How to open the door of a kelvinator kl75cm washmachine
Lock is on and can't open the door
  • 957 Answers
Try unplugging the unit for 30min. Sometimes this will reset the washer. My washer also has directions in the owners manual how to open when this happens.
Posted on Apr 13, 2014
3 Suggested Answers
  • 1214 Answers
SOURCE: whirlpool frountloader washmachine door locked
Has the washer finished it's cycle?
Reply and I will try to help more.
Posted on Jan 24, 2009
blueextc3221
  • 15935 Answers
SOURCE: f21 error on kenmore he2plus washmachine
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
Why is gas leaking from my kelvinator fridge
probably a hole in the evaporator
But I have to ask what is it you are seeing as the gas is not visible to the eye
is it a mist that you see on opening the door or has the compressor stopped working
Aug 22, 2015 | Kelvinator Refrigerators
How can i use kelvinator kl75cm when the catch is broken
According to the owner's / user's manual: try closing the door well; make sure there are no obstructions
Unplug the washer- and wait 1/2 hour; plug it back in; if you still get the error, unplug it and call the after-sales service center...
0860 234 481 (South Africa Customers0
+27-11-579-0800 (International Customers)
Mar 31, 2015 | Washing Machines
Electrolux EIFLSI5IIW1 stops at 1 min left in cycle
I have solved same problem with washer Electrolux EWS1066. All cycles stops after starts with 1 min left on display and open inlet water valve. I think that was bad door interlock but it was a defective main controller. No damage visible on board than I heated PCD with heater gun mainly pointed to SMD parts. Now washing machine work good.
Oct 14, 2014 | Washing Machines
How do I get my kelvinator stove's P 12 front door back
Without more information I can't be sure of your problem but I will make a guess that you removed the door without engaging the hinge locks. I am attaching a video that may help. All oven door hinges are not the same. Some require you to insert a screwdriver or pin in a hole to stop the hinge from retracting. My own oven door has retainers that snap onto the slot just above the hinge. When you remove the door these pieces are used to hold the hinge in the open position.
If the hinges are in the closed position you will have to figure out how to open them and hold them in the open position. Be Careful. The springs are very strong and can hurt you. I am including a link to a youtube video that may be the same as your oven door.
This free troubleshooting video shows step-by-step instructions on replacing the oven door hinge on Frigidaire, Electrolux, Gibson, Kelvinator, Tappan, and Kenmore gas ranges.
Door Hinge Replacement part 316456302 Frigidaire Gas Range Repair
Aug 15, 2014 | Kitchen Ranges
Wiring diagram for a Kelvinator DeVille eye level oven Model B305, Serial no 3674
Request the wiring diagram directly from Kelvinator.
Jun 25, 2014 | Ovens
F21 error on kenmore he2plus washmachine. Door locks. Due to no spinning and water remaining in the machine? I run the rinse/drain&spin program (15 minutes) several times. it stays at 15min remaining...
Mar 23, 2010 | Kenmore HE2 Plus Front Load Washer
Whirlpool frountloader washmachine door locked
Jan 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front load door will not open
replace door catch ass
or if you think you have it as good as new spray the lock with a little crc to lube
Dec 23, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
105 people viewed this question
Top Washing Machines Experts
