Question about Intel Computers & Internet
Dg31pr sata sata0 and sata2 ports are not working
  • Intel Master
  • 3,320 Answers
I'd say re-install the chipset drivers. That's what controls the SATA controller
Posted on Apr 13, 2014
  • 3 Answers
SOURCE: IDE motherboard gsvr845, trying to install sata2 hard drive
sir
i need intel 845 audio driver download
Posted on Mar 17, 2009
  • 489 Answers
SOURCE: can i install xp-sp3 without Sata driver on motherboard 'DG31PR'
You have a board with 4 SATA ports on it and a SATA HDD. The hardware detection routines will see this and load the SATA drivers. Why would you even want to try to set it up without them?
Posted on Mar 21, 2009
SOURCE: my monitor doesn't get any
did you update/downgrade your bios version....
Posted on Sep 28, 2010
Smoothly
  • 92 Answers
SOURCE: i have k8-upgrade-NF3. I tried
you need to change the BIOS setup. Go to the booting menu change the arrangement of your hardware.
1.Primary Disk (Hard disk) 2.CD/DVD ROM 3. Floppy 4.others
then save and exit. Your PC will reboot and MUST detect first your hard drive to proceed to your desktop..
I hope it will help you..
Posted on May 21, 2011
joecoolvette
  • 5660 Answers
SOURCE: Will Intel DG31PR supports SATA-2 or SATA-3 format internal drives?
The Intel DG31PR motherboard uses an Intel G31 motherboard chipset;
A) Intel 82G31 - Northbridge chip
B) Intel 82801GB (ICH7) - Southbridge chip
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_chipsets
Scroll down to the subheading - G31 in the left column.
The Southbridge chip controls the SATA bus.
The SATA bus uses SATA technology, that operates UP TO 3Gbps.
3 Gigabits per second.
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
The SATA 3.0 technology operates at 6Gbps.
6 Gigabits per second.
SATA revisions were made to be both Backward Compatible, and Forward Compatible.
However it depends on the manufacturer of the harddrive, as to how to switch it,
http://en.wikipedia.org/wiki/SATA#SATA_1.5_Gbit.2Fs_and_SATA_3_Gbit.2Fs
The answer is yes.
You will not get the full capability of the SATA 3.0 technology, however.
The harddrive will be operating at the SATA 1.5 technology.
Regards,
joecoolvette
[ Here is the Technical Product Specifications for the Intel DG31PR motherboard,
http://www.intel.com/support/motherboards/desktop/dg31pr/sb/CS-029381.htm
Click on in blue -
Intel Desktop Board DG31PR Technical Product Specification [PDF]
Page 10 - Peripheral Interfaces
- Four Serial ATA (3Gbps) interfaces -
Posted on Aug 02, 2012
Find my sata3 ports on an asus cm6670
YOU HAVE SIX SATA-PORTS 4 SATA2.
2 SATA3 PORTS,SATA3 SHOULD HAVE A DIFFRENT COLOUR.
Feb 11, 2015 | ASUS Computers & Internet
Intel DG31PR, How many HHDs can i add?
The board has 4 SATA ports and one IDE port. Therefore, assuming that you also want to connect a CD/DVD drive, you should be able to add another two SATA HDDs. You may need to get a SATA power adapter (splitter) cable, if no no more unused SATA power cables are available.
Also make sure that your power supply is not already "at the limit"...
Mar 22, 2010 | Intel DG31PR Motherboard
Need to know if it supports any SATA hard diskS
Yes, the T5212 motherboard supports SATA hard drives. I checked the picture and it has four (4) internal SATA ports.
If you would like to make sure, you may open the CPU and look for four black ports that has a marking of "SATA0 up to SATA3". The SATA ports starts with the zero, that's why you will see SATA0.
Good luck and have a good evening!
Jan 18, 2010 | E-Machines T5212 PC Desktop
Sata isnot reconized in bios nor will it install xp on a sata drive it starts to load all files then when to enter to set up xp home sp-3 the board is new been shelved then it gives windows cannot be...
Look up the specs. on the mb and find out if it supports sata1 or sata2 drives.
Your motherboard should have four sata ports and you may want to change to another port.
Also, you may need to format this sata drive, booting from the ide drive. Windows takes a long time to format but may be the only answer.
Last, make sure your bios settings are sata as raid.
Hope this works for you, its a pain.
Nov 19, 2009 | PC Chips MB PCCHIPS K8T800 M860 V1.0...
Raid settings, i one to set sata drive as primary and ide as secondery
First connect the SATA to port 0 Sata does not have any Primary or secondary port, It has ports SATA0,SATA1,SATA 2, 3 and 4(depending upon the number of ports available on your motherboard), Connect the SATA to port SATA0
Then connect another Drive to IDE 2(secondary). Normally the IDE port closer to the RAM is primary.
To confirm the connection is correct you can look in the BIOS
Please let me know if this information is helpful to you. If you find it helpful please do not forget to rate it.
Thank you for choosing Fixya
Oct 08, 2009 | Intel Motherboard
Can I use a SATA2 HDD for P5GL MX?
just like usb1 and 2, the sata2 harddrive will simply clock down to match the speeds of its port. the connections for both types are identical so there are no possibilities of problems...other then the motherboard saying "nope i cant read that", which most likely wont happen.
ohyeah...ram does the same thing too.
but honestly, if you're using a mobo thats only sata1 and you've got the dough for a new 1tb harddrive, you should consider upgrading your motherboard first...much better money spent
Apr 26, 2009 | ASUS P5GL-MX Motherboard
Can i install xp-sp3 without Sata driver on motherboard 'DG31PR'
Mar 21, 2009 | Intel DG31PR Motherboard
Sata concetion
SATA HDD's do not have master/slave/cs jumpers like IDE drives do because only 1 cable is connected to each drive, so you have to plug whichever HDD you want to be primary into the SATA0 port (or SATA1 if there is no SATA0) on the motherboard.
Also make sure you have your masterboot recrod installed on the drive you use to boot.
Jan 22, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Computers & Internet Logo
23 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
