I need to remove the Control Panel
The top three clips undo easily, but I can't see how to unclip the bottom three. I am worried about breaking it. I may need to replace the panel, as the start button is not working, but I'll still need to remove it. The manual did not offer any help. Any advice would be greatly appreciated.
  • Sadie Lawson Apr 12, 2014
    It is a Beko 15106D Washing Machine, thought it would show up in the question, silly me!
  • 3 Answers
Go to appliancerepair.com
Posted on Apr 12, 2014
Testimonial: "Thank you for your reply, this site does not have Beko listed, even with a search"
SOURCE: Replace touch pad and control panel
Sorry, there wasa problemwith the link in the previous post. Hope this one will work. https://secured.whirlpool.com/Service/ SrvTechAdm.nsf/ 2cd44500d572193285256a45004fd9d6 /2c1e295a88aaaae885256c5d004632a4 /$FILE/8178010.pdf
Posted on Jun 17, 2007
  • 90 Answers
SOURCE: How to remove top panel and front facia on a Hotpoint Aquarius WDF451 washing machine
Un plug it. There should be small screws either at the bottom of the panel on the front or there is separate panel that comes off the top back. If the back is one solid piece top to bottom, then the control panel lifts out and hinges up when the two small cross tip screws are removed from the bottom outside corners of the control panel..
Posted on Feb 10, 2008
jsrock516
  • 5911 Answers
SOURCE: removing front panel from kenmore elite HE-3 front load washer?
If you've removed the screws and the panel sticks, tapping on each side will knock it loose. The panel should drop down, then off. You can also try propping the two front feet of the washer up slightly for better access. A 2x4 works real well. This will allow more room for the panel to drop and gives better access to the screws. The washer is very heavy, so you may need some assistance to lift the front. Either lift from the bottom, or place your hands on the front facing of the cabinet to push the washer back. DO NOT push on the door or control panel.
If you still need assistance, please let me know. I hope this helps you.
Posted on Jul 05, 2009
dh1200s
  • 335 Answers
SOURCE: I have a Maytag Neptune top load washer. When I
I’m and owner as you and will toss out this info.
The OD alarm means the FAV6800AW/FAV9800AW Control Board has not sensed a lid open condition for three completed wash cycles. You can unplug the washer 120VAC power and plug back in and see if that will give you three more wash cycle before extending the OD alarm again. This would only be a temp fix. You have probably lost Lid is Closed/Lid is Open signaling back to the Control Board from the Left Hand Lid Lock assembly.
Take a look at this post and see if will help you repair the issue. I have some pic's and links in that post that may help. You will need the Service Manual for working on this machine.
I use external magnets over the left lid bumper to accurate the magnetic operated reed relay switch located in the Left Hand Lid Lock assembly to check for signaling operation of that magnetic reed relay back to the Control Board. I’m going to start out by having you check out the Magnet Reed Relay signaling from the Left Hand Lid Lock assembly.
With the Washer Lid open start a quick wash cycle, you should signal an OP alarm to the console do you? If so now close the washer lid the OP alarm should clear if the Lid Magnet is not out of position. If it doesn’t clear place couple magnets on the left bumper as I show in this post. If the OP alarm now clears then the lid magnet is out of position and the manual will show you its location to repair.
If you still trigger an OD alarm then it’s time to inspect the Left Lid Lock Plug and assembly for corrosion issues. See Page 34 of the Service Manual. The technicians thumb is on the Left Hand Lid Lock assembly. The Left Hand Lid Lock assembly is not a sealed very well and is subject to corrosion issues with its location near the bleach dispenser. If you are a DIY’er you won’t have any problem getting to the Left Hand Lid Lock assembly. The mating plug can be very difficult to remove from the assembly watch your knuckles. Be careful when you open the case halves of the Left Hand Lid lock assembly it is very easy to damage those retaining tabs. Unplug the 120VAC to your machine and follow the manual to raise the washer top from the base. If you have heavy corrosion issues you can clean up with contact cleaner ( I use WD-40) and some emery cloth/fine grit sandpaper. Check to see if the Black and Red wires are on the magnetic reed relay switch solder connections have not broken loose from corrosion. They can be re-soldered back on if they have broken loose. I don’t believe they have if you are not showing an OP alarm at the start of the wash cycle. You may want to squirt some WD-40 into the into the Left Hand Lid Lock plug and re-seat a few times if you have heavy corrosion in the Left Hand Lid Lock assembly as seen in the Pic.
