 25329201002, 25321402102, 2539280415, 2539287215, 25321041100, 25321201102, 2539280214, 25321411100, 25321211101, 25321421104, 2539284215, 25320211002, 25321111103, 25321421101 If you have questions please let me know, Thanks, Sea Breeze
Oct 06, 2010 | Freezers
What should the tempurture control on a 13.7 cu. ft. Kenmore upright , model 253 214 21101 freezer be set at when 3/4 to full be set at?
you will have to play with the adjustment until you get into its range. the load has alot to do with the box temp. I suggest getting a thermometer and try setting the temp to @20-25 degrees and see if that helps
Nov 26, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Jul 02, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
FREEZER ALARM WILL NOT SHUT OFF
Use a freezer thermometer and tell me the actual temperature. Or at least store some ice cream and see if it stays brick hard. Unless I have some idea of the actual temp I can't tell if defective freezer or alarm
May 11, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Dec 28, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
69 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
