Question about Whirlpool Refrigerators
Warm temp. on door of refrig.
Food in door spoils, temp. 60 to 65. Controls on coldest.
    New Friend:
  • 12 Answers
The fan on your freezer may have given up thus the cold air inside the fridge doesn't circulate.
Posted on Apr 12, 2014
MNTECH
  • 1543 Answers
SOURCE: door can't close on lg refrigerator
As you look straight at the white plastic square: Make sure the edge of the gasket is in place along the outer (in your case, left side) of the door. There is a metal spring near the white plastic square, and the end of that needs to be tucked into the groove of the door, not showing on the outside. Then, line up the white plastic square with the corresponding hole and use the palm of your hand to pop the gasket in, starting closer to the center of the door and working to the WP square area. (should only take about three hits.) Then, line up and snap on the long white plastic gasket retainer strip which runs from top to bottom along the inner edge of the gasket.
Posted on Mar 15, 2009
SolutionGuy
  • 331 Answers
SOURCE: model# 596.58642891 freezer side thawed first and
I humbly disagree with Sea Breeze. We know the thermostat (cold control) is working because the fans are running and the compressor is hot to the touch. So we're getting power to the compressor. Now, only TWO things will keep the compressor from firing up when it has power supplied to it.
1.) A failed Starter. (that box connected to the left side of the compressor.)
2.) A failed compressor.
Then there are two things that'll take out the starter.
1.) Just a mechanical failure within the starter (blown ceramic disk). Note ---> You can normally tell if a starter is bad just by taking it off the compressor and shaking it. If it sounds like it has pebbles in it... it's bad. If it's solid, it's probably good.
2.) If the compressor locks up or fails, the starter is not far behind.
This Kenmore is made by Frigidaire. My experience with these is that 90% of the time, the compressor has locked up. You said you had access to the compressor... if it's made by Tecumseh (you'll see a blue Indian head logo on the sticker) I can almost guarantee it's failed. (Frigidaire is now putting Embraco compressors in their machines because Tecumseh was such a terrible one.)
All that to say this... you may decide that you want to replace the starter (if it's bad/rattling). If you do, go here and look at parts # 211 & 251 on the diagram... you'll need these. So, all-in-all, it'd cost around $20 plus shipping to replace the starter. If the new starter works? Great! You fell within the 10%... (almost like winning the lottery!) If the starter doesn't work, all you're out is the $20.
Good luck,
SG
Posted on Mar 28, 2009
SOURCE: Freezer wrk OK but temperature in the bottom fridge not cold
If you have a frost build up on the interior back wall of the freezer, you have a defrost issue. This would include a bad defrost control, bad heater or terminator.
If there is not a frost build up then you may have a bad evaporator fan motor.
Posted on Apr 28, 2009
  • 36 Answers
SOURCE: freezer stays cold but refrig does not
Hi there .... check if the fan that circulates the air from the freezer section to the refrigerator section is working or if it is ,is it spinning fast enough to throw the air across .....
Posted on May 23, 2009
Sea Breeze
  • 4654 Answers
SOURCE: How cold should the refrigerator be?
38 to 42 degrees F The problem with the defrost will need to be fixed and you can check a few things that may save you the cost of someone coming out. Unplug and remove the rear panel in back of the freezer. Defrost with a hair dryer and try to get as much ice out as possible so you can have a look at the defrost heater. Yours is made with a glass tube on the outside of the heating element and if burned out you need to replace both it and the defrost thermostat that it goes through. Hopefully you will try to use my assistance and we can resolve this quickly. Now if you do not see a problem with the defrost heater let me know. Your model has a mother control board and we may need to have a look at it also. Let me know, Thank You Sea Breeze
Posted on Aug 16, 2009
Food is starting to spoil more quickly than it should. The refrig temp on the door is set at 34 degrees which is the lowest it will go. The temp. on the refrig thermometer says it is 60 degrees. What...
You can get a small digital thermometer at your local hardware store for a pittance. ... For most refrigerators, this temperature coincides with the lowestsetting or one of the ... If your refrigerator is really full with items, lower the temperature a bit. ... they're not going to go bad because they were at 41degrees for a few hours.
Sep 12, 2013 | Samsung RF267AE (25.8 cu. ft.) Bottom...
I have a Whirlpool mod. ED5LHEXD00 refrig. I left home for 3 weeks in Dec. with the house temp. set to 50 deg. F. I got home and discovered that the refrig./freezer was at room temp and all the food had...
If Fridge working fine now, the problem may be is Hydro Grid.
