Question about Chromo Inc NORIA JR. 8GB 7" Tablet PC. Android JellyBean 4.1. Dual Cameras, HDMI, 3200 mAh Battery, Dual Core 1.2 GHz CPU - Light Blue
Boot prob. wont boot past adroid logo what do i do also wont boot into recovery. Said system update was needed then rebooted and wont boot all the way now
  • Chromo Inc Master
  • 3,320 Answers
Posted on Apr 13, 2014
Proscan tablet stuck on android screen
The Issue
The problem usually presents itself like this: you boot up your tablet and the tablet reaches the Android logo and hangs there and never moves. If you attempt to restart or reset the tablet through the Android recovery mode that too does not help and the tablet is basically useless as it will not start-up.
Why is my tablet stuck on the Android Screen?
The issue is caused by a corrupted or none functioning Android operating system and the only way to get your device back to a functional state is to reflash the original firmware or a compatible version
Devices will no work
This will work on any Android tablet with the issue, however it works best with tablets that look like the Alldaymall A13 MID or the Irulu AK304 which we have tested this on and others, it's a simple matter of finding the correct fir
What will I need to fix this Issue?
You will need:
1. A MicroSD Card.
2. A means of connecting the MicroSD card to the PC/a MicroSD Card to USB converter
3. Your Tablets Firmware:
Alldaymall A13 MID Firmware:
Irulu AK304 Firmware:
4. Download thoenix Card
How to Fix your tablet that is Stuck on the Android Logo?
1. You will need to get the relevant items from the list above that includes the MicroSD card, the SDCard adapter,phoenix card tool and your appropriate firmware for your model tablet. show you what to do step by step
Sep 30, 2016 | Tablets & eReaders
Keeps rebooting
there are many reasons, why this happens, try this instead, if this will help. boot to recovery, depending on your tablet, for android, turn off your tablet, then while turned off, press volume up and power same time till you see your tablets logo, wait until it opens recovery, then select wipe data/factory reset. this will bring back the tablet to its original state or factory default settings, after a wipe, select reboot system, the tablet will turn on again, loading the settings like the first time you bought it, and see if that helps.
Sep 24, 2015 | Samsung Galaxy Tab Tablet PC
Wipe my data partition
you need to boot into recovery mode to wipe the data partition. Doing this will reset the phone's data partition. Doing this will delete all data off the device and return it to the same state it was in when you first powered it on.
  1. completely power off the phone
  2. press and hold the power, volume up, and home buttons until you see the Samsung logo
  3. use volume up/down to scroll and power to select
  4. scroll to and select wipe data/factory reset
  5. select yes on any following prompts
  6. reboot device
If the above process does not work on your device, see alternate methods to boot into recovery mode in the following link.
How to Boot Samsung Galaxy Devices into Download Recovery Mode
Oct 18, 2014 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
Wont load past android logo
Give it about 2-5 minutes , if that doesn't work try holding the power and volume button until it shows you a reboot option.
Mar 31, 2014 | Hannspree SN10T1 101 Tablet
Samsung tab 3 frozen on the on screen. code 10 fault code
Forcing a complete Reset works. This option keeps all your existing data.
  1. Hold Volume Down and Power button until presented with two icons (Open box and an arrow and an Adroid Doll)
  2. Select the left option.
  3. Volume down to toggle between options. Volume up to select.
  4. Will be presented with the Recovery Console.
  5. Select the first option "Reset"
  6. Here the volume buttons are used to navigate up and down and the power button to select.
After selecting the reset option your Galaxy tab will fully boot up again..
Feb 16, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
Help how do hard reset my proscan tablet plt7035 i for got my pattern to unlock it
1. Power the Tablet off.
2. Press and hold the Volume Down button of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
5. Navigate to Erase content.
All info on tablet will be deleted but not the info in the SD card
The tablet will complete the hard reset process and reboot into a factory default state.
Oct 19, 2013 | Proscan Recertified - PLT7035 4GB NAND...
My galaxy tab 2 7.0 wont reboot. when I shut it off and turn it back on it wont go past the samsung logo. I have tried to plug it in, it shows the battery icon and its full. I hold the power button down...
At frist turn off your smart tab&then press [(Volume+)+home key] on that time you have to press power key again and again.then you get cwm recovery.then select update from sdcard by using vol - key and click it by using home key.then select your zip file which is dwonload you before for root your phone.
Thank You
-Mitin Sakib
Aug 27, 2013 | Tablets & eReaders
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
Android vimicro logo stuck on screen
ANDROID Tablet Freezes at Android startup screen
For Superpad VI - 10.1" Android Version 4.03, this worked for me!
1. Press & hold START button
2. When "VIMICRO" appears, Then Press & Hold the MENU button
3. The Android System Recovery <3e> Menu should appear
4. Scroll down using the Volume Key to "wipe data/factory reset"
5. Press HOME Button
6. Scroll down to "Yes - delete all user data"
7. Press the HOME Button
At this point the system will do a recovery and hard start, and will be on "reboot system now
8.Press the HOME Button
Your system should reboot normally, but you will need to enter all new data, as it has been wiped clean.
Apr 03, 2012 | Tablets & eReaders
Open Questions:
See all Chromo Inc NORIA JR. 8GB 7" Tablet PC. Android Questions
Chromo Inc NORIA JR. 8GB 7" Tablet PC. Android JellyBean 4.1. Dual Cameras, HDMI, 3200 mAh Battery, Dual Core 1.2 GHz CPU - Light Blue Logo
431 people viewed this question
Top Chromo Inc Tablets & eReaders Experts
jeff5may32
shadowchb
 Mikey
Mikey
Are you a Chromo Inc Tablet and eReader Expert? Answer questions, earn points and help others
