Question about Water Tech Pool Buster Pool Cleaner
Starting my pool for the first time after winter
My return jet is sucking in water when I turn my filter on no idea why.
Water is just shooting out the top of my filter.
  • james aurienne May 11, 2010
    are hoses hooked backwards
    President:
  • Water Tech Master
  • 1,378 Answers
Sounds like your hoses are all mixed up on your filter. The filter valve should have labels telling where the hose from the pump to the filter goes, then the filter to the pool.
Posted on Jun 18, 2009
What setting do I putmy pump on to vacuum sand out of my pool. I have the sandman 22"?
I'm not familiar with that particular brand, but if you want to get sand out of your pool you should first make sure you're ready to vacuum (with the plate firmly in the skimmer box and connected to your hose and then to your pole with the vacuum head), then turn the multi-port valve (MPV) to 'waste'. If your equipment is below the water line then water may start to come out your waste line - not a drama. Next, just turn the pump on and you will be vacuuming sand straight through the pump and out to wherever your waste line goes.
Be careful to ensure that you don't let the waterline in the pool get below the level of the skimmer box, because if you start to suck air you increase the likelihood of damaging your pump. A good idea is to top up the pool as much as you can with a hose before you start vacuuming, and then top it up again as necessary as your going along.
If you do need to top up the pool, be sure to get your water tested as soon as you can afterward, then top it up with whatever chemicals you may need.
Sep 19, 2014 | Blue Wave Sandman Above Ground Sand Filter...
Return port of the intex pump is sucking in water at the top part of the nozzle
If the debris that is getting pulled in is floating, lower the inlet to about 3 to 6 inches under the surface of the water.
Mar 17, 2014 | Intex Above Ground Pool 12x30"" Easy Set...
Sticker wore off on the filter. which button backwashes? the pool is about to overflow.
b> VALVE SETTING FUNCTIONS OF VALVE POSITIONS FLOW DIRECTION THROUGH VALVE FILTER PUMP - TOP - THROUGH FILTER - BOTTOM - RETURN For normal filtration and vacuuming pool through filter. BACKWASH b> PUMP - BOTTOM - THROUGH FILTER - TOP - WASTE For reversing flow for cleaning filter. RINSE b> PUMP - TOP - THROUGH FILTER - BOTTOM - WASTE For initial start-up cleaning, plus resetting filter bed after backwashing. WASTE b> PUMP - WASTE For vacuuming directly to waste, lowering pool level/draining pool. CLOSED b> NO CIRCULATION PAST PUMP PORT For shutting off all flow to filter and pool. RECIRCULATE b> PUMP - RETURN For bypassing filter, but circulating pool water. May be plumbed for "off-system" pool water access. Ideal for Jet-Air® fittings. WINTER b> VALVE NOT IN USE
Ifthis answer does not fix your problem, please comment with additional detailsprior to rating the answer. Positive feedback is appreciated once your problemis solved! Thank you.
Aug 28, 2011 | Hayward SAND FILTER, PRO SERIES
I just cleaned out my Pentair FSN filter as I hve done several times before. I replaced the internal air bleed assembly from the factory piece (broken filter piece) to one with a screen from the pool...
it sounds like your valving for the return water is set wrong. check to make sure that some water will return to the spa when the pool is running. It's a valving problem more than it is a filter problem.
Aug 23, 2010 | Pentair Fns Plus 48 sqft De Pool Filter...
My swimming pool filter returns dirty water to the
Might you have a broken lateral in the bottom of your filter and what you are seeing is sand coming into the pool?
Do you backwash daily or more often? (You should) Do you have a multi-port vavle or other type?
Im thinking broken lateral. Sucking air in and of itself will not cause dirt to return to the pool.
Whats a lateral? There is a series of pipes in the bottom of the sand with small holes in them. These holes allow water to travel in and out depending on whether you are filtering or back washing ... but not sand. If you have sand, you have a broken pipe.
Open the filter and remove the sand into a bucket to inspect the laterals.
I hope this works for you.
a
Oct 18, 2009 | Hayward SAND FILTER, PRO SERIES
No pressure on gauge,pool is filtering but on off,cell tube fills up with water then emptys then fills up again
you aren't getting a good suction. Try placing your hand over the jet or jets going into your pool as to build up the pressure once again. Gradually allow the water to flow out of the jet(s) as you feel the pressure building up again. As of current you pump is just allowing the water to flow right through instead of sucking with force and pumping with force. No issues with filter or pump. Just need to restore proper suction/pumping
Oct 11, 2009 | Pool & Spa
Air in filter on hayward above ground pool.
I had similar situation.try removing winterizing plug,wrap with teflon tape, make sure no debris on threads. This worked for me. Tony
Apr 28, 2009 | Pool & Spa
Water Tech Pool Buster Pool Cleaner Logo
93 people viewed this question
Top Water Tech Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Water Tech Pool and Spa Expert? Answer questions, earn points and help others