When the fridge just start, the compressor is running with high pressure of Freon. If Hydro power has voltage surge or power Off/On ( suddenly ), the compressor should be stuck, the overheat protection switch will actived, than fridge will stop working.
The noice of "click" - properly is overheat switch auto-reset.
May 28, 2017 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Refrigerator section gets real warm, food spoils quickly but once I wiggle the control knob or just open the door and close it, it starts blowing cool air again. Why is it doing this?\r\nI was gone 7...
First of all thank you for all the information you posted, it helps greatly. Make sure your lights turn off when you close the door, very important. Next, I would suggest looking into a cold control, part number 2325701, if you have to tap on it, or rotate it to start running it maybe sticking and will cause the problems you have today. The link below is the part you need and you can order from this site or go to your local part house and get the part.
www.repairclinic.com/PartDetail/Temperature-Control/2325701/1408480
You can by-pass the cold control by using a jumper, be doing this you will turn the unit into a total freezer though. Be aware this will test you problem, but not cycle at temperature as design. Behind the cold control is a adaptive defrost board, this controls your defrost cycle and could also create the same problem. If the unit gets stuck in defrost, it does not advance like a timer, just when the thermostat opens inside the freezer.
To prevent confusion, I would by-pass the cold control, watch for freezing, if the unit runs with not problem for at least 6 hours, the cold control should solve your problem.
Good Luck
Aug 14, 2011 | Whirlpool W8RXEGMWQ (18 cu ft)...
I have a Kenmore side by side refrig. and the freezer side keeps getting full of frost, and the refrig. side is barely cold, and keeps spoiling food. I've had a tech come out and check things out and...
Either your defrost element or timer is bad or your fridge is low on freon. Frost is a sign of outside air getting in but it can also be a sign of the defrost heating element not kicking in and the defrost timer turns it on for a few minutes each day and a defrost limit keeps it from getting two warm during the defrost cycle. good luck hope this helps
Aug 17, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Have a Whirlpool Gold fridge manufactured in 2000 according to the sticker inside fridge. Same sticker says model# is GT22DA or GT22DC. Freezer is working fine. Fridge part is not keeping food cold and in...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 15, 2009 | Refrigerators
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Refrigerator does not get cold
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
Jun 14, 2009 | Frigidaire Freezers
A funny smell and i think it might be the temperature
Adjust the knob to 3 or 4 which would be the midway temperature.
0 would probably be off or close to it. The 7 would be coldest and freeze water.
If this is manual defrost you need to turn it off and defrost it. The frost will keep it from getting cold enough. The buildup is normal from humid warm air when opening the door. You might get a standalone fridge / freezer thermometer (about $5) to tell you what temperature is. The smell may be food spoiling from warm temperature.
Mar 20, 2009 | Danby DDW1805W Designer Series...
Whirlpool et8mtkx gets too cold, freezing
ok renato i believe in teaching so here is refrigeration 101 first the freezer does all the colling for the whole unit there is nothing in the refrigerator that cools its control runs a damper door like on a wood stove or fireplace at what we call the mid point setting the middle point the fridge should be about 35to40 degrees food starts spoiling at 42 the freezer should be about -8 to 2degrees the freezer has the only true thermostat that controls the compressor it has a cut in cut out temp and they are filled with freon like the unit and are subject to leaks at which time they malfunction now you can check the freezer for temp at mid point setting if its way below 8 degrees replace the freezer side thermostat which im betting is bad any way and not cutting out now blambnm email me at b4829@yahoo.com and we will talk ive never seen a whirl pool unit with out a freezer so you must be in another country im in the usa but we can fix yours too ill just need more info ok
Jun 05, 2008 | Whirlpool ET8MTKX Top Freezer Refrigerator
I have noticed that fridge seems to be running alot lately I did all routine maint. cleaning coils etc. and it still seems to be running alot. model number is afd2535dew top fridge french door. Is there an...
not really sure as far a swhatconstitutes ruining along time, you are doing the right thing by keeping it clean for sure, refrigs now run for as long as they need if it never stopped running youd see hte effects of that in 2 ways, either all your food would be FROZEN solid( cause it never shuts off), or your food would be spoiling quicker hat n usual, in which case your refrig is trying to run all the time to maintain temps! the noise that you hear running might just be the evap fan motor running( circulater fan, sure its gonna run to circulate, but the compressor wont be running all the time.. check and go by your dairy products, ice cream too hard or too soft, and in refrig check the milk and butter.youll never know how cold you leftover is but youll know right away if the milk it too warm
Mar 19, 2008 | Refrigerators
Refrigerators Logo
101 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
