Question about Whirlpool Kitchen Ranges
RF367LXSS Whirlpool model RF367LXSS 0 in one of the burners the inner burner is not working the outer burner works . What could be the issue?
jsrock516
  • 5911 Answers
SOURCE: Gemini Range Dual Burner
Unfortunately, you cannot repair one element of a dual burner. It all comes as one unit. When one portion of a dual or triple element goes bad, you must replace the whole element. I believe the part number is 1032746 and runs about $70. You will have to lift the glass top to access the burner elements. If you decide to pursue this on your own follow these steps: 1. Unplug range and/or turn off main breaker. 2. Open oven door to access screws under front edge of cooktop. Remove two screws and the top should tilt up. 3. The top will not stay up on it's own, so you will need some assistance holding it up. Some ranges have a couple of disconnect plugs that you can unplug, so you remove the entire top and lay it somewhere to work on. If this is the case with yours (as I suspect it is), lay some soft towels down on the kitchen table or counter top and lay the cooktop upside down. This will make it much easier to work on. 4. Remove affected element by disconnecting the wires first. You may want to write down how they came off, so you can be sure to reconnect them in the right order. 5. Remove mounting brackets holding element in place. Pay particular attention to the numbering scheme on the bottom of the element and where the brackets are mounted. The new element usually doesn't come with new brackets which means you have to take the brackets off the old element and put them on the new element. Make sure you install them in the same numbered holes as they were located before. 6. Reconnect wires and reinstall cooktop, making sure you reconnect the disconnect plugs if equipped. Now, be careful when working on the cooktop while it is upside down. Make sure you don't apply too much pressure on the glass or you could crack it. Also, use extreme care NOT to touch the element surface as the oils from you hands can cause hot spots and effectively ruin it. The bake light material in which the element is mounted is also very fragile. DO NOT put to much pressure on it or it may crack and break. Once you get the cooktop reinstalled and power reapplied, op test it to make sure BOTH elements are working. It is normal to see a little bit of sparking at first with new elements and/or an odor. Test the entire range of the element and make sure it regulates like it should. I hope this helps you.
Posted on Aug 04, 2007
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
blueextc3221
  • 15935 Answers
SOURCE: Looking for replacement burners for Whirlpool
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
SOURCE: Troubleshooting a whirlpool cleantop gas stove
troubleshoot a whirlpool stove mdl# SF367FEYW4. The broiler works fine but the oven wont light.
Posted on Oct 29, 2010
SOURCE: Kitchenaid superba burner (large burner front left) works only on high regardless of setting
Replace the infinity switch for that burner.
Posted on Jan 07, 2012
Large triple burner on right works on outer burners but inner burner will not come on??
Computer controlled. You need a technician. (I avoid buying appliances like that, like I avoid the plague). God Bless (and long live) the older appliances with knobs and thermostats!
Oct 08, 2012 | Ovens
Our Uniflame Grill has a round outer burner and a round inner burner. The outer burner has a large orange/yellow fllame. The inner burner has a small blue flame. Is it normal for the inner burner to...
Bob, your wife is partially correct. However, both burners should have blue flames with orange tips. Cleaning the burners and the their venturi valves, should solve the problem. When I say cleaning them, I mean removing and cleaning them.
Hope this helped you and Happy Grilling!!
Jun 27, 2011 | Uniflame FG2204C Grill
My GE profile electric range (model PS905SPSS) has a power boil burner with dual burner elements (one inner circle and one large outer circle). The outer circle one is glowing and heating but the inner...
Disconnect power to range. If you have an ohm meter, you can check the burner coils for continuity from the wires at the switch. If not, open oven door, remove screws holding top. Lift up top and remove screws holding the set of burners in question and visually inspect the inner coil for a break in the burner coil.
Nov 27, 2010 | GE Ovens
One of the dual zone stove burner stopped working. The inner one has stopped the outer ring is still working
You have to determine if the control or the burner is bad. Only way is to verify power from the control. If power is there the burner is bad. If the control is not powering the burner then the control is bad. Rarely is it both but not a impossibility. 240 volts so a trained professional is preferred.
Eric
Dec 05, 2009 | Whirlpool GR448LXPQ Electric Kitchen Range
Burner on stovetop is out
good day,
hope this link below will solve your problem.
kitchen appliances
Sep 28, 2009 | GE Spectra JBP78 Electric Kitchen Range
Kenmore smoothtop model 911.9554590 duel size burners
the inner burner is broken so the whole thing needs to be replaced. check your owners manuel for warrenty times on the burner. otherwise just replace the burner and that will solve your problem..
Mar 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
COOKTOP
its been my experience that the dual burner switch is far more likely the culprit, unless you can physiclaly see the outer ring is broken( visual inspection works wonders. as far as trying to ohm out i generally look at theelemnet itself (4 wires lead to the elemnt you can trace 1 to the outer portion of element, and 1 to the inner portion.WITH POWER OFF Iswithc those 2 wires and the restore power try element ad watch for outer ring to work inner ring no good. now i know its the switch not sending power. reset wires and order new switch
Mar 08, 2008 | Cooktops
Whirlpool supercapacity 465 range won't heat up
hoops, it almost sounds like you lost a leg of power, L2. L1 is sending power to the board but but it's not making the loop. Too much of a coencidence that the burners and oven are not working. Check the cord connection to the oven. You should have 220V across the 2 outer terminals. 120V from each end to center terminal. Let me know what you find. Catriver.
Dec 16, 2007 | Whirlpool GR465LXLS Electric Kitchen Range
Problem w/burners & lights after self clean
You may want to re-seat the right two cooking elements, in case there is poor electrical contact. When you have them removed, clean the contacts with denatured 91% alcohol and a Q-tip. The removal procedure follows.
First, unplug the range.
LIFT–UP PORCELAIN COOKTOP
To lift:  When cool, grasp the cooktop front
edge.  Gently lift up until the two support rods
snap into place.
To lower:  Hold the cooktop front edge and
carefully push back on each support rod to
release.  Then lower the top into place.
COIL ELEMENTS
➢When an element is on, it will cycle on
and off to maintain the heat setting.
➢Coil elements are self-cleaning. Do not
immerse in water.
To remove:  When cool, raise element.  Carefully pull out and away from receptacle.
Check them for damage. They do wear out.
To replace:  Insert element terminals into receptacle.  Guide the element into place. Press down on the outer edge of element until it sits level on drip bowl.
COIL ELEMENT SURFACE
➢ On Canadian models, the two front elements will not operate during self-clean.To prevent the risk of electric shock or fire, never line drip bowls with aluminum foil.
If that does work, you may have a faulty control panel. In that case, call Maytag at the number below.
Maytag Customer Service
533 Benson Road
Benton Harbor,MI 49022
(800)688-9900 U.S.
(800)688-2002 Canada
Dec 03, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
78 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
