Question about Philip Persio Watches
Instructions for philip persio titaitium watch
Do the inside small dials work or just for show
SOURCE: watch 3 dials inside face
so its a chrono watch i belive. well sometimes diffrent models require diffrent operations to set up the display.
Perhaps the manual can be found on the internet site of the watches brand.
Posted on Mar 18, 2008
  • 9 Answers
SOURCE: lost instructions for accurist chrono mans watch
It should have a CAL number engraved on the watch back and using this you can find instructions for download at www.accurist.co.uk under the after sales service area and downloads option.
Posted on Jun 18, 2009
  • 61 Answers
SOURCE: i have been given a philip persio watch, (no idea
many of these watches require 2 batteries. One for the analog and one for the digital. I would contact a jewelry store to make sure they will change your batteries; since the watch was free to you it will surely be worth the price of new batteries to get it working.
Also, some models do take only one battery but if it is not at a full charge you may have the issue you described.
If not a battery issue, then there are other detailed steps to follow (the jeweler should be able to help you.)
Note: I recommend contacting an independant jeweler (non-chain and non-mall store) because most non-independants will not change batteries in watches they don't sell.
Posted on Oct 31, 2009
  • 2501 Answers
SOURCE: I have an Armitron75/3639mptt with no instructions
Go to the web site (www.armitron.com/watch_instructions.asp) and dwon load instructions from there.
Posted on Jan 05, 2010
SOURCE: I have a Philip Persio watch which has Day/Date
LUN is short for "Lunes", spanisth for Monday. You will probably have MAR for Tuesday, MIE for Wednesday, JUE for Thursday, etc...
Posted on Nov 08, 2010
Accutime watch in roman numerals, has 3 small circles on inside of the face of the watch . i don't kno what they are for or how to run them?
I'm not familiar with Accutime watches, but it may be that the 3 sub-dials are there just for decoration.
If they're not, then the upper and lower buttons on the right will control the hands on the sub-dials.
Check the following:-
Is there any movement in the buttons when you press them, or do they feel solid as if they are part of the casing?
Do the hands on the sub-dials look as though they are slightly raised or do they look as though they are glued on?
Does pressing either of the buttons cause any of the hands to move?
If pressing the buttons has no effect at all then you can be sure that the sub-dials are decorative only.
If the sub-dial hands do move when you try the above suggestions, then get back in touch for further instructions.
Oct 06, 2016 | The Watches
I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
Apr 05, 2011 | Fossil FS2919 Wrist Watch
I have a Philip Persio watch which has Day/Date display. In the Day display window it shows "LUN"...what is that??
Oct 12, 2010 | Watches
I don't know how to get the dials to work. what do they do? how they do it?
You can find the instructions on the Tag wed site (www.tagheuer.com), select "watches" then "Carrera"
then "man" and then the model of your watch.
On the right of the page is a small menu,select "user manual". (The laptimer model does not have any instructions but if this is the one you have, try the other models to give you an indication of the dial functions).
Feb 10, 2010 | Tag Heuer Carrera Series Chronograph Watch
Inside faceplate came loose
Pull out crown and leave it in this position. This will stop watch to work and do any further damage by catching parts inside. I doubt that this would be under the warranty, because without any outside force (usually knocking) these parts would not come off. I know that you will disagree with this, but experience says that 95% of people do not recognise they watch has been knocked. I'm not here to argue, but to help. You do not need to find a particular KC repair shop. Any local watch repair shop can fix this, as this is the common problem to all watches. Just type in your browser: Watch repairs in Miami, US (or wherever you live), and you will come up with local watch repair addresses. Choose the nearest one to save your time and travel money. As a professional watchmaker I can tell you: even if your watch still under warranty, this kind of damage are not covered and you would be charged anyway - even if you would send watch to KC.
Rate me, plz.
Jan 10, 2010 | Kenneth Cole Watches
I have been given a philip persio watch, (no idea which model) it has an analogue display and a digital display. the digital works perfectly but the analogue wont start any ideas
Oct 31, 2009 | Watches
Mark Naimer watch came without instruction manual.
I purchased a Mark Neimer (?Naimer) QUO watch style W107J and it came without a manual. The buttons on the side are just for show--they do nothing. The three small dials in the center (week days, month days, and military time) are also useless. This Undergear product is a joke at best.
May 19, 2009 | Watches
I need to change the battery
On mine the back turns off using the notches in it. I persuaded it with a small screwdriver. Just be careful it doesn't slip and hurt you.
Apr 07, 2009 | Watches
Lost instructions for accurist chrono mans watch
Jan 02, 2009 | Bulova Chronograph Watch
Watches Logo
66 people viewed this question
Top Philip Persio Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Philip Persio Watch Expert? Answer questions, earn points and help others
