Question about Jacuzzi Home
I have replaced 3 flappers on one of the toilets. After about 6-8 months it will run for a couple seconds and cut off. it does this often. Since I bought 2 at the same time and the other has not had any problems, I think there is some minor defect on the one. any suggestions
    Sergeant:
  • 230 Answers
There is a very good chance there was a factory defect. Either the exit hole is misshaped or there may be a small sharp edge that could be eating up the flappers. I would contact the manufacturer telling them about your problem and see if they will replace the tank or just buy a bunch of flappers wholesale and change them when needed.
good luck
Posted on Apr 19, 2014
  • Gene Kukuk
    Gene Kukuk Apr 19, 2014
    I have checked the rim the flapper sits on. I feel or see nothing. As I look at the flappers there is really nothing of any note I can find. I am going to replace the Tube and tank bolts and gaskets. Just find it silly that I have 2 installed the same day and the other I have done NOTHING to. Who would have thunk it!
    New Friend:
    Problem Solver:
  • 18 Answers
Do not bend anything, depending on type of ballcock, there are flat head screws on top to adjust or a clip on a lever to slide up or down to adjust
Posted on Jun 22, 2014
pranaclimbin
  • 50 Answers
SOURCE: my toto toilet keeps running
if its a metal arm connecting the ballcock shut off valve to the float flush it and bend the metal so the float is lower. if u can adjust the ball **** lower then do so. the shut off is not shutting off cause the float isnt going high enough. and the excess is going down the overflow.
Posted on Dec 04, 2008
kachbibi1
  • 979 Answers
SOURCE: Toto Dartmouth toilet flapper/chain design flaw
Your right this is a poor design. Space was the main reason for this and functionality was sacrificed. However, you can get a replacement rod at a major plumbing store. You could rig it by attaching a stem to the valve assembly. Allow the chain or rubber piece to slide over it. It is kind of like putting a permanent finger in the path of the chain to give it a "direct" lift up. This would then force the chain to go up instead of at an angle.
Posted on Jan 28, 2009
  • 659 Answers
SOURCE: Toto toilet Power Gravity intermittently running
Did you replace the flapper with a genuine Toto replacement flapper? If you didn't, they are slightly different. Toto toilets are fantastic but you do need to use OEM parts for repair.
Posted on Mar 19, 2009
phmaddnes
  • 24 Answers
SOURCE: Running toilet
Mine does that also, here's what I found.; I am on a well and occasionaly sand gets caught in the valve thingy... Take the tank lid off, turn the arm that attaches to the float assy. 1/4 turn towards the back of the tank and take it out. Rinse off the gasket and pin as well as inside the hole. Reassemble and it should solve your problem.
Posted on Jul 04, 2009
  • 3600 Answers
SOURCE: Toto fill valve continual problem, new toilet
There are cheep fill valves and ther better built fill valves, so make sure you buy aa quality fill valve. Also buy a pressuer gauge at ahard ware store and check water pressure level at a faucet outlet. Screw gauge onto water fauct leave a little room for air to escape when water is drippng out tighten the hose bib on the gage turn on the faucet and read the pressure. If it's more than 50 PSI you need to lower the water pressuer. I need to know if your on a, on site underground well,or are on city water to tell you what you need to do to to fix this problem. If there is one. thanks for using Fix-ya if you want more info post here.
Avid101
Posted on Aug 24, 2009
Ive replaced 3 toilet fill valve with 440a Fluid master fill valves height is good water level good.After a while it sounds like there is leak by from all toilet.Flappers have been replaced. What coul
check the overflow pipe in the cistern tank as some fill valves do not stop completely but allow input of water after the noise has stopped. This allows the water level to rise up and the water to flow out into the toilet bowl. Reduce the water level height by adjusting the cut off level and when the water rises past the new level the increase pressure on the valve will shut it off.
Sep 16, 2014 | Fluidmaster 400A Toilet Tank Repair Fill...
Air in water pipes
Check the toilet flapper, if the toilet is running it is because the flapper is not sealing properly. Change the flapper or entire flush valve.
