Question about Pool & Spa
Just purchased spa tonight all jets work but no heat can any one help what I need to replace
  • 717 Answers
What brand of spa did you purchase?
Rod
US Parts Center
Posted on Apr 14, 2014
2 Suggested Answers
  • 111 Answers
SOURCE: OH error QCA spa High jets work and heat
OH is the overheat code.
Your spa temperature is set above 108, or your thermostat is faulty & not reading correctly.
Posted on Jan 26, 2012
Jet not running & spa not heating.
check to see if recirculation pump is running that one heats spa
Jan 25, 2016 | Pool & Spa
Over heating spa
Are Jets staying on HIGH?
Are your controls mechanical or digital?
Exact Information of the spa control system, not the spa manufacturer, will help us to help you. The box below with all the wires coming in & out. Name, model, code & serial #'s will help.
When jets stay on & don't turn off, water will heat up just by circulation causing "Friction".
If mechanical, your thermostat may have failed. If digital, your temperature sensor may have failed.
Dirty filter can cause this as well, if your flow sensor is failing.
Nov 17, 2013 | Belize Spas Belize e480L Lounger Spa -...
My pump on my spa to go works but i get no heat
Does it even have a heater ? these portables used a scavenger to heat the spa. it's a cove around the motor that uses the heat from the motor to heat the spa. it takes about a day to heat the spa and the heat doesn't last long. sorry .. . good luck and vote if'n I was of help.. jay the pool pump motor repair guy longwood florida
Aug 08, 2013 | Comfort Line Spa 2 Go Portable Spa with...
Heat pump does not work
can some one help me i have a spa quip sq1500 and my heater light will stay on for say 5 or 10 min but soon as i put jets on again the heater will go off and stay off untill i turn off jets again ????
thanks
Jun 08, 2013 | Pool & Spa
My Apollo hot tub stopped heating and the first set of jets are not working and both seemed to have gone out at the same time. The second set of jets and the air are fine. Does anyone have any ideas of...
You're pump #1 has failed. Your spa has 2 water pumps and an air pump. Number 1 pump pushes water through the heater. Pump 2 simply supplies the second set of jets with water. The air pump simply pushes air through the air jets.
If pump one fails you will have no heat and the first set of jets will not turn on. Pump 1 is the most prone to failure because it kicks on any time the spa needs to filter or heat. This happens automatically every day so pump 1 works much harder than pump 2. Your heater has a safety mechanism that makes sure that water is flowing through the heater when it kicks on. If there is a problem with pump 1 your heater will not kick on. There are stickers on your #1 pump. Get the model number off of the sticker and order a replacement pump from a web site like www.spapartsdepot.com. If you give them the model number of the pump they can send you a replacement. I'm 100% sure that's the problem. I'm not affiliated in any way with the web site I mentioned but I'm pretty sure they will have the pump you need. Good luck!
Mar 24, 2013 | Apollo Pool & Spa
Have a sovereign hot springs spa purchased in 2000. When turning the jets on it kicks the breaker. Also, the inside control system is not working anymore. Could our friendly electrician do this easily,...
When spas turn on initially they run through a purge cycle. This when the pump runs for a few minutes to remove any air in the heating system so the heater does not dry fire.
If your system runs through the start up cycle just fine but kicks the breaker when the heater starts then the heating element is bad and needs to be replaced.
Rod
US Parts Center
888-521-6183
Mar 18, 2013 | Pool & Spa
I received my brand new ez spa today and once I got the water in and pushed test on the gfci the spa came on and so did the jets. I understand that the motor needs to run to heat the water but does the...
Yes, the jets will run anytime the heater is operational. This is neccessary to keep the plumbing from melting, and also to evenly distribute the heated water. Most hot tubs only take 4-5 hours to heat up, but the easy spa takes very long because they use a very small heating element. Usually only 1.5KW.
Jul 26, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
I bought a home and my coleman spa 400 series has a problem, the jets 1 don't come on, jets 2 do. the water isn't heating up. was wondering what the problem could be
Pump one is the pump that does all the work in your spa. It handles the heating and filtering. If pump one does not work, It will not heat. It is likely pump one is gone but a technician would be needed to determine if it is the pump or the spa pack.
Dec 23, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Spa / hot tub does not heat
Your temperature control is way out of calibration or, it's wired wrong. Remove it and check it in a glass of water. Use an ohm meter across the heater wires. As you add hot wwater, the heater contacts should open.
Aug 11, 2009 | Jacuzzi Home
Pool & Spa Logo
32 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
