What size screw for holes on back of set
What size screw do i need on my phillips lcd model #42PFL6704D/F7 Their is four holes on the back of the set to be used for wall mounting. Need to know the size of the screw for those holes
  • Anonymous Mar 25, 2014
    Model #2611-TLXB
  • Anonymous Mar 29, 2014
    have wall mount but need to know what size screws I need for the back of tv
  • 92 Answers
Go to this size to figure out the screw size. http://www.tvwallmountguide.net/
Posted on Jun 18, 2009
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
Aug 23, 2015 | Panasonic Viera TC-32LX85
Screw size for wall mounting for Phillips 32inch. What is the screw size on the back that you would use to mount tv to wall
Get in touch with Philips at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
Feb 28, 2015 | Philips 32PFL5332D 32 in. LCD Television
What size mounting screw for a Vizio Model VO47LFHDTV30A
Are u trying to mount it on the wall ?
If so. Buy a universal **** it come with all the screw
Or call Qcwireless thay can get thm for u
Oct 11, 2014 | Vizio L32 32 in. LCD HDTV
Need 4 screws for phillips 42pf9946-12 plasma tv to fit wall bracket
Best way to be sure is call Philips customer service with the model number to get the thread type and length of these--no two sets are the same here---usually most will be available at local hardware stores if Phillips does not sell them(that would be a bit more pricey and take time).
Jun 15, 2012 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
TV Stand Screws
If you still have the manual or know the manufacturer you might want to try giving them a call. They'll know what size screw was used on that model tv stand. Otherwise, measure the insides of the holes and go to a hardware store; they should be able to help you find the right one. Just make sure they are not too long. Screws are pretty cheap, so I'd suggest buying one of a couple different sizes to try out. They should fit snugly in the hole, but should not split the wood/plastic. You'll want to get four of the same size washers and nuts as well once you know what kind of screw you need. That way they won't loosen. :)
May 18, 2012 | Emerson LC320EMXF 32 in. LCD TV
Wall mounting Philips 32PFL6704D/F7
First of all a standard screw will not work. You will have to visit your local hardware store and purchase a machine screw to fix the problem. In many cases you will have to use an estimated guess and gamble your time and money. The length and width of the machine screw will be found at this store. The effort is miniscule and money will be meager. Remember, do not use a standard screw!
Jul 23, 2009 | Philips 32PFL6704D 32 in. LCD TV
Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
Apr 10, 2009 | Insignia IS-LCDTV32 32 in. Television
Wall mounting emerson lc320em9 television
I don't know the model in particular, but most of these sets can be wall mounted if you have the screw holes for the mounting plate in the back of the set.
What I believe the tech was telling you would be that it is best to not wall mount the set. The reason is that we found that we have been seeing a higher failure rate from sets being wall mounted. This is because the surface of the wall reflects some heat back in the set, and thus causes it to internaly run warmer. This is also the same from running a set inside of a cabinet. The complete surface area behind the set being very close to the wall surface blocks cooler air circulation. It is best to run these sets on a stand that is out in the opened at least 1 foot away from any wall surface.
Jerry G.
Jun 28, 2008 | Televison & Video
42'' LCD PLTV-4250 MOUNTING
The universal mounts generally have a selection of screws that are to fit different makes and models of tvs.
If you bought the appropriate size mount for the size of your TV, there should be mounting holes that match your TV, and screws that will secure it.
I have not seen any mounts that use more than four.
Apr 07, 2008 | Protron PLTV-4250 42 in. LCD Television
Televison & Video Logo
2,643 people viewed this question
Top Televison & Video Experts
