Question about Uniden D1680-4 Standard Phone - Dect. Dect 6.0 Cid/itad Answering System & 4 Ha
I can't remove Silent Mode from the handset
I have 4 hand pieces, 2 work OK on the other 2 I can't remove Silent Mode. I followed the procedure from the manual.
How do I get out of silent mode on uniden dect 6.0
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1760om.pdf
1. With the phone in standby, press and hold # on any handset. The phone prompts you to select the number of hours (1 - 9 or Always On) that you want it to stay in silent mode.
2. To confirm, press # or just wait about 5 seconds. The phone turns on the answering system and displays Silent Mode On on each handset.
3. After the selected number of hours, the phone automatically exits silent mode. To exit silent mode manually, press and hold # again.
Feb 18, 2015 | Uniden Cordless Phone
How do I take the phone off silent mode
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660om.pdf
You can silence the ringers on all handsets for a specific period of time.
English - 10
2. To confirm, press # or just wait about 5 seconds. The phone displays Silent
Oct 28, 2014 | Uniden DECT 6.0 Cordless Phone ID
How do I turn off silent mode
Silent Mode
You can silence the ringers on all handsets for a specific period of time.English - 10
Sep 29, 2014 | Uniden DECT 6.0 Cordless Phone ID
Phone is on silent mode I dont know why or how to change please help
Hello there
You didn't give us the model number of your phone but go on the web and get the user manual for your phone.
From this ,manual http://www.manualslib.com/manual/184646/Uniden-Dect1560.html#product-1560-2%20-%20DECT%20Cordless%20Phone
I got.....
Silent Mode
You can silence the ringers on the base and all handsets for a specific
period of time; the answering system answers any incoming calls without playing anything through the speaker.
on any handset. The phone prompts you to select the number of hours ( 1 - 9 or Always On ) that you want it to stay in silent mode.
If the phone is in silent mode and you turn off the answering
system, the phone exits silent mode.
Sep 25, 2014 | Uniden Cordless Phone
GE cordless phone beeps in slient mode when someone calls
hi Mcbain,
try the hand set leave some time (30 min) by remooving battery.
try again.
let us inform the results.
regards.
nuwan
Jan 13, 2014 | Uniden DECT 6.0 Cordless Telephone...
How do i turn off the silent mode on a uniden phone, ive held down the # sign and nothings happening
Silent Mode
You can silence the ringers on the base and all handsets for a specific period of time; the answering system answers any incoming calls without playing anything through the speaker.
To confirm, press # or just wait about 5 seconds. The phone turns on the answering system and displays Silent Mode On on each handset.After the selected number of hours, the phone automatically exits silent mode. To exit silent mode manually, press and hold # again.
If the phone is in silent mode and you turn off the answering system, the phone exits silent mode.
Multihandset Features To use the features in this section, you need at least 2 handsets.
Your base supports a total of 12 cordless handsets: the one that came with the base and up to 11 DCX160 accessory handsets.You must register accessory handsets to the base before using them. (Handsets that came packaged with the base are already registered.)Handsets that aren't registered display a Not Registered message. For registration instructions, see p. 18, or see the accessory handset manual.If a handset was ever registered to a base, you must reset it before it can register to a new base; see p. 18, or see the accessory handset manual.Conference Calling
When an outside call comes in, two handsets can join in a conference call with the outside caller.
To join a call that's already in progress, just press Talk/flash or SpeSpeSpeaker.To leave the conference call, hang up normally; the other handset remains connected to the call.
Aug 18, 2011 | Uniden DECT 2080-5 Quint Phone
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
Jun 08, 2009 | Samsung SCH-U470 Juke Cellular Phone
Portable hand set will not hold charge longer than 10 minutes.
(Got this from a Panasonic Support Tech...Thanks Panasonic!) The following steps are worth a try.... Resetting Handsets & Base Unit: 1) Unplug AC adaptor from base unit for 30 seconds. 2) Reset handsets by removing/reinstalling all batteries.
Re-register each handset to the base unit by following the steps below:
1. Press MENU, #, 1, 3, 0 on the handset. 2. On the base unit, press and hold the LOCATOR button for 4 seconds until the registration tone sounds. 3. On the handset, press the soft key below OK and then wait until a long beep sounds. 4. Press the OFF button to exit. Situate the base unit in a different location. Change the line mode from A to B or vice-versa by following the steps below:
1. Press MENU on the handset. 2. Press #, 1, 2, 2. 3. Press the up or down arrow key to select the desired setting. 4. Press the soft key below SAVE. 5. Press the OFF button to exit. If the problems persist, your unit is malfunctioning and is in need of repair or replacement.
Mar 16, 2009 | Panasonic KX-TG5230M FHSS GigaRange...
Samsung d900
To place the handset in silent / vibrate mode follow the steps below: To place the handset in Silent Mode, hold down the pound key (#) for about 2 seconds. To exit Silent Mode, perform the same action while in Silent Mode. You will see a confirmation message for Silent Mode, each time you enter or exit Silent Mode. The phone will vibrate rather than ring when you receive a phone call, message or alert while in silent / vibrate mode.
Aug 23, 2007 | Samsung SGH-D900 Cellular Phone
Uniden D1680-4 Standard Phone - Dect. Dect 6.0 Cid/itad Answering System & 4 Ha Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
