Question about HP Pavilion dv7-1130us laptop
Hp probook 470 g1 starts fine but nothing on my screen, works on my tv but not laptop. only a week old have I done something
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 94 Answers
Right click on desktop -> select screen resolution. Select identify. If external monitor is number 2, select monitor number 1 (laptops monitor) and from dropdown menu select "extend these displays" or "duplicate these displays". Select apply, picture should be shown on both screens.
Posted on Jun 04, 2014
  • 4 Answers
SOURCE: Display Failure for HP dv9000 Laptop 17"
Thanks Zohail for your comment.
My friend Juan Carlos asked me to check his laptop.
Captioned laptop was checked/inspected by two technicians and no one get it to work.
Fault Description.
After 3 months of use. The wireless mini-card fails. No wireless connection can be made.
Randomly the laptop fails to boot up. Black screen and power led (blue lights) on.
Owner took out the battery module and reset the laptop according user manual instructions. He got it to work a couple of times until the laptop was un-responsive at all.
I goggle the Laptop model number and the fault description and plenty entries showed up. Faulty motherboard, short guarantee from HP, etc…
I found the service manual from this series and I decided to verify if the motherboard was really damaged.
Prior a full dismantling I reset the bios by disconnecting the CRT battery. I made an other test: the machine starts the boot sequence, read from DVD, later pass to hard drive, the hard drive led blinks a couple the times and that’s all. After a period of time the laptop shut downs itself and reboots again….black screen ….nothing……..
I tear down the laptop (according service manual instructions), check all boards and I did not find any sign of damaged component or over-heating.
I took special care during the dismantling, I let the CRT battery in place (motherboard) but I disconnect every thing. Everybody must be aware that this particular mobo has a
small switch (identical to the power switch). Captioned switch can no be accessed from outside (you have to dismantle the computer in order to see it). I took a ball pen and press this switch for five seconds (twice). I assembled back the laptop and make a test in order to see if starts. The machine boots and the set up screen came up. “ Press F1 to continue… I press F1 and the start sequence complete….
I found that the power settings in Power Profile (HP Recommended) was 2% in critical battery (too low in my opinion)
Conclusion: the machine is working; the only thing that I could not get to work was the wireless min-card. I reload the drivers but probably the mini-card is faulty.
I hope that this solution helps.
Posted by MCampos
Posted on May 31, 2009
gsage
  • 180 Answers
SOURCE: hp laptop 9720us screen wont brighten or dim. last
You got the wrong inverter fitted - i'm sure your unit requires a sinle lamp inverter and they have cheated - putting in a generic lamp inverter and branching togeather the wires to accomodate the single plug thus reducing the available volatage for the lamps - this is why it's dim - correct part is 431391-001 Display panel power inverter - For use with single lamp display panel
Posted on Aug 08, 2009
  • 1752 Answers
SOURCE: Hp 4510s probook will not power on
Your battery is shot.
Posted on Nov 03, 2009
  • 2973 Answers
SOURCE: hp probook 4510s cannot get cd tray open
Maryar,
The tray may have got stuck. It happens. What you can do is look for a small hole on the face of the drive, either on the tray front or just below it. Insert a paper pin through it. The pin will press a lever which will open the tray. If you do it a few times the tray may get unstuck finally. Hopefully.
Posted on Dec 13, 2009
  • 4349 Answers
SOURCE: i can adjust screen brightness
Typically there are two ways: through the keyboard, usually a function button and brighter or darker button, and 2nd in the power settings. Lower screen brightness gives much longer battery life.
Posted on Feb 14, 2011
Can i get some help at a sistem homecinema
If your system has a VGA or suitable video input then it is possible to connect your laptop to it for viewing your laptop. As for cutting wires NO! Coloured connectors? I advise looking at your instruction manual for the System. Red is audio right. Black or white is audio left. Yellow is composite video. All are inputs.
Jan 25, 2015 | HP Computers & Internet
I have a HP Probook laptop 6555b and last week while using it , it displayed that it was not charging. I checked the connector with a multimeter and found it was damaged.I replaced with a spare one t
Check your Adapter Cables properly connected or take your battery from the Laptop and put it back. Then try restarting. If nothing helps check your Adapter with another same model Laptop. If the Adapter working well then your Battery is dead!.
Dec 01, 2014 | HEWLETT-PACKARD Hewlett Packard HP ProBook...
Hp probook only boots to hp logo
you could try the ram, i had same problem , replaced ram and it was fine. might work
Feb 06, 2013 | HEWLETT-PACKARD HP ProBook 4525s Notebook...
Webcam not working on hp probook 4430s
try going to device manager, uninstall and then reinstall, this may work
Jan 25, 2013 | HP ProBook 4430s Notebook
Hp laptop 9720us screen wont brighten or dim. last week my screen went blank brought it to a shop they changed the inverter and also some cable connection . works fine just not quite as bright as before ....
Mar 10, 2009 | HP Pavilion DV9720US Notebook
Screen wont light up, cannot see the screen.
press f8 after boot up ,then select option enable vga,then when it start go to control panel,
un-install the display drivers,restart and reinstall them.
Feb 06, 2009 | HP Pavilion dv7-1130us laptop
HP Pavilion dv7-1130us laptop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
