Question about Garden
Suffolk Punch 35s not starting
Hello all - i purchased a second hand suffolk punch 35s petrol lawnmower a few months ago. - It's been a great mower though currently it's stopped working/firing over. thought maybe it was because i added old fuel - so i drained this out and put new petrol in - and still nothing. Its sparking so seems strange - I also cleaned out the carburettor but no success. - this wasn't the the best solution - but i took the spark plug out - put a thimble of petrol in where the spark plug goes - spark plug back in and pulled - and it worked and fired up for 5-7 seconds but then died out. Seems to be a fuel blockage? - but i've tried all avenues with no success or noticeable blockages - would appreciate and advice you could give an amateur Best regards Parkie.
    Problem Solver:
  • 28 Answers
Carburetor have a setting level for its fuel , check the floating control adjust fuel level , also check spark plug current is there,just by rotating engine and keeping spark plug out of cylinder , just keeping it with engine body.
Posted on Apr 12, 2014
  • 3 Answers
SOURCE: maintenace Manual for Suffolk Punch petrol-driven Lawnmower
Have you checked with the company that makes the mower for the manual? Hae you tried searching the internet to see if you find the manual there?
Posted on Dec 09, 2008
  • 110 Answers
SOURCE: i cannot start my Suffolk punch 43s petrol mower,
As far as I can tell, there are no downloads available. I eventually gave up and bought a copy from a mower museum. You will need to know the approximate age, as several diferrent engines have been fitted.
If you have the old red engine, the choke lever should be at right angles to the line of the carb IE pointing straight back.
The newer green engines are usually marked, but of not, remove the air filter and look into the carb throat. When the choke flap is CLOSED, the choke is ON IE cold start position.
As soon as the engie starts, move the choke to approx 50%, then fully open after 30 seconds or so.
If in good order, these engines are a 1-pull start. Fit a new plug, then spray WD-40 or similar into the OPEN carb thoat. If there is no sign of life at all, you have a coil failure (or possibly a points problem if it's ancient).
Posted on Oct 03, 2009
bobthebulldo
  • 67 Answers
SOURCE: Filled fuel tank on my Suffolk Punch 14S lawn
the float needle must be so the pointy end is pointing up into the carb and the other in the bowl
Posted on Oct 17, 2009
vincob
  • 718 Answers
SOURCE: MOUNTFIELD PETROL MOWER WONT RUN
If there is a float bowl on this model, takeoff the center screw and look for a little pilot hole on the side and take a small pin or the like and clean this pilot hole and try again to start. Good Luck Pal.
Posted on Jun 04, 2010
  • 250 Answers
SOURCE: I have a Suffolk Punch
Yes, that's all you need. At some time yours was cross-threaded, That means that it was forced on wrongly, and broke the thread.
Posted on Mar 24, 2011
How much oil in a Suffolk punch 35s
Geoff, Check the attached links, manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.oldlawnmowerclub.co.uk/sites/default/files/opmanual/Suffolk%20Punch.pdf
Suffolk Punch OWNERS MANUAL
Small engine repair How to drain and change the oil in small petrol engine
Jul 02, 2016 | Garden
I need to set up the dellorto carb on the 35s suffolk punch
Running only with full choke is a fuel problem. Unhook fuel line from carb. it should run good. If not go back the line. Check the fuel cap vent.
Mar 25, 2014 | Garden
Replacing Tap on Qualcast petrol tank
It should just screw out, there is a thread on the plastic fuel tap, they can be pretty tight.
Jun 09, 2013 | Garden
Replacement bottom blade for suffolk punchl lawn mower
Hi Keith,
You can find spares here:
http://www.espares.co.uk/search/lawnmowers/suffolk-punch/p/1116/2173
If you google suffolk + punch + spares you should be able to find more websites which supply blades.
Hope this helps!
May 30, 2011 | Garden
I have a Suffolk Punch 35s mower and the petrol cap leaks badly and won't stay on whilst mowing, do I need just a new cap to fix it?
Mar 24, 2011 | Garden
Qualcast Suffolk Punch 35s lawnmower running problems
There is a small idling mixture screw on the side of the carburettor.
As the engine is not well suited to the carb. it mainly runs on the idle setting!
As long as you are not leaving the choke on. This is a little tab on the top of the carb. You start with it set on C then soon set it on the middle position, and after about 3 mins turn it off.
Jul 12, 2010 | York Yankees Bedding MLB Comforter
Please advise on where to puchase replacement parts for old Qualcast punch classic 30s lawn mowers
Hi howardandjan, You call it "old Qualcast punch" if it's called Qualcast punch it's not that old, it was originally called Suffolk punch (after the horse) and came in 14" and 17" cuts, the 30s (30cm approx 12") was originally called suffolk colt. when Qualcast took over just about all the british cylinder mowers Atco,suffolk,webb etc they started swapping names about but you should be able to get parts from any good mower shop try winchester garden machinery in hampshire always found them helpful
Aug 30, 2009 | Garden
Maintenace Manual for Suffolk Punch petrol-driven Lawnmower
Sep 14, 2008 | Garden
Garden Logo
275 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
