Question about Electrolux 8 cu ft Stackable Electric Dryer Titanium EIMED60LT
Dryer will not start
There is power to dryer and both sides of connections in the dryer, but, will not power up at all. dryer is right out of the box....
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Check door switch. listen for timer clicking .also belt could be off drum
Posted on Apr 14, 2014
Our dryer model wed6200sw1 will not power up. my brother inlaw installed a 3 wire power cord when helping us move. there is a white wire that hangs loose in the housing that I believe is a nuetral ground,...
This is tough to say without being their.. But lets try...You need to hook up the power cord correctly before doing any other diagnostics...On the dryers terminal block you should have a black on one side, white in the center, and red on the other side THE POWER CORD WIRES HAVE TO BE HOOKED UP THIS WAY. when checking voltage at the back of unit make sure its 120 volts from center to right side , and 120 volts from center to left side after this is correct we can diagnosis from their if its not working right.......
Sep 01, 2010 | Dryers
Thesawdustmaker@msn.com
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 05, 2008 | Whirlpool LER5636P Electric Dryer
Changing the power cord?
Yes your right on track. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru it, but you seem to be doing it right.
Mar 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do I connect the a 4 prong power cord
Four prong dryer cord connections to dryer:
- Red to far-left or far-right screw on dryer (doesn't matter which side)
- Black to screw on opposite far-side on dryer
- White to center screw on dryer
- Green to dryer grounding screw
Any questions, please let me know.
Oct 02, 2009 | Maytag Dryers
Dryer will not start have replaced the heating element, door switch and on switch
hi, i recommend inspecting the terminal block that the power cord is connect to on the back side of the dryer. this terminal block may be faulty or, the cord could be lose and not connected properly.kindly, inspect this device that is located on the back side of the dryer for lose connections. if the termainakl block is in good conditon and, the power cord is screwed on tight, thsi iwll confirm timer fialuer.
replace the timer in this case.
May 20, 2009 | Kenmore Dryers
Dryer problem
with power disconnected
follow the wires from the start button, to a relay,
check the wires (both ends) of all leads to the relay and reconnect any that have fallen off. (crimp tighter if they have fallen)
Check door switch function and connection.
check timer connections
the relay start-button timer and door switch comprise a latching circuit, when the start button is pressed the relay is supposed to latch closed and supply current to heater and motor. if the latching circuit disconnects the relay does not latch closed, and only runs as long as the start button is pressed.
if nothing has disconnected one side of the relay has usually failed, and the connection is not being made to latch the circuit
replace relay
cd48320.jpg relay is shown at right, 2 switches connected by a dashed line.
Oct 12, 2008 | Kenmore 62602 Electric Dryer
Putting new power cord on dryer i have a 3 cord set up a red wire a black wire and a white wire and dont know which wire to connect to which.
on the back of your dryer.
1.connect the white wire to the center of the junction box.
2.than take the red wire and connect it to the left side of your junction box.
3.than take the black wire and connect it to the right side of the junction box.
If you have a green wire on the cord as well. PLEASE make sure it is connected to the dryers back panel. do not leave it to hang.
Please do not forget to rate and comment about your experience today.
Aug 16, 2008 | Whirlpool Dryers
Older whrilpool dryer
make sure the green wire is connected like in the picture. this connects directly to the neutral, if it is disconnected when you connect a 3 wire cord then this problem you are having will happen.
Aug 06, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryer heats up but won't turn
Perhaps you have a broken drum belt
May 20, 2008 | Whirlpool LEB6200 Electric Dryer
Whirl pool dryer
L1 Hot= Left terminal (Red Wire) ...... L2 Hot= Right side terminal (Black Wire) .......... Netural = Center terminal (White Wire) .................. Ground is Green connect to the cabniet of the unit and remove the connection strap from the center terminal on thje dryer wiring block..
Feb 22, 2008 | Kitchen Ranges
Electrolux 8 cu ft Stackable Electric Dryer Titanium EIMED60LT Logo
63 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
