Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Software update 191U1403041 froze at 67%. Cannot use remote or turn off TV. How do I continue software update?
TV frozen. How do I continue software update?
Why did it freeze during software update?
Here is some help on a Sharp Aquos. You pull the plug and update manually.
Sharp Aquos Firmware Update Issue and Resolution I recently had problems with my Sharp Aquos LC-60LE632U and firmware update 311U1204061. When I attempted to run the Netflix app, I was told that I couldn't proceed unless I updated the firmware. After 2 attempts to update the firmware via the network, I turned to Google and found that this was a common problem. In order to resolve the issue, you'll need to update the firmware manually, via a USB thumb drive. See the following instructions:
  1. Go to the Sharp USA product download site
  2. After you choose your TV model, download the firmware file
  3. View the rest of the instructions found here
Info found here
http://www.avsforum.com/forum/166-lcd-flat-panel-displays/1436990-sharp-aquos-frozen-when-updating-software.html
Oct 03, 2015 | Televison & Video
Phillips 42 inch television
It sounds like a short in the menu button, most likely the one on the TV itself (though it could be the remote). To rule out the remote, just remove the batteries from it and see if it still does it - it probably will.
Fortunately, this should not be too hard to fix. You'll need to remove the faceplate around the menu button, and then look at the wires. Somewhere between the button and the board those wires connect to, you should find a spot where two bare wires or connectors are close enough that they almost touch. It may be that the wires are stripped somewhere, or that one of the connectors is bent over towards the other. If it's stripped wire, wrap it in electrical tape. If it's a bent connector, bend it back (and possibly wrap it in electrical tape as well).
Either something's causing the wires to move just enough that they occasionally touch, shorting, and thus the TV registers it as the menu button being hit, or they are close enough that the power occasionally arcs from one to the other, with the same result. Separating and insulating them should do the trick.
-Dyllan
Dec 27, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Haier l32b1120 input source wont go off screen
Software is wrong update software from Haier offical site
Feb 26, 2015 | Haier HL32R 32 in. LCD TV
Help my vizio tv, model #e371va is stuck frozen? Help our VIZIO TV is stuck frozen?!My Vizio is froze on the setup screen and Ive tried everything to clear it.. Nor do i have the original remote any...
While the set is on, pull the power plug. Then hold and depress the power button in for about a minute. Then replug set and turn it back on. If that does not reset the tv then you do indeed have a serious issue with the set.
Apr 07, 2017 | Televison & Video
After updating software the playstation froze. Remote doesn't work and controller doesn't work. It is frozen on the accepting the update screen. What can I do?
  • Rank: Wiz
  • Rating: 83%, 121 Votes
http://support.xbox.com/support/en/us/nxe/contactus.aspx
Insert the link above in your browser and thats all you will need right there, they will have you get the serial number from your x box , that link is to the support page they have the phone number, email, and live support on there
Chris Thrash
B52Computers
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
I have a bosch logixx 8 washing machine. Fault code f67 when I turn the machine on. What does this mean?
I have Logixx8 WAS 32782 that got the f-67 code. I had it repaired today and the technichan updated the software. f-67 was indicating "lost contact with display panel". The display panel had of some reason erased its software. SW update was the standard solution.
Oct 02, 2010 | Bosch Washing Machines
Its frozen i cant turn off it says safe model?
Update the firmware:
- Launch the software.
- Connect the remote.
- Click "Downloads"
- Click "Firmware."
- Update the remote.
That will get the remote out of safe mode
May 23, 2010 | Logitech Harmony 550 Remote Control
My 659 is frozen with the following message on
I suggest starting the software and updating the settings...
1. Launch the Harmony software on your computer.
2. Click 'Update Remote'
Apr 09, 2010 | Logitech Harmony 659 LCD Remote Control
My remote is frozen on 'watch tv'' . device button, help button will not work. off button not working, initial screen to turn on devices does not appear. remote is fully charged
Hi, try updating the firmware in safe mode.
1. Remove the battery, press and hold the 'Off' button, and re-insert the battery. The screen will say 'safe mode'.
2. Connect to the software and click 'Downloads' at the top of the screen.
3. Click 'Firmware'.
4. Update the remote
Mar 20, 2010 | Logitech Harmony 890 Universal Remote
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
93 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
