Question about Konica Minolta Office Equipment & Supplies
How do i get on service mode on konica minolta c284e i want to image stabalization process and do gradiation
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 7 Answers
Hi Lufuno,
MENU > Counter > STOP > 00 > STOP > 01
pass:9272 9272 9272 9272
Posted on Apr 23, 2014
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
Posted on Dec 20, 2007
Cogz
  • 1326 Answers
SOURCE: Minolta CSPro 3000 Copier/how to enter service mode
Press Stop - 0 - 0 - 1 or it maybe User Funciation then meter count - Stop - 0 - 0 -1 , it's been years since I worked on them
Posted on Feb 07, 2009
goalie39
  • 469 Answers
SOURCE: Clearing a service code ''C0400'' on a Minolta CS Pro 6001
C400 is exposure lamp fails to come on, on start up the main exposure lamp should come on and do a scan.
If the lamp is not detected by the sensor, then you get the code.
Restart the machine, watch for the exposure lamp. if it does not come on before the code occurs, then the lamp or thermal fuse is likely gone.
if the lamp comes on then the code, the AE sensor is likely gone.
Hope this is of some help.
Ed
Posted on May 11, 2009
  • 12 Answers
SOURCE: How do I get into service mode on a Konica Minolta
hi,
you can get in service mode by pressing: utility counter -> job details ( on lcd) -> stop -> 0 -> 0 -> stop -> 0 -> 1 .
Select "imaging process adjustment", then "graduation adjustment.
The copier prints a coloured sheet, you have to place it to the glass and the machine will read it.
Repeat sequenze 4/5 times. You have to make it in all three section " graduation mode" "resolution mode" and " i'm not remeber".
You can find clear information about graduation adjustment in a installation manual procedure.
Contact me, i can give you a pdf file.
Sorry for my bad english.
Bye.
Posted on May 15, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Service Call error C0F32 in Konica minolta copiers
Since you did not include the Model number I will suggest the following:
This code means pretty much the same on all Konica/Minolta machines.
The ATDC or automatic toner density control has experianced a problem. Have you run the copier out of toner by chance?
You can try resetting this code to see if it comes back. If it keeps coming back then you are going to need the process unit serviced. Or depending on the model you can replace the "Imaging Unit" yourself.
Posted on Oct 27, 2009
I forget service mode password in konica minolta bh 501 can you help me
There is only 3 service mode password the easiest way to find it try the 2 and the other 1 tomorrow so it will not lock. 1) 11111111 2) 00000000 the last 3) 12345678. You dont have to go to [Utility] ... etc its a long process w/c you can see the service mode password/ change.
Nov 23, 2014 | Konica Minolta Office Equipment & Supplies
How do I print a fax confirmation on a Konica Minolta c284E? i AM NOT GETTIKNG A CONFIRMATION PAGE WHEN i SEND FAXES
In your administrator settings you need to go to report settings and activate it to print TX reports. When the machine is standard then it will only print a report if the fax has failed to send.
Aug 26, 2014 | Konica Minolta Office Equipment & Supplies
Reset image unit (Magenta) Konica Minolta Bizhub C352
Change the chip or enter in service mode and change the imaging unit life duration to long life.The copier displayed continuosly Please change the image unit,press OK and ignore.
Feb 13, 2013 | Konica Minolta bizhub Office Equipment &...
WHERE IS THE SERVICE MODE ON MY CANON C 3200 IMAGE RUNNER. MY COLOR COPIES SEEM TO NOT BE ALIGNING CORRECTLY
just press ( * ) additional function then select adjustment & cleaning just find auto gradiation then select full gradiation the machine will print a test pattern
Nov 24, 2010 | Canon imageRUNNER C3200 Copier
C-0F32 FOR KONICA MINOLTA BIZHUB C350
Abnormally low toner density
detected Magenta ATDC Sensor
T/C 0.21 % or less is detected ten consecutive times
in the Developing Unit as validated through the toner
replenishing amount determination control.
Check Developer unit, check toner supply ratio in the service mode, under Image Process control and make sure that Toner motor is sping and adding toner into Dev. unit.
Also check and see if you have enough Developer. clean ATDC sensor and run Image Quality adjustment
Apr 13, 2010 | Konica Minolta Office Equipment & Supplies
KM7450 Vertical Lines in Magenta
I would replace the Magenta drum unit & developer unit
Jan 13, 2010 | Konica Minolta magicolor 7450 Magenta...
Oct 27, 2009 | Konica Minolta Office Equipment & Supplies
How do I get into service mode on a Konica Minolta Bizhub C250 copier and how do I adjust the color settings once I am in there?
hi,
Bye.
May 13, 2009 | Konica Minolta Office Equipment & Supplies
I have a Konica Minolta Bizhub c351 and all of a sudden it started printing everything with a pink hue and the colors are very uneven.
There is a long process to solve the problem I might suggest that you have to call for service. It might be the magenta developer unit might be bad or rich the max life that need to be replace. Or just plain adjustment on colors setting. It might need to update the firmware to the newest level.
Mar 27, 2009 | Konica Minolta bizhub C351 All-In-One...
1,185 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
