Question about HP Compaq Presario PC Desktop
Computer wont let me close windows
My computer wont let me close windows it says " computer error
  • 1 more comment
  • rodrub73 Jun 17, 2009
    where do i get the diagnostic program
    okay
    there are many which do u recommend
  • 523 Answers
Run Diagnostic program to repair the files, you have corrupted files.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on Jun 17, 2009
  • Kyocera HP Expert Jun 17, 2009
    there is many companies has it, Norton or Microsoft, go to google and look for free one,
How do i get setup is starting services off and open windows
I found a solution for the same problem that fixed it for a few people. Try this:
1) On the same error screen press SHIFT+F10 and it will open up a black Window. (a command prompt window) 2) In the black windows type the word "regedit"(without the inverted commas and hit enter. That will open the registry editor. In the Registry Editor.. Browse to.... HKLocal machine/SYSTEM/SETUP/STATUS/ChildCompletion, and after highliting childcompletion,on the right hand side check for setup.exe. if the value is 1 change it to 3.(by double clicking on setup.exe and changing the value shown in the box). Then close the registry editor and then also close the black window. Then click on OK for the error and the computer will restart and the installation may complete. just try it and let me know if it worked.
I found this solution at http://www.tomshardware.com/forum/69394-35-acer-aspire-wont-setup-starting-services-help
Let me know if this helps,
Thanks!
Apr 05, 2013 | Acer Aspire Computers & Internet
My window 7 is wont boot
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it http://www.nextag.com/dvd-lens-cleaner/shop-html
Feb 27, 2013 | Computers & Internet
How to fix windows explorer error
Okay, try to install a free cleaning software called "Ccleaner". Use it to clean up your computer. You may have too many temporary files.
Also, try to defragment your hard drive. This may help.
Feb 01, 2012 | Acer Aspire One AOA150-1887 8.9-Inch...
How do I delete the error reporting to microsoft
if it is Showing ” Internet Explorer has encountered a problem and needs to close. We are sorry for the inconvenience ” Click “Don’t Send ” and everything get closed ,This Window error Report generated by microsoft is sometimes create problems for you , it is suggested you to dont ever click Send Error Reports or ” Please tell Microsoft about this problem ” because it will send all yours computer details to Microsoft , and creating problems for you.so its better to disable that error repor,so that such problem not arise in future,There are three methods to disable Microsoft error reporting.
  • To get rid of this MS Error Reporting, Right-click the My Computer icon on your desktop and choose Properties.
  • In the System Properties , go to the Advanced tab and click Error Reporting.
  • Select disable error reporting This will make any crashing program’s window simply close itself.
  • You could also click But Notify Me When Critical Errors Occur, but it might be even safer if you select Enable Error Reporting.
Inspite of this technique you can also disable error reporting via control panel as well as via editing registry . icon_smile.gif
Tags: Dont Send, Error Reports, Microsoft, Window Error
May 19, 2010 | Computers & Internet
Window pops up and says Printer card monitor is having problems
try to go to msconfig and try to disable the error reporting services and then you wont get the error while starting the computer and also disable the startup services for the printer
If is doesnot work log on to http://techbuddies.org
Jun 08, 2009 | Dell Computers & Internet
Itunes wont open
I would first try shutting down every process in Task Manager (hold down: Ctrl / Alt / Delete keys) that isn't necessary to run your computer. Next, if that didn't make it run properly, try installing iTunes while in safe mode. You'll have to consult your computer's instructions for entering safe mode. If that doesn't fix it, you may have to re-install Windows (I've assumed that you're running Windows).
Jan 22, 2009 | Apple iPhone Smartphone
Windows Explorer error after pressing Start -> Turn Off Computer!
Do you close down your applications first before shutting down? If not, give that a shot. If that fails try closing things down in the System Tray (icons by the clock). Try these things first and if that doesn't work, I have a few more things to try.
Jan 16, 2009 | Microsoft Windows XP Professional for PC
Remote Desktop Connection Not Connecting
The IP Address (local) may have changed. Go to the computer you are having problems connecting to, and into cmd.exe and type :
ipconfig /all
Then try that IP you get from ipconfig
Jan 04, 2009 | Computers & Internet
ERROR MESSAGE: "Checksum error."
The Checksum error usually indicates a data transmission issue. This may be due to a loose connection, bad wiring, electrical interference (cross-talk), a physical problem with the device itself, or a conflict caused by another software program. * Make sure that the cable attaching the camera to the computer is secure at both ends. * Close down all of the computer's other applications before attempting to download. 1. Press the CTRL, ALT and DELETE keys simultaneously. This will bring up the Close Program Window. 2. Highlight the program that you want to close and select END TASK. The Close Program window closes only one program at a time, so you will have to repeat these steps for each program that you want to close. NOTE: The SYSTRAY and EXPLORER programs should be allowed to run. Do not select End Task for these programs. You will also want to leave any necessary programs running, such as those controlling a wireless mouse or keyboard.
Sep 21, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
HP Compaq Presario PC Desktop Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
