Question about Samsung Computers & Internet
L1900e dark backlight
I've got a problem with L1900E, when i turn it on the logo shows up (very dark) and dissapear, and i have to wait a few minutes to see anything. Picture is blinking and it's barely visible. I have to wait 30 mins to see desktop, but it's still too dark. Using forte manager doesn't seems to change anything about brightness. I'm equipped with miliammeter and frequency counter, i don't have an oscilloscope Is it CCFL need to be replaced or it's an inverter problem?
    New Friend:
  • 28 Answers
1st try to check circuit that is operating CCFL, otherwise replace CCFL , it does not look like ccfl problem
Posted on Apr 12, 2014
  • Lukasz
    Lukasz Apr 12, 2014
    You need to be more specific, i dont have even a circuit diagram of the inverter so i have no idea what i should be looking for
4 Suggested Answers
SOURCE: Viewsonic VX900 blank screen
Here is a pic of the fuses on the inverter board for a Viewsonic vx900, you can visually inspect them as well if you do not have a volt meter. While visual inspection is not 100% reliable, usually when these are popped you will see the red line across them is black or broken.
Posted on Jan 03, 2009
BoiseLCD
  • 63 Answers
SOURCE: LG L1900E flickering after cold start
This is probably due to a bad solder joint somewhere. Bad solder joints can effect a unit in the reverse also. IE works at first and then dies after it gets warm. Think about how metal expands when it is heated. And contracts as it gets cold. If there is a hairline fracture on one or more component joints, this would cause it to not have such a great or solid connection when it is cool, or contracted. As it gets warmer, the solder expands therefore filling the void and giving it a good connection.
Regardless, it will likely only get worse over time. If you're handy with a soldering iron, pop it open and reflow all the joints. Especially the ones on the transformers and copper coils. Best to hit them all, excluding the tiny surface mount devices.
If you need further help or if you'd like to have this, or any other LCD monitor repaired for a flat rate fee of $40, please visit my web site http://BoiseLCD.webs.com, or email me at cjmclellen@msn.com.
BOISE LCD - LCD Monitor Repair
Chris McLellen
(208) 891-9117
cjmclellen@msn.com
sleepy_user
  • 140 Answers
SOURCE: TFT VE710b backlight needs 20 Minutes to light up fully.
The inverter is yoru problem. It takes a while to build up the voltages that is needed to drive the bulbs.
Unless you are operating the monitor in temps below around 40 degrees F... temp is not a factor.
Your prob getting ready to buy a new one. Your inverter(s) are on thier way out.
Posted on Jan 23, 2009
Vizio E470i_A0 shutting off after loosing horizontal frame sync
It could be several things but I'd start with a main board, the fact its shutting off kind of drives me away from Tcon as that shouldn't shut the set down if there was an issue there, it also could be power supply, you could test the voltages from the board once it starts giving issues and if some are off then change the power board.
Dec 10, 2017 | Vizio Televison & Video
Vizio E480i-b2 LED TV loosing picture and sometimes shutting off
I don't think you had backlight issues like you thought you did as the set should have shut down the backlights totally as soon as it sensed over voltage or over current, I'd try a new main board and see if that fixes things up for you
Dec 09, 2017 | Vizio Televison & Video
BLANK SCREEN..NO SOUND OR PICTURE ON MY SANYO 50" FLAT SCREEN TV...MODEL NO: DP52440 HOW DO I RESET IT
Try unplugging the set from its power source, let it sit for 10 minutes and then plug it in again, then turn it on. Are you getting any on-screen messages or logo display when you turn it on? Is there any backlighting showing? (in a dark room, the screen should have a faint glow). Try switching the input source using the remote. If the set is less than a year old, it is under warranty. If nothing is displayed ever on screen, the panel might need repair or replacement.
Jan 28, 2015 | Sanyo Televison & Video
I thought I asked this already but it does not show up. I have a 15" lcd tv that will only stay lighted for a few seconds on each channel then goes dark. I can kinda see a image on the dark screen. I...
the backlight is either going out or the capacitor for the backlight is bad to where its not storing enough power to run the backlight the start capacitor must be good but the run capacitor might be bad usually the backlight itself goes bad but not if it turns on for a few seconds it would have to be the capacitor.
Oct 04, 2013 | Philips Magnavox 15MF400T 15 in. LCD...
I have had my 55" Vision for a year and a half. Today I was watching a movie and the picture went dark and audio stayed on. If I turned the TV off and then back on it would light up with no Vision logo...
Sounds like you have a backlight problem. To verify this, turn on the set and dim the lights in the room. Take a bright flashlight and shine it on the screen. If you see a faint picture, you either have a back inverter or a bad backlight bulb.
Sep 02, 2013 | Vizio GV42L 42 in. LCD Television
Sony tv kdl-46vl130, Turn the tv on, half of the picture is dark, leave the tv on for about 20 minutes, and the tv is perfect, and stays perfect no matter how long is watched, Turn the tv off, and come...
I didn't look up the model to see if its a LCD or LED, if its an LED it sounds like you have some lamps going out, try turning down the backlight settings and see if that helps
Nov 15, 2017 | Sony Televison & Video
I have a similar problem.
Actually it sounds like the phone is merely off. Perhaps the battery actually died. If so and then the phone is off. When you plug in the phone with while it is off it will show the logo then it will say please wait and the the battery icon and say charging. If the phone is charged it goes dark.
Just hold down the "end call" key for a minute and see.
This actually happened to me once. I thought my phone was broken. Just as I was about to call AT&T I decided to try turning it off which is done the same way as you turn it on. Imagine my surprise when it started right up!!!
Aug 10, 2009 | LG Vu CU920 Cellular Phone
Phone does not boot-up
i hope this is not true in your case. But I have had 4-5 customers a few years ago who this has happened to. Even us had a hard time flashing the phones fully to bring it back. My customers tried putting games and themes on the phone as well. You need to flash the phone. No easy solution. Sorry..
Mar 18, 2009 | Nokia 9300 Smartphone
Chris McLellen
(208) 891-9117
cjmclellen@msn.com
Dec 29, 2008 | LG Computers & Internet
Computers & Internet Logo
104 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
