Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Wiring in powerforce turbo vac
Wire came loose from motor
    Problem Solver:
  • 7 Answers
If you want to save some money, doing it yourself is always the best way. Now I'm not sure how you would get to the motor on this vacuum, but just start from the most convenient point to take it apart and either take pictures after each part removal or write it down so you know exactly how everything came off in order to put it back on correctly. If it is just a loose wire, it should be fixed with some electrical tape to hold it in place?
Posted on May 11, 2014
3 Suggested Answers
  • 31 Answers
SOURCE: Powerforce bagless turbo roars and has poor suction
You would think they would come with some kind of Warranty!!!! ~ Most of the Time the Motors are Fine, And they just need new bearings!, As its easier to replace the Whole motor unit then Fix whats broke!
Posted on Jul 07, 2009
Wins411
  • 166 Answers
SOURCE: I have a Bissell Turbo - Powerforce Model #6585C - I want to know
First go here:
http://www.bissell.com/searchresults.aspx?searchtext=9500&mode=userguides
This is the PDF of the user guide. Start on page 18 and 19 and this shows how to change the belts.
Posted on May 03, 2010
My upright bissell powerforce bagless motor has blown
Did you contact Bissell Consumer Care? 1-800-237-7691
Sep 07, 2015 | Bissell Vacuums
Cant find reset button
Hey Troy, the PowerForce Turbo Helix doesn't have a reset button. You may want to have a Qualified Technician at at BISSELL Authorized Service Center inspect your vacuum.
Here's a quick link to assist you in locating one in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 28, 2013 | Bissell PowerForce Turbo Helix Bagless...
First go here:
May 03, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have two Electrolux Central Vacs. One is not working. Is there a reset button
If this is a CENTRALUX metal bodied 1590 series vac vac there is a reset breaker on the side of the motor housing of the vac. Depending on the age of the vac there is also a filter lockout switch . If you are using a cartridge filter and it is misaligned and drops down the switch will shut the vac off to prevent motor damage. Check those two items. The internal filter must be fully inserted so its twist lock/washer device can rotate holding it up in place. Then take a pair of insulated pliers and short across the low voltage terminals where the wiring system enters the top of the vac . If the vac starts, it is fine. If not your problem lies in the motor , the relay or the filter lockout switch.
If you have a plastic bodied Electrolux, a recent model the test procedure is the same but there is not the same lockout for the filter
Next test the nearest inlet in the house. If it fails to start you have a break in your internal wiring, possibly at a connection or a an inlet which may have a loose wire connection behind the wall. Post back with your results and if you have more questions. If so post the model #
Oct 28, 2009 | Electrolux Central Vacuum
Jul 07, 2009 | Bissell 6594 PowerForce Bagless Upright...
? light come on no power
you motor might be broken
this is the only thing i can think of unless your motor is not getting power
this could be a loose wire
if the light is comming on then the unit its self has power
hope this helps:-)
ricko
Dec 26, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Shuts off after a few minutes
Could be a bad wire, but most likely a motor going bad. If motor you would look at about $90 just for the part.
May 20, 2008 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Shop Vac just stopped
If you remove the motor, you will see that the wires that go from the switch to the brushes. On one side there is one wire connected directly to the brush. On the other side the wire goes to a plastic plug with a second wire going to the brush. This is probably where the problem is. This is a fusible link and it has most likely melted creating an open in the circuit. I put a piece of solder where the link was and the motor ran BUT the brushed arced like a sparkler. Upon further examination the brushes were crumbling apart. I have been unable to find replacement brushes.
This machine has a five year warranty. I called Shop Vac Customer Service 1-888-822-4644 and they sent me a new motor.
I had a Shop Vac QL50EIC which had exactly the same problem but the warranty was expired so that I had to buy another motor for about $50.
Mar 08, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Vac quit working
I have a Bissell powerforce bagless 12 ampsthe brush will not turn, motor is working not sure if brush is gone or I need a new belt it shows spots of burns like the brush is jamed
Feb 23, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
23 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
