Question about Troy Bilt 5.5hp Self Propelled Mower
Troybuilt 675 hp lawn mower doesnt start
At first it used to turn on and shut off in 2 seconds. i got the starter spray kit and worked great for 3 weeks. changed spark plugs, airfilter as well.
just yesterday, sparks started coming out of the engine, not in a violent manner but like 2-3 of them and i stopped the mower. it was smoking for a while afterwards.
now it doesn't start at all. i've done all the cleaning to parts i know how to do (airfilter, sparkplug, starter kit, carb). HELP.
Self propelled not working on troy built 675 series bought 5/08. The belt is still on.
Posted on Sep 13, 2009
Mower can not start
Does it have spark? Does the engine get fuel? If you spray starting fluid into the air filter will it start up?
Sep 20, 2016 | Craftsman 675 Series 190cc 22" Briggs ...
Starving for fuel runs fine on starting fluid
Make sure gas tank and gas line isn't plugged. Also, make sure the gas itself is good, might have water in it.
Apr 25, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
I HAVE A CRAFTMAN LAWN MOWER 6 HP SELF PROP RUN FOR 2 OR 3 MINUTES ONLY I CHANGE THE OIL GASOLINE AND S/PLUG CAN YOU HELP ME TO FIX IT?
It sounds like you have a bad Ignition Coil (Module). This is how they act when they start going bad. When they get warm, they quit. Some will last up to 20 minutes before they shut down. You can sometimes find a used one pretty cheap at a small engine shop.
Jim
Aug 07, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
The electric starter spinns but wont engage to turn 6-5 hp briggs and strattanengine on my huskvarna lawn mower
hi there
svseanachai
have you had the battery out ? if so did you refit the battery back in , with the proper connections to battery - reversed connections at battery makes starter spin but starter clutch wont engage - have seen this on b/s 16 hp vee twin
if this is ok check the starter clutch / helix and gear they may be faulty or stuck
have a look let me know
cheers hope it helps
pauly46
dont fprget the thumbs rating
Jun 02, 2011 | Husqvarna 675 hp 21" Honda Rear Bag Push...
My Craftsman 675 190cc starts in full throttle what could be causing this
sounds like the carburetor is a little gummy and when the engine shuts off it goes to full throttle by the govenor for easy starting but is supposed to return to the set 3600 rpm. try spraying carb clean on the carb and wiggle the govenor arm to make sure it move freely
Feb 23, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
What would cause mower to die after starting?
your carb. is gunked up. get a can of starter fluid and a helper. have the helper spray some starter fluid into the air intake to keep it running after it starts. Once it runs for a couple of minutes it will be ok. J.
Jun 27, 2010 | Craftsman 675 Torque 190cc 21" Briggs ...
My 675 will fire up a start and will immediatly quit. i have cleaned the spark plug and put in new gas.
it's still getting bad gas. take off air filter, prime with fresh gas, use an old spray can, and keep spraying while running until all old gas is used up in the carb
Jun 26, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Mower starts for 15 seconds then stops.
if it is still new. call troybuilt and ask who in your area does service work on troybuilt mowers, because it is still under warranty...good luck
Apr 07, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
1,464 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
