Question about Uniden D1660 Cordless Phone
Uniden D1660 how to use speeed dial - Uniden D1660 Cordless Phone
Need a manual for Uniden DXAI8580-2 5.8 and DCX160 6.0
This is the link for the manual for the DXAI8580
http://www.telecomuserguides.com/manuals/filesupload/Uniden/5_8GHz/DXAI8580-2om.pdf
The DCX160 is the part number for the accessory handset used with Models D1660 and D1680 and a few others models. The handset used for these series are all interchangeable and has the same keypad function. You can reference the information for the DCX160 using the handset for D1660 Following is the link for the D1660
Apr 20, 2017 | Uniden Lands Phones
Uniden phone stuck at searching, not getting a dial tone
One thing to try is deregestering your phone and registering it with the base again.
Hole the # and 'End' key on the handset until the next menu appears (about 5 seconds). Select deregister phone (use the 'Menu' button). Do it again, but select "base unavailable". After that, set them in the base (not the handset charger) and they should register with the base.
This works on most Uniden model phones.
Jan 29, 2013 | Uniden DECT 6.0 Cordless Telephone...
Silent mode on uniden d1660 corless phone
Follow the instructions beginning on page 9 of the manual.
Jun 16, 2012 | Uniden D1660 Cordless Phone
Uniden D1660-2 how to set up voicemail and message
The Uniden D1660-2 isn't an answering machine. If you have a separate answering machine connected to your phone line, please consult its documentation. If you subscribe to a voicemail system offered by your phone company, please contact them for instructions on accessing their voicemail system.
If you need a D1660-2 manual, you may download a copy here.
Mar 14, 2012 | Uniden D16602 Twin Cordless Phone
How do i set up voicemail?
You need to contact your telephone company for instructions on setting up and using their voicemail system. The Uniden D1660 doesn't record voicemail, though it can tell you when you have voicemail waiting.
You may download the D1660 manual here.
Dec 05, 2011 | Uniden D1660 Cordless Phone
No dial tone-out of range is message
your batteries are probably going flat
Dec 04, 2011 | Uniden Cordless Phone
How do i add another handset "uniden 6.0" phone to an existing phone and base unit of the same brand.I need the step-by-step instructions please. thank you!
First make to get a compatible handset.
For the Uniden D1660-2, the compatible handsets are DCX160 and DWX337. Make sure that you have not exceeded the number of handsets that the phone can support. The D1660-2 can support 12 handsets unless you use any DWX337 handsets. Then the limit is 6. (If you have more handsets, you will need to deregister some of them first.) Then allow the handset to charge. If the handset is reading "not registered", then place it into the base unit. You should see "Handset Registering" for about 30 seconds; then it will read Registration Complete. The manual for the Uniden D1660-2 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf . This is the most common Registration for Uniden phones; there are a few exceptions (depending on the base or the replacement handset). Check the appropriate manual (see below to find the manuals).
For the DECT4096, press Menu on the base and then navigate to Handset Register. When you see Handset Registering on the base display, press and hold # on the handset to be registered until you see Handset Registering. (It takes about 2 seconds.) After the display changes to Handset Registered, check for dial tone.
On a few Uniden phones, there is a Page/Handst Register button on the base. On those you navigate through the Handset menu to Handset Register (Menu > Handset menu > Handset Registration). Then press and hold the Page button until you hear a beep. Then wait for the registration to be completed.
Most Uniden manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl . Select your type of Uniden phone and scroll through the list to your model or use the search box to directly search for your phone and the manual.
I hope this helps.
Jul 26, 2011 | Uniden D16602 Twin Cordless Phone
How do you trn a uniden D1660 cordless phone off of silent mode
To exit the silent mode, press and hold # on the handset for about 5 seconds. In the future, when you set the silent mode with this press and hold routine, you can follow it by a number (1-9) to set a specific length of time for the handset to be silent. Otherwise it will stay on until you manually turn it off.
The manual for the D1660 is available from http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf .
I hope this helps.
Jul 01, 2011 | Uniden D1660 Cordless Phone
Uniden D1660 Cordless Phone Logo
20 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