If you use a DVM/Ohm meter to check the magnetic reed relay switch make sure you unseat/pull the Left Hand Lid Lock Plug from the Left Hand Lid Lock assembly to isolate the signaling leads going back to the Control Board, we don’t want to kill the Control Board with the Ohm Meter. I would only break out the DVM if I had to start troubleshooting signaling back thru the wiring harness to the control boart inputs and +12VDC output to the Left Hand Lid Lock assembly. The Control Board would have to be isolated fom the Ohm Meter measurements. I recommend not using a DVM/Ohm meter at this point of the troubleshooting process.
Here is a link for the Left Hand Lid Lock if you feel it would be easier to replace the assembly. Left Lid Lock Other suppliers will have the part I like these folks. Post back if you have additional questions.
Rich
Posted on Aug 29, 2009
Testimonial: "Your suggestions were helpful because it allowed me to investigate the area in question and found the black wire had unraveled from the connection. "
Jahn27
  • 1554 Answers
SOURCE: Cabrio top load washer (WTW6600SB1)
Unplug the machine or disconnect power then remove the three hex-head mounting screws from the rear of the console. Tilt the console forward toward the front of the machine then disconnect the user interface board cable connector from the machine/motor control and lift the console off the cabinet.
Carefully pull the cycle selector knob off the shaft then turn the console on its face for access to the user interface control board. Unhook the wires from the clips then remove the three screws securing the board. Using a flat-blade screw driver, pry the cover's two locking tabs out then unclip and remove the cover from the console.
Lift the locking tab of the encoder then turn the encoder counterclockwise and lift and remove it. Carefully pry the font edge of the user interface board up then pull the board forward and remove it from the console. You may glue the broken part back in place or replace the console with part number W10070060.
Posted on Jul 18, 2011
Testimonial: "Great answer! After reading response I was able to get access to broken item in 5 minutes!"
Tip
Replacing colorwheel on an InFocus X1A, X2, X3, and SP4805
to replace the colorwheel:
remove the 4 brass and 4 silver screws from the bottom and the 2 silver screws from the back. through the top vent on the back panel and using a flat head screwdriver, unclip the 3 clips holding the back panel on. once removed, unplug the 2 wire harnesses. remove the top and front panel. now unplug the large wire harness and remove all the brass screws on the 2 power supply boards (also the screw for the ground wire). there is a black clip in the middle of the larger power board. remove the boards. now remove the brass screws holding the metal plate on. once removed, unplug the flat ribbon cable (for the colorwheel). now facing the front end, remove the lamp and the 4 screws holding the lamp housing (with fans) on to the bottom case. remove the tiny black screw on the small circuit board and remove the board. now you can get to the colorwheel. there are 2 small black screws holding the bracket. pull the ribbon cable through from under the fan. replace with new colorwheel and reverse the instructions. the only difference, remove the front panel from the top by undoing the clips. good luck!
on Dec 02, 2009 | InFocus LP220 Projector
How to replace a gear lever leather boot on a Honda 2.2 crv 58 plate
First, unscrew the original gear knoband remove completely.
Next unclip the panel which covers the base of the gear knob. This unclips quite easily without the use of tools or screwdrivers. Pop it off from the top end first and then lifts out from the bottom.
Screw on the new gear knob. Once tightly fitting, put the gaiterover it.
