Question about Kobo Arc
My kobo wont let me past the setup stage
My Arc was working fine but recently it powered out and when I charged it and turned it back on I had to go through the setup again. When I complete the setup and press to open the screen to get my apps it just takes me back through the setup and wont let me progress. I have tried holding the volume button down while turning it on and that takes me to a reboot screen but when I ask it to reboot it just takes me back to the setup again.
My Kobo Aura is not recharging. The charging unit seems "dead". Can the charger be replaced?
it can
Kobo Aura / Aura HD compatible Advanced Rapid Wall AC Charger ...
Gomadic Powerful High Wattage wall charger for home or travel use. Customized circuit design is based on the latest in power regulation and is tailored to the ...
Kobo Aura One Charger, BoxWave® [Wall Charger Direct] Wall Plug ...®-Direct-Touch/dp/B01MA3NLF8 Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc 7 10 HD; Kobo Touch Glo Mini Aura Hd Ebook Tablet.... ... HQRP Micro USB Charger / AC Adapter for Kobo Arc / Arc 7 / Arc 7HD / Arc 10HD / Mini / Glo / Touch / Aura / Aura HD / Vox.... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid ...
Kobo eReader Glo USB Cable - Micro USB: Cell Phones ... Rating: 4.7 - ‎11 reviews
Kobo eReader Glo USB Cable - Micro USB: Cell Phones & Accessories. ... Cable for Kobo eReader Kobo Mini, Kobo Touch, Kobo Aura & Aura HD... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc ...
Chargers & Cables - Electronics: 146 products available ' chapters ... Results 1 - 24 of 146 - Shop Online at for a wide selection of chargers & cables products, 146 items available. Enjoy free shipping on orders ...
kobo aura charger Google Search
Sep 24, 2017 | Tablets & eReaders
My kobo arc 7 screen is not responding to touches. Can it be reset?
1. Turn the power off and pull the battery out and reinsert it.
2. Hold the Volume Down button.
3. Then press and release the Power button.
4. Wait a minute,the menu appears that allows for Fastbook, Recovery, Clear Storage, and Simlock.
5. Ok,press the Volume Down button to choose Clear Storage.
6. Next,press and release the Power button,Wait for the Kobo Arc to restart.
7. You will see the two options: Volume Up for YES and Volume Down for NO.
8. If you choose YES, all data will be deleted from your Kobo Arc and including third-party applications.
9. The Kobo Arc will reboot to its original data.
10. This time you can restore your backed up data to your phone.
Nov 25, 2014 | Tablets & eReaders
When your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD is connected to a wireless network, you'll see a and-wififull.svg Wireless icon in the System icons at the top of the screen.
  1. Tap the and-home.svg Home icon at the bottom of the screen.
  2. Put your finger at the top of right of the screen and swipe down.
    The Settings shortcuts will appear.and-shade.svg
  3. Tap the and-settings.svg Settings icon.
  4. If required, tap the slider button beside Wi Fi at the top left of the screen. The button will turn blue and display On.
  5. Tap Wi-Fi. The list of available networks will appear.
  6. Tap the name of the network you wish to connect to.
  7. Tap Connect.
  8. If you see a lock icon beside the wireless connection, it means that the connection requires a password. You'll need to enter the password to connect.
Turning off Wi Fi on your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD You can turn off Wi Fi to keep your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD to keep from connecting to the Internet, which is also known as Airplane Mode.
Turning off Wi Fi extends your battery life, and also lets you use your Kobo tablet on an airplane or in a hospital.
  1. Pull and hold the power slider at the top of yourKobo Arc 7, Kobo Arc 7HD, orKobo Arc 10HD until the power off menu appars.
  2. Tap Airplane Mode.
Oct 27, 2014 | Tablets & eReaders
My kobo wont turn charge and turn on
Broken psu connector or moethboard junk it its not cost effective to repair.
Aug 20, 2014 | Kobo Arc
How do i repair the charging port on my kobo arc the cord will not fit?
That's a tough job unless you can send it back.
You can charge it with a USB cable and aPC, however it is slower but it might work.
Try that first.
May 17, 2014 | Kobo Arc
My kobo wont open the book, keeps loading but does not open
Does your Kobo turn off and on normally? Or is it stuck loading the book and totally not responding? If so, reset your Kobo. Look on the bottom edge of the Kobo - see the little pinhole? Stick a paper clip into there until you feel it push against a little switch. Remove the paper clip.
Is the Kobo working, but simply can't open a book? If it's only affecting a particular book, try deleting it and downloading it again.
Dec 27, 2013 | Kobo Arc
I need a kobo arc manual
No Probs,
Copy and paste this link.
Nov 18, 2012 | Kobo Arc
Kobo Arc Logo
47 people viewed this question
Top Kobo Tablets & eReaders Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Kobo Tablet and eReader Expert? Answer questions, earn points and help others
