Question about GE Monogram Side by Side Refrigerator
Remove fan and compressor from a GE monogram Refigeratof
I want to take the compressor and fan unit out to make it lighter to move
SOURCE: Ge Monogram ZISS420DMAS compressor and fan not running
ICE CREAM WON'T FREEZE
The ice cream does not freeze, it stays soft. I have a GE Monogram 42" Built-in-Side-by-Side Refrigerator.
Posted on Jun 18, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Compressor of built-in monogram burning up. Should it be?
Don't know who to believe these days. When the compressor won't start and over heats the start relay,start capacitor and external overload may be the most likely reason. The door frames have heat strips that is normal. Sea Breeze
Posted on Jul 23, 2009
arikrom
  • 528 Answers
SOURCE: GE Monogram side by side compressor runs loud -
check if it is the fan make that noise and not the compressor but if it is the compressor then you might need a new starter unit to the compressor
Posted on Jan 01, 2010
  • 58 Answers
SOURCE: where are the compressor fins on the GE monogram
there are no fins just a compressor with copper tubing and a fan in the back. there is a cardboard flap. just take it off and clean out to see in.
Posted on Feb 16, 2010
  • 35 Answers
SOURCE: 36" SxS not cooling
unplug it for five minutes... if it dosent come back on the pc board must be replace....
Posted on Apr 10, 2010
Ge monogram zfsb23d howls
Usually you will get a sort of whinning/screeching noise from the fans inside the fridge/frezzer when they are not working properly but you can also get that howling noise from the fan which cools the compressor for the fridge/frezzer which is usually found underneath the Unit. All you have to do is find exactly where the noise is coming from and remember unless you have a dog that likes to lock itself in the fridge for a joke then most noises that come from fridge/frezzers are only made from the moving mechanical parts and sometimes leaking refridgerants but not often.
Apr 03, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
Ge monogram compressor not turnign on
overview of a condenser unit on ge monodram and compressor replacement
Aug 04, 2013 | GE Monogram Side by Side Refrigerator
GE Monogram Ice Maker
Could you please describe the problem you are having a little better?
Nov 21, 2012 | GE Monogram ZDI15C Automatic Icemaker
Ge monogram zisw42emd, evap fan not coming on, Units been down a week, compressor seized,installed start kit. Compressor running 2.5 amps pressures 25/105 Replaced coil thermostats, evap fan not running.
that back pressures sound high to me and the hi side sound low may have a bad compressor not pumping right should run around 0 to 5 low 125 to 150 hi hope that helps
Oct 06, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Where are the compressor fins on the GE monogram side by side
here I replaced compressor on GE Monogram. U can see how machinery compartment made on Almost all models of Monograms. Thanks. Hope that helps.
Feb 16, 2010 | GE Monogram Side by Side Refrigerator
GE Monogram side by side compressor runs loud - sounds like rapid knocking. what can i do?
Jan 01, 2010 | GE Monogram Side by Side Refrigerator
GE Monogram freezer side working but refrigerator side is not.
Did you clean the condenser?  Is the unit FULLY defrosted?   Defrost fully!!!!!!
Did he check the amount of gas in the unit?  If your unit has low gas...it is in need of more.  R12 is expensive.
Check gas level:  Shut unit for at least one hour.  View compressor.  Several pipes...we're looking at the largest.  Start the unit.  This pipe will begin to frost.  If it does not clear to dry, ice or wet...stays frosted...it is low.  Get the repair guy back ... but ask how much he'll charge first.
Dec 12, 2008 | Refrigerators
Nov 28, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
GE monogram side by side built in refrigerator: fan behin Climate control drawer makes noise when it starts
IS THE NOISE SOMETHING HITTING THE FAN BLADE?
CHECK THE FAN ASSEMBLY BY REMOVING THE BACK PANEL IN THE FREEZER COMPARTMENT.
NORMAL NOISES IN THE UNIT ARE A GURGLING NOISE OR THE SOUND OF RUNNING WATER OR HISSING. THIS IS DUE TO THE FREON BEING PUSHED THROUGH THE SYSTEM AS THE COMPRESSOR RUNS. POPPING OR SNAPPING CAN OCCUR WHEN THE COILS IN THE FREEZER MOVE DUE TO A CHANGE OF TEMPERATURE.
Apr 08, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram Side by Side Refrigerator Logo
19 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
