Question about GE Profile Spectra JGBP90 Gas Kitchen Range
The oven of GE Profile range simply stopped igniting
Burners work, clock, fan, etc. all work. Oven simply does not ignite after I set temp and press start. Graphic shows oven is on but no sound of ignition and temp stays at 100. No smell of gas. Isn't it a spark ignitor? It's an XL44 Self-Cleaning Gas Range--new in 1999.
Larry K.
  • 23 Answers
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Posted on Jun 20, 2009
Replaced fuse and blown bulb,grill works as does the fan but the oven does not ignite.
You don't give make/model/year etc but can you light the oven manually with a taper?
Did you have an owners book with it?
I take it the igniter works the top burners?
Feb 16, 2016 | Ovens
Oven & Broiler quit working on same day.
Yes, I think you have the answer. If you have the knowledge, check the electrical supply side, fuse etc. Check out your user manual in the fault finding section. The oven has a thermo switch that prevents the gas opening if theres no ignition.
Apr 17, 2015 | Kitchen Ranges
I have an LG electronic range it is on recall for the burners going on spontaneously, they have yet to fix this for me. Now the oven set buttons for both the regular and convection over will show and
Thats what is sounds like to me- or the keypad..... Anytime you have multiple malfunctions of of the control panel, it usually is one or the other. Hope this helps. Good luck, Dennis Wayne
May 08, 2014 | LG Electronics Range. 30 in. SeCleaning...
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
My jennair burners ,fan and oven light work but
Replace the clock first(electric control) then test the oven it could be that it's why the oven does not work.
Jan 13, 2010 | Jenn-Air JES9860 Electric Kitchen Range
Fan oven not working not heating up
If the fan is working o/k, then you need fit a new oven element located behind removeable rear cover in oven compartment.
Please rate my solution.
Thanks.
Nov 10, 2009 | Whirlpool AKZ159IX Oven
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
TOP BURNERS WORK BUT OVEN DOES NOT WORK AT ALL.
Sounds like a heating element. Same thing happend to my oven. You can find them around 50-60 dollars. Veryy easy to install, just remove a couple of screws and remove old element and put in new one. Make sure you shut off power to oven firstg of course.
Oct 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
466 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
