Question about Garden
I have electric Ryobi lawnmower The mower just came to a halt and would not start again The connections seem okay Is there perhaps a fuse or something that may have gone
    Scholar:
  • 128 Answers
Most electric mowers have brushes in their motor , it is most likely they need replacing .
Posted on Apr 21, 2014
4 Suggested Answers
SOURCE: I have a problem with a Black and Decker electric
Hello blumph,
I can think of only one or two things that are causing your problems. It could either be approx. a $14.00 switch in the handle that has shorted out, or 2 bad brushes $1.75/ea.on the armature (motor). Both are fairly simple fixes with just a screwdriver and maybe pliers. You might also check and see if the power cord has been chafed or damaged and is shorting out.
See below for parts:
http://www.ereplacementparts.com/black-and-decker-mm575-electric-lawnhogtrade-mulching-mower-parts-c-4167_9514_9550.html
yurcarguyken@yahoo.com
Posted on Oct 07, 2009
autodidact66
  • 116 Answers
SOURCE: how do you store lawnmower for winter? do you
mix a fresh gallon of 89 octane with a fuel stabilizer. run for a few minutes. the battery will need a trickle charger.
Posted on Nov 06, 2010
  • 16 Answers
SOURCE: I Have a push mower
Sounds like the blade maybe bent, you should either try to straighten it out or replace
Posted on May 05, 2012
Ryobi troubleshooting
What model is your lawnmower and what wattage?
It Sounds like from what you have said it could well be the capacitor that bridges the on/off switch that needs replacing. These can sometimes be temperamental, and go open circuit, particulary if the mower has in the past overheated and the cut-out has been activated. They are quite easy to replace yourself and can be purchased on ebay.
Apr 12, 2014 | Garden
Lawnmower has no current to starter
In-line fuse may be flown.
Jun 15, 2012 | Troy Garden
Need manual for ryobi electric lawnmower model ry14110 48
I need the Manual for the RY14110A Lawn mower
Sep 12, 2010 | Garden
Clippings not going into catcher...dropping onto lawn
ck the outlet of the deck and any connection between the deck and bag for debis build up.
Sep 13, 2009 | Garden
Can i convert a 12v cordless black and decker mower to electric
I assume you mean convert it to corded, connected to the mains; cordless is electric as well.
It is possible but there are conversion losses as compared to using a 'native' AC corded mower motor.
It also depends on why you want to convert it. If you find the battery unit underpowered, adding a 12v power supply and cord will not solve that, it will just extend the run-time to continuous, assuming the motor does not overheat, as it is probably designed to match the battery run length for on/off cycle times.
You could consider trading, or selling yours and buying a corded mower.
Jun 28, 2009 | Black & Decker 19" Electric Lawnhog...
My lawnmower engine cuts out
I was having the exact same problem with my 6.5 hp Toro lawnmower with a Tecumseh engine. The engine would start up okay but after a few minutes of mowing, the mower would start missing and eventually shut down. I would pull and pull and pull on the starter rope, getting angry and frustrated and eventually going back in the house to let it cool down.
I looked up all kinds of information and I finally decided it was a bad coil (something about the resistance being low when the mower wasn't hot and then when it heated up the coil would conduct enough electricity to somehow make the engine shut down.)
I called a local shop and wanted to get an estimate on replacing the coil. I have no clue about engines so I dared not get into the guts of the mower myself. He told me to check the gas cap. HUH??????
He told me to make sure there wasn't a part missing out of it. I thought, what the heck would a gas cap have to do with the engine shutting down. Well, apparently there is a mechanism on these caps that prevents a vacuum from pulling on the fuel system and my gas cap indeed had a part missing. To verify this, I cut the grass for about 5 minutes. When it started to run rough, I took the gas cap off to allow pressure to escape from the gas tank and voila! it started to purr like a kitten.
So, I'm only out $4 for a new gas cap and I'm as good as new. Man I wish I was more mechanically inclined so I hope your problem is as easy to solve as this one.
Hope this helps!
Apr 12, 2009 | Garden
Lawnmower
There may be a thermal fuse fitted to the motor, sometimes they reset when they cool down. Sometimes they are a one shot fuse, when they blow the have to be replaced.
There may also be a reset switch on or inside the operating lever/switch.
Have you also checked the operating switch/lever for a bad connection or a wire come loose.
Mar 31, 2008 | Vacuums
MM875 electric lawnmower
check motor if armature are not broken & see if the rectifier not burnt. rectifier works from ac & convert it to dc to run the motor.
if you need diagram for parts see toolpartsdirect.com
Aug 27, 2007 | Black & Decker 19" Electric Lawnhog...
Garden Logo
119 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
