Question about Coffee Makers & Espresso Machines
Hi I have a jura xf70 and every time I make a coffee water leaks into the drip tray I was told to replace the brew group which stopped the leak for a while but now it's started again any ideas
    Problem Solver:
  • 15 Answers
Could be a hole in the heating block. if it gets worse and starts tripping the power out you may have to take it to a repair centre.
Posted on Apr 27, 2014
SOURCE: water leaking from steam wand when brewing shots
Try this from another post. It should help.
The steam wand began to seriously leak but a call to Starbucks Customer Service line and I was talked through how to adjust it so that the leaking stopped. It requires taking off the top/back panel of the machine (6 philips screws) then using a small allen key (1.5 mm I believe) to loosen and adjust a plastic oblong donut-shaped thing (a "cam" actually) on the shaft of the steam knob... no more drips.
The key to prevent dripping is to open the steam knob without putting pressure on it when it gets to the full-open stop position. Cranking it too hard when it comes to a stop in the full-open position will slowly move the cam out of position. Then the shaft doesn't fully seat inside the machine anymore and won't fully shut off the water to the steam wand. Then, no matter how hard you crank the knob in the shut-off position it will still drip. The purpose of the cam is to stop the knob from complete unscrewing and it also turns the pump on and off for the steam wand. The cam adjustment is very small but completely solves the dripping problem. Seeing inside the machine made me realize how easy it would be to repair problems as long as I can get the parts from Starbucks or perhaps Saeco.
Posted on Dec 29, 2008
  • 13 Answers
SOURCE: Jura Impresso E9 not dripping through spouts but into drip tray
This is most likely due to a bad o'ring. The bar you speak of...Does the unit have a small spout pointing upward from the area?...with a groove? Is the o'ring in that groove damaged or missing? When the grounds are compressed in the piston, the brew unit lowers down onto this spout and seals on it. The high pressure water then is injected upward inot the brew unit. When this seal fails the water simply leaks into the tray when there are grounds providing backpressure. When rinsing and no backpressure some of the water may be getting through. Make sure you lube up any seals with a food grade lube. Olive oil will work in a pinch.
Mike
Posted on Jul 08, 2009
Richie_asg1
  • 1036 Answers
SOURCE: Nespresso Essenza D100 leaking water while brewing
Sounds like a gasket or seal gone or a split pipe.
If it's still under warranty - take it back for free service or replacement.
If you do have to attempt DIY, then a clear silicone sealant may save you the price of expensive gaskets.
Be very careful when taking apart - take notes or photos as it will help put it back together !
I usually put related sub-assemblies together with their screws in separate pots.
Posted on Aug 11, 2009
ftw1952
  • 10319 Answers
SOURCE: No coffee will comeout of
back flow problem in the water feed valve. I never had to service one of these brands although I am sure the valve is frozen or clogged up
Posted on Aug 22, 2010
SOURCE: cOFFEE MAKER LEAKS CLEAR WATER FROM THE BOTTOM EVERY TIME I USE T
Have the same issue, looking for my receipt for warranty. All of us having this problem can't be wrong and it must be defective
Posted on Dec 10, 2010
What do I need to do when error 8 is displayed on turning on machine?
Jura does not allow access to internal parts for cleaning. Brew group is the dirtiest part as it deals with complicated movements to make coffee.
Error 8 means the brew group is not returning to start position after it completes entire cycle to make coffee.
Jura recommends to remove drip tray. Using a thin cloth, insert the hand all the way under the machine. You will feel access to the bottom of the brew group. Wipe clean the bottom of brew group as best as you can. There will be lot of coffee powder (wet & dry) that is partially responsible to prevent brew group return to start position.
A better method is to open the machine using special key. Clean & lubricate the brew group. every two months. This will prevent Fungus and Bacteria growth. .
Instruction videos are posted on You tube channel "Parts Guru USA"
Use the link below to order the special key. Services Unlimited Inc Parts Guru Since 1988 Services Unlimited Inc Parts Guru Since 1988
Mar 20, 2016 | Jura Capresso Impressa S9 Coffee...
Leaking water
If it's clean water which runs out, check the hoses going from the water tank to the pump then through the boiler to the brew group. If coffee is running out instead, then it's the spout going from the brew group to the cup. I know Saeco's not Juras but they all function the same way.
Mar 23, 2013 | Capresso Jura-13204 Impressa E9 Automatic...
Hello my saeco vienna coffe machine leaks on the side when I make my coffee
Try changing the water inlet seal under the water tank (part # NM05.006)
May 14, 2010 | Saeco Vienna SuperAutomatica Coffee...
It leaks at the drain outlet behind the brew group...overflows into the tray and leaks horribly from underneath unit
Hi
The drain in the back of the machine is plugged with coffee residue. There is a pocket below the injection tube ( the one with the 2 o-rings on it) that is filled with coffee residue that needs to be cleaned out. When its clean and you put water in the pocket it should come out the drain hole into the drip tray. The pocket is where the brew unit relieves the pressure when it is done brewing. That is why you get coffee residue in the pocket.
Oct 11, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Magic De Luxe type SUP012 r Water leakage into brew unit
HI
Your grind might be a little to coarse or you are not getting a full charge of coffee in the brew unit. Water is released into the drip tray when the brewing is over. If the grind is to coarse or you don't have enough coffee dossed into the brew unit, then there is more space for water and you get more water in the drip tray. Open the door and push the lever at the top center of the door towards the plus but not all the way. 1 click back from the plus(+) is fine. When the machine is grinding pull the handle toward you(smaller number). Now change the grind a little at a time, but don't make it too fine. That will cause a lot of problems later on that is hard to correct.
Jun 26, 2009 | Saeco Magic De Luxe Espresso Machine
I have a new Z5 (less than 300 cups) that began dispensing a slow and reduced volume of coffee and also began leaking approx 3 oz of water into the tray after just 2-3 cups of coffee. I have meticulously...
If the grounds are really wet and not looks like a round firm cake, you need to use coarser grist on the grinder. The water in the drip tray is coming from the brew unit. The o-rings are not holding the pressure inside because the sieve is clogged. It could also be that the o-ring are dirty, then the brew unit needs to be disassembled and cleaned.
A good way to controll if the grist is too fine, is to watch if the coffee is just dripping from the outlet. Then try adjusting the grinder until the coffee flows evenly. You can also hear if the pump works harder during brewing.
Apr 26, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Mike
Feb 05, 2009 | Jura Capresso Impressa E9 Espresso Machine...
Leaking Water shorts out machine
I had the same problem. What may be the problem is the tiny water drip hole that feeds the drip tray is blocked with coffee sludge. Open the machine and remove the dump bucket, drip tray, and the brew group. Behind the brew group is a flat plastic piece which has a small drip hole at the bottom of it. This may be blocked which causes the water that should go into the drip tray to build up and overflow inside the machine running onto the countertop. Clean out the area behind the little drip hole and the hole itself. This should cure it.
Nov 16, 2007 | Saeco Vienna SuperAutomatica Coffee...
Water leaking from coffee dispenser
Hei dory may be this can be helpful.Inside the machine take out the brewing group on the back panel there is asmall metal piston with 2 small orange rubber o ring.Try to replace that(is not easy since the position)were the o ring are locate is very unconfortable but is something i believe you can do it.That one is the main connector between the inside and the conjunction with your brewing group.
Good Luck
Sep 09, 2007 | Saeco Incanto Classic Espresso Machine
Coffee Makers & Espresso Machines Logo
54 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
