Question about Konica Minolta Office Equipment & Supplies
How do i get into service mode on a konica minolta c284e copier
  • Konica Minolta Master
  • 6,161 Answers
Mter count, stop 00 stop 01
Posted on Jan 10, 2016
Nitrotrike
  • 589 Answers
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Posted on Feb 10, 2008
jqsababa967
  • 145 Answers
SOURCE: konica minolta problem
How to reset an F34, F35, or F36 code.
Solution:
To clear the code, perform the following:
1. Turn the machine OFF.
2. Enter the 25 mode, (turn the machine ON, while pressing the 2 and 5 keys).
3. Select 1: Software Switch Setting.
4. Use the arrows on the LCD to select dipswitch 3-1.
5. Touch the OFF key on the LCD to change the data to 0.
6. Press RETURN.
7. Power the machine OFF/ON to exit the 25 mode.
PLEASE. NOTE;
THIS IS ONLY TO RESET THIS CODE ,IF IT CAN;T BE CLEARED THAN YOU NEED TO Replace the temperature sensor assembly
Posted on Dec 03, 2008
Cogz
  • 1326 Answers
SOURCE: Minolta CSPro 3000 Copier/how to enter service mode
Press Stop - 0 - 0 - 1 or it maybe User Funciation then meter count - Stop - 0 - 0 -1 , it's been years since I worked on them
Posted on Feb 07, 2009
Kevin Hayes
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
jqsababa967
  • 145 Answers
SOURCE: C-D370 error code for Copier KONICA-MINOLTA C252
this has to do with what they call NAVRAM IS C
To troubleshoot the error:
1. Reset the code by pressing stop-0-7-1-3-9. This will display a "*" on the LCD. Press this button.
2. Perform a Data Clear and then perform the Setup Procedures from the beginning.
3. Perform a NVRAM Recovery Procedure. Please see attached document. To view the PDF, Adobe Reader® must be installed. Adobe Reader® can be downloaded for free from RRUPTED/need to be reset BUT that will clear all the current setting especially if print to it.if you are willing to try ....
you should have a Tech do this...
good luck
Posted on Sep 20, 2009
How i change the developper of konica di5510 plus the code of it
I would recommended you get a konicaminolta tech to that it not simple in will require developer, knowing the service mode 36. Clearing counters in mode 25. Try a web site that sell the old Konica Minolta service manual. follow step by step.
Feb 04, 2015 | Konica Minolta Minolta Dialta Di5510 Laser...
Konica minolta reset password or what is the Master password
Sir what model depends is it Minolta, Konica, or KonicaMinolta. Want admin PW or service Mode?
Dec 10, 2014 | Konica Minolta 7222 Digital Copier Toner...
How do I print a fax confirmation on a Konica Minolta c284E? i AM NOT GETTIKNG A CONFIRMATION PAGE WHEN i SEND FAXES
In your administrator settings you need to go to report settings and activate it to print TX reports. When the machine is standard then it will only print a report if the fax has failed to send.
Aug 26, 2014 | Konica Minolta Office Equipment & Supplies
How can i enter the service mode for konica minolta bizhurb 250/350 black an white copier and how to adjust ATDC and to run f8?
To enter service: utility/counter, counter details, stop, 0, stop, 0, 1, then 00000000. F8 is found under functions menu. ATDC is run by F8.
Aug 11, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
What is the server address for bizhub c284e
Enter in printer setting and select configuration page and START.
Aug 03, 2014 | Konica Minolta bizhub Office Equipment &...
Size/media error printing
Paper size error what is the weight of the paper and size???
May 20, 2014 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub c451 service mode password reset
Hello there if u enter the service mode and it shows and password it means that the user or the service before has activated the CE password that means that you can enter if you do not know the password. Either way you have to try to enter the default CE password that is 92729272 or 00000000 or 123456789 the first one if not change should open acess to the service mode if not you have to call the konica minolta for NVRAM reset procedure there is no other alternative.
Mar 14, 2014 | Konica Minolta Office Equipment & Supplies
63 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
