Question about Garden
My hitachi ex200-3 excavator has a problem. That it can function all activities but moving has been a problem it does not move. And all activities are done as in slow. How do I solve this problem??
Also the Control valve seems to be disturbed. How do I fix this all up?
  • Garden Master
  • 2,478 Answers
Looks like was disturbed. Can you screw valve a little? If that helps a little more. Do have pressure gauge on panel? What's it read?
Posted on Apr 16, 2014
2 Suggested Answers
alicantecoli
  • 22326 Answers
SOURCE: my excavator hitachi ex200-1 weak swing and when you swing then stop vibration begin on turn table when i stop to swing,and when i swing and lift cylinder raise,vibration on the turn table will contin
Not sure would need to have a good look ,but i suspect a safety valve isnt closing properly causing thumping within the hydraulic system which is the vibration you can feel,shouldnt cost a lot to repair providing the faulty valve can be located so return to the dealer as they will have a good idea as yours isnt the first to go wrong iam sure
Posted on Sep 24, 2012
If 75 landy Hitachi track hole. My swing motor,manifold union center is leaking. I would like to know how to fix it myself. Or how much it would cost to have someone to fix for me.
Hitachi Deere Excavator Center Joint / Rotary Manifold ...
? 10:00
https://www.youtube.com/watch?v=Vsd_Os6WFCw
Mar 12, 2013 - Uploaded by woodieswood
Hitachi Deere Excavator Center Joint / Rotary Manifold Rebuild ... my Hitachi landy swing brake keeps ...
Viewing a thread - Hitachi Excavator- Swing motor gearbox leak ...
talk.newagtalk.com/forums/thread-view.asp?tid=362837...flat...1
Jan 30, 2013 - 3 posts - ‎3 authors
Hitachi Excavator- Swing motor gearbox leak ... 10000 hrs that I am thinking the seal on the swing motor reduction gearbox went out. ... but a friend that works on construction equipment said to check the swivel manifold.
Dec 08, 2015 | Cars & Trucks
How do i go about finding a service manaul for my Hitachi EX60Mini Excavator? I was told it was a grey market machine by the dealer.
go DownloadAManual.net and there is a manual listed for hitachi ex60-3 excavator service manual download
The dealer may be saying that it is a japan machine made under licence in china and is not covered by the hitachi warranty properly and because of that dealers are reluctant to work on them as they are considered inferior product
Oct 13, 2015 | Hitachi Televison & Video
Is there an adjustment to increase hydraulic power on Komatsu pc35mr-2 mini excavator? Or is there a sensor that is responsible for relationship between engine rpm and hydraulic operation?
you assumption is right
the pump is operating at idle as at full rpms and is controlled by pressure relief valves
When demand for pressure is low the valves will be partially opened and will operate when the pressure is reduced ( ram valve is moved)
Higher rpms maintain the pressure for faster ram operation
I would suggest that you have the system pressure tested by a service centre as it could be a malfunctioning valve (solenoid) or a failing pump
Mar 28, 2015 | Mini Cars & Trucks
Hitachi excavator ex120 diagram
Check pressure from pump. check oil level in reservoir check for air in system. check for broken ram piston seals or scored bore in cyl allowing oil to bypass the ram
Aug 24, 2013 | Cars & Trucks
My excavator hitachi ex200-1 weak swing and when you swing then stop vibration begin on turn table when i stop to swing,and when i swing and lift cylinder raise,vibration on the turn table will contin
Sep 24, 2012 | Cars & Trucks
Hdmi ports not working
You may have to activate that imput through your menu.Alot of plasmas have the ability to mute imputs.
5 Hdmi ports
Port one, cable box
port two, blue ray player
port three, Boxee box
port four, XBox 360
For example
Aug 07, 2012 | Hitachi 55HDT79 55 in. Plasma HDTV
Hitachi UHO 25 excavator is giving a problem. What happens is that the machine starts and the track moves but suddenly locks one side. I have changed the centre joint kit and serviced both track motors but...
I have the same problemon my UH025-7 after a year of troubleshooting we finally found it to be the hydraulic pump itself. This pump is a multi stage pump with one part of the pump operating one track and another part of the pump operating the opposing track. Track would start to go then drop dead. If I eased the levers forward it would move a little before one track would drop dead again. My problem is finding a pump. Al Drewett toledofiberglass@bellsouth.net
Jul 12, 2011 | Kitchen Ranges
Hitachi 65xwx20b
hello. yes you might check the cord . ? or your outlet that your pluging in to,might not work.? check them. ok hope this help's you."GOOD LUCK"
May 03, 2008 | Hitachi 50UX58B 50" Rear Projection...
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
