Drayton LP522 Heating & Hot Water Programmer
LCD screen on heating & Hot water programmer has gone practically blank with 1 arrow at the off and one at the once both on the hot water side with the green light on. The only way to turn the water heating off is by turning the power off. I hoped this would reset everything but just the same when it is turned back on. Tried pressing the set and + button to reset but none of the buttons on the programmer are working. This was only fitted last month and was working fine till last night...has it failed and we were unlucky to purchase a faulty unit???
  • G King
    G King Apr 12, 2014
    This all I see on the LCD Display
    Problem Solver:
  • 6 Answers
Mine is a different brand but looks similar if yours has a drop down panel which you open to set the times and to alter for winter summer in this panel you will see a very small hole Take a ballpoint and insert in the hole and press this is a reset button that the electrician told me about when mine went wrong it is not marked but it is a tiny button inset in the hole
Posted on Apr 12, 2014
Testimonial: "Hi Heather....I have just checked and unfortunately this one doesn't have a reset like that which is annoying as that may just have done the trick!"
Central heating 7 day programmer has no power to it
That may be a 24V Tstat and there would be a little transformer in the boiler that powers the Tstat. Sometimes those burn out.
Oct 08, 2014 | Water Heaters
Drayton lp522
Seems like the display unit is burnt out and needs replacing, they are not usually repairable
Apr 12, 2014 | Heating & Cooling
Hi, I have a drayton lp522 programmer with a
go to boiler Disconnect red line and jump out White and red line at boiler if the fires reconnect red line and replace thermostat
Sep 23, 2013 | Heating & Cooling
I have Drayton Heating System in new home. I seem to be unable to put my central heating on without also having the water heater on. The boiler will come on if the water heating and central heating is on...
you will only be able to have the central heating on seperately if the system is fully pumped. Why would you not want the water to heat? it is more cost effective to use the residual heat to heat the water and keep the temperature up. Costs alot more to heat a cold house and a cold water tank
Nov 06, 2011 | Honeywell Programmable Thermostat Heater
Hi, I am having problems with the timer that controls my boiler. It is a 'Lifestyle LP522'. The hot water is set to come on in the morning for 4 hours and again at 4pm for 3 hours. The heating is...
then there must be a problem with the programmer as the boiler thermostat will call for heat only if the programme is on try setting the water side to 24 hrs it won't cost any more to run , but will prove if programmer is working .
Mar 07, 2017 | Heating & Cooling
ST6400C programmer, heating switched off. Switch hot water on only, tank full of hot water but pump runs and radiators get hot. Wall stat is set at zero. When programmer is touched and the flap dropped to...
Have had a lot of these programmers with this fault.Integral fault with electronics.Programmer will need to be replace as unrepairable.You should be able to find a straight replacement version from your heating supplier.
May 11, 2011 | Honeywell Programmable Thermostat Heater
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
I've a problem with my central heating, I've changed my central heating programmer to a drayton lp522. My heating is constantly on. The only way that I am able to turn it of is with the thermostat when I...
Hi you never mentioned which programmer the LP522 replaced, as the LP522 is a 5/2 day programmer.
you may of wired directly to the heating on terminal on the programmer?
It may of been that you had a basic programmer which was only designed for the system you have installed.If i know what existing programmer was used i may be able to help?
Kindly
Richie
Dec 03, 2008 | Water Heaters
Honeywell ST6400C programmer
Hi yes sound like it not working on hot water only it would check ou the wiring on this side
Jul 25, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
236 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