Mar 10, 2014 | Plumbing
The water in the tank continues to leak out and the tank has to continue to refill. I have replaced the flapper, I have taken the tank off the toilet and check gasket alignment. The tank does not leak...
There are only a coulple of places that the toilet could leak or, overflow and give you this problem. When you replaced the flapper valve, did it have an extra piece of rugger on it? Universal flappers have a round piece on them that are designed to fit over the overflow tube. If you flapper had this piece and you don't have need for it, you need to cut that out, if the flapper "hooks" to the overflow assembly. Leaving that piec on can contort the shape of the flapper and make it so it won't seal. If you are noticing constant movement(slight swirl) in the bowl, make sure the back tank is not constantly overflowing into overflow tube. If this is the case, your water level is too high. You will either need to adjust the water level and/or replace the fill valve. If you can hear the toilet running or leaking, push down on the flapper, if it stops, you have a problem with the flapper and/or the chain adjustment. When you install the flapper, you have ton make sure the chain is long enough to let the flapper fall and seal but, not so long that it can tangle or get between the the flapper and it's seal below it.
Jun 19, 2011 | Jacuzzi Home
The chain in my tto toilet came off of the pink flapper. how do i repair this and will it hold
The flapper assembly alone can be replaced. Turn off the water supply to the toilet and manually lift and remove the flapper from the fill tube - if you have to cut it, that's ok. Inspect the lip the flapper sits on, looking for chips or flaws that make that surface uneven.Go to your local hardware store - they have a large variety of replacement flappers from just a couple of dollars to pricier versions. Matching flapper color is not important - design and style is! Your fill tube probably has ears on the sides - you'll want to make sure you get an eared replacement. Usually the replacement flapper will have "extra " parts cast into the rubber for multiple applications, and these can be removed with scissors or a razor knife. Follow instructions provided with the flapper and know you just saved a healthy amount of cash over a service call!
Nov 10, 2010 | Toto Home
I bought a toilet from homedepot in toronto 6 months ago. from yesterday, it keeps to refill the tank like every 10 seconds. but i can not see where the water leaks
There are a few likely causes for a toilet to leak and refill. The most common is the flapper not seating properly. Usualy on an American Standard it is a disc. Either way, they are fairly easy to replace. One test I use to see if the leak is comming from the flush assembly is to put a couple drops of food coloring in the tank and wait a few minutes to see if it appears in the bowl. If so, there is a leak in the flush assembly, usualy the flapper. Hope this heps. Please vote to let me know.
May 12, 2010 | American Standard 2860.334 Enfield Two...
Runs for 6 seconds every 35 min. flap replaced.
Sounds like your flapper or flush gasket may need to be replaced. An easy way to check this is , the next time you hear it kick on, wait for it to stop and put a couple drops of food coloring in the tank and wait about twenty minutes and see if there is any color in the bowl. If there is then replace the worn flapper or washer. Hope this helps.
May 09, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
Installed cadet 3 and every twenty minutes it will run for about three seconds and i know it isn't supposed to do that
EITHER THE FLAPPER IS NOT PROPERLY ADJUSTED OR YOU WILL NEED A NEW FLAPPER. WATER IS SLOWLY LEAKING BETWEEN FLAPPER AND SEAT. AS WATER LEVEL DROPS ,TOILET WILL RUN TO BRING WATER LEVEL BACK TO PROPER HEIGHT.
Jan 06, 2010 | American Standard Cadet 3 Right Height...
Kohler two peice toilet the water just circles and will not flush.there is plenty of water in holding tank that run through
These models need to have a flush valve flapper that has a styrofoam float on the lift chaninof the flapper. Go to hardware store or home improvement store and get a 'Korky brand toilet tank flapper with float 'ball". Cut the rubber ring piece away from the flapper and you don't need it (see cut here marks on flapper). Install flapper and adjust the float fairly close to the flapper.
When the water level drops in the tank and reaches the level of the float on the opne flapper, the flapper quickly closes causing the toilet to have a "surge" of siphon action which forces the water in the bowl to be drawn out.
Jun 29, 2009 | Kohler K-3422 - Wellworth Elongated...
Home Logo
82 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