Top Tip - use a cable tie to keep the new gaitor fitting snug! This stops it slipping down and looking saggy. Clip off the excess off the end of thecable tie.yannis-albums-new+gear+knob++gaiter-picture7966-tip-use-cable-tie-keep-new-gaitor-fitting-snug-audi-tt-leather-gaiter.jpg
Finally tuck the new gaiterin and ensure it is fitting snug. Then follow clip the plastic base cover back on. Sit back and look proudly at you new smart, quality gear knoband gaiter!
Oct 11, 2014 | Cars & Trucks
How do I change the drivers side window motor on an 2007 suzuki xl-7?
I dont know this model specifically, but these are all pretty standard. You will have to get the door panel off, which usually begins with removing screws toward the center of the door ( usually by the handle ) then popping the door panel off by going clip by clip around the outside. You may break clips if you dont know what you are doing, but just buy new ones. No sweat.
Then, remove the plastic film covering the door ( dont tear it, cause you need it again) and find where the motor is screwed in. Undo the bolts holding the motor in, unclip the wires. Replace with new motor. Installation is reverse of removal.
Jul 06, 2014 | Cars & Trucks
How do you remove door panel on rover 75?
1st off remove the plastic moulding inside of the door release ,undo the small screw,at the bottom of the door there are 4 screws[usually pozy drive] undo them, prise off the bottom part of the cover [the door pull arm]inside there is a large pozy screw,undo that,then using a medium screwdriver or a small pry bar placed between the door panel/door,prise away the panel section by section,beginning from the bottom,until you have unclipped all the plastic retainers,then gently lift away upwards,do not drop,as you have to unclip the door release cable from the back of the door panel,making sure to remember how it is sitting on the door panel and the lever,so to ease the re-assembly.
Jun 01, 2014 | 2005 Rover 75 1.8
Where is the spark plugs on a Lexus gs300 2003?
just remove the air intake box. then remove the throttle body , which should consist of two connectors and two coolant hoses and the throttle plate cable. all very easily accessible. once you have the cable, connectors and coolant hoses dissconnected, there is one nut at the bottom of the throttle body and two long screws at the top. slide the throttle body of the rod at the bottom. then remove the three bolt that hold on the big rubber gasket. now disconnect the three coils (which the little clips will break, but dont worry. after removing the wires and coil IMPORTANT!!! blow out all the debris in the alley due to it might fall in the engine while removing the spark plugs. perform service and dont worry if you mix up the coils it wont matter. just make sure the the wire go in the rght spots. then assemble together.
Aug 12, 2010 | 2006 Lexus Gs 300
Range rover p38 radiator removal info
First, remove the grille, then the top panel. Remove the viscous coupling and fan. Remove the top radiator mounts, Remove the coolant hoses and oil pipes, remove 4 bolts holding the A/C and intercooler/or PAS radiators (depending if yours is diesel or petrol.) then lift up and out the radiator. Fitting is reversal of removal.
Hope this helps
Nov 20, 2009 | 2000 Land Rover Range Rover
Removing keyboard
from the unplug the key baord
Dec 09, 2008 | Computers & Internet
"Burned" DC in power adapter
hi there generally all laptops can be opened more or less in the same way first undo all screws in the back, next you need to remove the panel where the power button is most of them just unclip and come off easily using a flat screw driver, you'll probably find some more screws underneath,if the hinges covers are part of the panel they should come off with the panel if seperate just check for any screws if not they just unclip undo any further screws, next unscrew the keyboard, unplug it, unplug the mouse pad, then the top part of the laptop base should just lift easily, make sure you remove the battery before you start all this, any drives, hard drive, etc hope this would be of some help regards
Jun 21, 2007 | Sony VAIO GRX550 Notebook
SAMSUNG RS21DCNS
speaking from memory: remove the middle translucent section held by one screw at top and clips. you will then see the additional screws you need to undo
May 07, 2007 | Samsung RS2630SH Side by Side Refrigerator
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
