Question about Fujitsu Siemens Computers & Internet
Live chat pc assistance
Have a problem to install my graphic card on a motherbaord that has onbaord graphics, IRQ conflict problem, need to know hwo to configure. Main problem is "IRQ not configured - PCI in slot 02, Bus:01, device:00,function:01". Steps I did. Disbaled on board graphics>installed my plug in play graphic card and its drivers, ( note first boot after I plugged in graphic card that error message came up) Specs are here ( took screen shot with light shot:http://prntscr.com/399zs0)And here's another screen shot for the full detail about motherboard : http://prntscr.com/399zwn. thanks in advance
  • 1 more comment
  • Stijf Cassar
    Stijf Cassar Apr 12, 2014
    Oh btw I have already Tried the reset to default on bios and set the display adapter to PCI and still have this problem, Disabled Onboard graphcis both from device manager and bios too and problem still here.
  • IT aid
    IT aid Apr 12, 2014
    try disconnect all devices just leave graphic card and hdd and see what happend
  • Stijf Cassar
    But i think the problem is , it is conflicting with the IRQ of the onboard graphics i took screen shot of my bios setup , PNP configuration and their options :http://prntscr.com/383c1v , andhttp://prntscr.com/38cji4 , in screen shot 2 those options are avaible for all lines except lne2, I know i should do as you said disconnect devices and leave hdd and graphci card only but to be truthful pc is my cousins and he does not understasd much and neither i do when it comes at dismantling this stuff, so im trying to fix it for him like this
  • 320 Answers
Hi you should put your graphic card to slot 0 pcie. Switch your on card on and uninstall drivers. Put your graphic in correct slot and power up your machine and check if is detected by system, then install driver for it. If successful restart and disable on board card.
Posted on Apr 12, 2014
Testimonial: "yes my graphic is in there I think, Im not an expert but it can only fit in there ( the black slot ( this is my motherboard and that black slot is where it can only fit : http://prntscr.com/39ahqn)"
  • IT aid
    IT aid Apr 12, 2014
    did you try remove everything just leave memory, procesor, graphic card and see what happend. later add hdd
spare_head_2
  • 47 Answers
SOURCE: Resource Conflict - PCI Network Controller in Slot 02
Hi akwasi,
Try pressing F2 and look in the bios for a setting that says "Load Bios defaults". If you have any PCMCI cards inserted please remove them first and try a re-boot.
Have you added any new components on the PCI bus? If you have you need to make sure that the BIOS is allowed to reconfigure the interrupts. The device in slot 03 is conflicting with the integrated network controller hosted on the PCI bus. Remove the device in slot 3 and all should be well.
Most BIOS manufacturers allow the PC/Laptop to manage it's own interrupts, so ensure the device you've inserted allows for this. If it uses fixed interrupts this might be your problem.
A good manual should details the BIOS setting you can adjust in order to get the PCI controller happy again and allow the machine to POST correctly.
Regards,
Spare head 2
Posted on Jan 04, 2008
check for an update of bios on acer.com it will fix your laptop problem....
Posted on Apr 24, 2008
  • 1087 Answers
SOURCE: Al encender mi ACER Aspire
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
Posted on Aug 16, 2010
junk9
  • 150 Answers
SOURCE: when starting the laptop acer
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Posted on Sep 08, 2010
alien_x
  • 281 Answers
SOURCE: I have Acer Aspire 5101
you need to flash your bios with a new version try the laptop manufacture's site.
Posted on Nov 02, 2010
Fitting an external PCI graphics card ... issues.
Go into the device manager find the card you do not want to use then disable it do not delete it. Restart the computer making sure that your display is plugged in you want to use and it should show up. The way your doing it is allowing both monitors to or both drivers are active. John
Apr 16, 2012 | Acer Veriton M420 PC Desktop
No detect in my PC
>Check for physical connection of your graphics card, remove the case and see if it is perfectly fit it.
>Check for plug and play devices in services( Run>Services>Plug and play>Properties>See if it is started or enabled.
>Check for driver, incorrect driver could cause you the issue.
>Check in device manager if there is any IRQ conflict. If so, rollback the driver.
>If you have a system restore checkpoint, revert back to the previous settings. This might help you to solve the issue.
Does the above tips help you to solve the issue?
Regards
George
Jan 14, 2011 | Sigma ZDS VGA Video Controller 030249...
I need the Graphics drivers, after the installation I have the small screen resolution (4 bits) Thank
*Goto My Computer Properties> Hardware> Device manager> See if there is any conflict with the graphics drivers (?-wrong driver,!-IRQ conflict), if it does try driver rollback.
*Sytem Restore would be a prompt action. Since this is caused with installation of new software/s. A system restore would likely to solve the issue.
Please vote.
Jan 12, 2011 | Fujitsu Siemens SCENIC P300 PC Desktop
NOT BOOTING
i think you have got a conflict with irq's juss cahnge the port if you have got another one or change irq numbers in bios..............
Aug 05, 2009 | HP NVIDIA GeForce 8500GT,, PCI Express...
Monitor flickers sometimes when starting pc and won't come on.
if it is an older tube monitor - it seems it is at it's last breaths or the graphic adapter may be malfunctioning.
- please ensure all the cables( the internal ones, too) are attached properly,
-appropriate drivers fitting your OS are installed
- that there is no internal hardware conflict (IRQ conflict), please see: settings/hardware/device-manager for details
- try to hook up another monitor to double-check it is really the moni and not the graphics card!
if the issue occurs only in the original combinaton of old moni and PC, do consider to get a newer one.
another hint for an old moni is a slightly colour mismatch (maybe it has come to the red side?)
happy shopping
Aug 04, 2009 | Computers & Internet
Dumping phusical memory while playing fifa
windows seems to shut down while you're playing,
maybe due to an internal conflict.
(that is why it dumps...)
check for IRQ conflicts and if there is enough space available on drive c:!
if still have the prob only when playing FIFA 2009, check if computer meets minimum system requirements and the graphics card is functioning properly.
turn down ingame screen resolution.
still have the issue?
please come again providing more infos on PC system, win version and graphic/video card1
Aug 04, 2009 | Gigabyte GA-G41M-ES2L Motherboard
When reinstalling a x300 series box error message
just install the update x300 series software(v4.03.100.1 ) fom ncomputing website.
ed.
Apr 15, 2009 | NComputing X300 3 User Expansion Kit...
Dell laptop 8200 usb failed to work
go to dell web site and download the chipset update.
chance are the connection on the motherboard is bad or the chipset software is out of date.
if the software for the chipset can't fix the problem. the next alternative is to replace the mother board.
Mar 18, 2009 | Dell Inspiron 8200 ATI 64MB Video Card -...
Conflict with memory allocation
THAT IS A WINDOWS ALLACTIONS FILE AND YOU CANNOT CHANGE IT NOT WITHOUT REWRITTING THE WHOLE WINDOWS PROGRAM.
YOU MAY FIND THAT THE CPU MAYBE SHAING DMA CHANNEL OR IRQ WITH THE SAME ERROR
A BOOK I HAVE PUT A WORKING VIDEO CARD IN AND EVERY THING WORKS OKAY THAN THE PROBLEM IS NOT THE VIDEO CARD MORE LIKELY THE MOTHERBOARD DMA ERROR NOT YOUR VIDEO CARD
ROD
Jan 09, 2009 | Nvidia GeForce4 MX440SE 64MB SDR AGP with...
AGP slot
try a 3 way monitor vga switch 1 imput and 3 outputs to your monitors
Dec 14, 2007 | HP Pavilion Media Center TV m7360n...
Computers & Internet Logo
185 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
