Question about Cell Phones
5215 deutz allis tractor. break down diagram pto shaft/ system how
Help! break down diagram/instruction for pto shaft and how to connect the splines from pto shaft to woods finish mower
EarthJam
  • 23 Answers
SOURCE: removal of rear wheel on cox stockman ride on mower
These wheels are usually just held on with a Key way, ALOT OF TIME they offer resistance because they are rusted insode the rim and are needing a mallet to hit them from the inside pretty hard.
Turn it as you can usually a lever on the back side of the mower can be pulled out without the brake on to slip the transmission into nuetral. Turn the tire. I have used a small peice of 2x4 as well because a hammer dont fit well. Good luck I will watch this post and search my Diagrams to see if i have this rider tmrw at work.!
Posted on Feb 03, 2009
c17hydro
  • 2984 Answers
SOURCE: JOHN DEERE 5300 TRACTOR 3 POINT LIFT ARMS NOT
Yep....I have worked hydraulic systems for 17 years....you have air in the system and it needs to be bleed.
Posted on Mar 25, 2009
  • 4 Answers
SOURCE: PTO switch shuts down tractor
if the pto bearing is locked up it will stop a motor dead this is a common problem. You will have to get a new clutch assemble. The other thing that it could be is the deck has a locked up spindle.
Posted on Aug 20, 2009
huffman49
  • 235 Answers
SOURCE: Riding mower stalls when PTO is engaged.
check the kill switch and the wire it could be that a small piece of the covering came off and is grounding to the deck or frame there by killing the engine the jerkink of the mower maybe whats causing the wire to come into contact with metal..good luck
Posted on Apr 03, 2010
miket756
  • 2702 Answers
SOURCE: engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
Posted on May 02, 2010
My 1976 allis Chalmers three point won't lift up and the PTO won't stay engaged. Everything on this tractor is run by hydraulic pumps. There are 3 pumps on this tractor. A piston pump, a gear pump, and a...
I would try checking the remote valves, maybe undo the line at each one and see where your pressure is stopped and maybe you can work down to where whitch with valve is not working..
Jan 29, 2015 | Garden
Remove clutch
I'm assuming you're referring to the PTO clutch on the bottom of the engine shaft. There's a 5/8" bolt that goes up through the clutch into the shaft. Remove it, but then turn it back in about 10 turns and use a wheel puller to start getting it off. You might have to c-clamp the PTO/clutch top and bottom together to get both pieces off. Once the assembly starts coming down the shaft, you can probably remove the wheel puller, remove the bolt completely, and pull the PTO/Clutch off by hand. Be sure to unplug the PTO/clutch before removing it. Also, many of these have a spacing washer on top of the PTO/Clutch that comes off in the process. BE SURE to put it back on before replacing the PTO/Clutch. DO NOT hit anything with a hammer to try to break it loose - you'll most likely NOT get the part off and most probably WILL damage necessary parts.
Jul 29, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
My Allis Chalmers 6080 PTO will not shut off with the lever. Even though I pull the lever to stop PTO, it stays engaged. Any answer to this issue?
The lever is maybe not engageing the electrical switch so if it worked good in the past something has worn or come loose.Find the point where the lever engages the switch and there are usually 2 wires running to the pto.Also one or more wires might be off the pto.Go from one thing the lever does to the next step and it might be a bad switch if the lever is working the switch and it still does not turn off.Hope this helps
Nov 05, 2012 | RTO Allis Chalmers Tractor Pto Shaft...
Belt size for 616 deutz allis riding mower ,deck & drive
most wear parts numbers are on the bottom side of the hood.
Jul 29, 2012 | Garden
We are trying to hook up to the tractor a 466 john deere silage special to the tractor. My dad died and we are new at this
do you have the pto shaft connected? on some tractors the pto has a cover that has to be removed and a push pin that will allow the shaft to slip over the pto spline on the tractor then push it back to lock it on. if i can help my email is derrikhamby@yahoo.com
May 31, 2011 | Computers & Internet
Alis charmers 190 xt serisi 3 rear poser take off shaft Transmission fuild or oil going into the hydrolic side and overfilling
The seal between rear housing and the middle housing for the pto shaft needs to be replaced, if you continue to use it you will cause damage to the rear end due to lack of lubrication.
Nov 10, 2009 | Diesel Allis Chalmers 190xt Tractor...
Cell Phones Logo
37 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
