Question about Cell Phones
Nokia lumia 720 microphone not working
When speaking into the phone no one hears me, but i can here them. Works on blue tooth headset though.
  • 10 Answers
SOURCE: only works on loadspeaker
The problem is with the socket where you insert the handsfree. Sometimes the socket connection is not released internally after removing the jack. Please insert the handsfree to its jack socket and remove it. Try again.
If not possible, a repair technician has to do it.
Posted on Oct 29, 2007
  • 33 Answers
SOURCE: blue tooth headset for nokia 3110c
You can purchase a universal bluetooth headset and then pair the device using the instruction manual that comes with the headset. This is a very easy process and all you need to do is make sure that the blutooth on your phone is switched on. When you turn the headset on, it should automatically pair after the first attempt.
Posted on Jun 09, 2008
  • 31 Answers
SOURCE: Nokia 6070 stays in headset mode w/o headset pulled in
Try restoring factory settings which is in settings
Posted on Jul 09, 2009
  • 5 Answers
SOURCE: HEADSET ICON
open headset port, push down on square connector, cover port and it will be gone
Posted on Sep 11, 2009
SOURCE: My LG GW520 phone's microphone's aren't working.
my LG GW520 set is problem mic.
i replaced it mic **** it is not work.
now i am checking mic point on the board his one point is not show any value please send me its mic tracks on the board
Posted on Mar 21, 2011
Nokia Lumia 800 Windows Phone 7.8 Bluetooth not work properly
soft reset your phone if problem persists hard reset
Oct 21, 2014 | Nokia Lumia 820
Why is there no sound on my NoKia Lumia 520 windows 8 ?
I ran into this same problem with my Nokia 900. It happened right after I plugged and unplugged a headphone into the headphone jack, so I suspect Nokia ships with a defective headphone jack sensor, because this happened with the second phone after I returned the first one and got a new one. (Note to self, don't plug a headphone into a Nokia phone). I am able to temporarily get around the issue by going to the dialer and calling ##634#, then going to the audio loopback diagnostic and starting the loopback for the phone and choosing loudspeaker. This does not last permanently, so I have never found a solution to the issue, other than using blue tooth or speaker phone.
Jul 28, 2014 | Nokia Lumia 520 Windows Phone Black
How to do hard reset for nokia lumia 720
#Option 1, Hard Reset NOKIA LUMIA 720 with software menu:
  1. Turn on the NOKIA LUMIA 720
  2. Go to Menu Setting > Setting
  3. Choose About and choose Reset your phone
#Option 2, Hard Reset NOKIA LUMIA 720 with Hardware Key Button:
  1. Turn off NOKIA LUMIA 720
  2. Press and hold together Volume Down Button + Power Button until LCD show exclamation mark icon
  3. Now release all number 2 buttons.
  4. Press one by one continuously:
    1. Press and Release Volume Up Button
    2. Press and Release Volume Down Button
    3. Press and Release Power Button
    4. Press and Release Volume Down Down
  5. If the step finish, the NOKIA LUMIA 720 will do the hard reset or factory format by itself.
  6. Wait until it finish to format, then we will need to setup like new again.
Aug 20, 2013 | Nokia Lumia 720 Windows Phone Black
I try to connect my blue-tooth headset model NOKIA BH-209 with my Nokia E63 mobile phone , but My NOKIA E63 mobile phone does not search NOKIA-BH-209, my NOKIA blue-tooh BH-209 is working with an other...
PLEASE MAKE SURE THAT YOUR PHONE BLUE TOOTH IS WORKING PROPERLY IF YES TRY CONNECTING YOUR PHONE WITH OTHER BLUE TOOTH HEADSETS. IF IT GETS CONNECTED YOUR PHONE DOESN'T SUPPORT YOUR HEADSET. IF IT DOESNT YOUR PHONE ISN;T WORKING GOOD.
Jul 18, 2011 | Cell Phones
Does explorer 230 pair with nokia 2600
the explorer 230 blue tooth can be paired with the Nokia phone if only the blue tooth tooth device is a universal blue tooth.
Universal blue tooth can work with any phone no matter the model.So check the blue tooth if it is a universal blue tooth, try it with the phone and see if it will work.
Have a nice day
Mar 16, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Nokia 6265 nobody can hear me
Change the setting from headset or handsfree back to normal. If you are using blue tooth,you have to shut it off to get normal mode to work.
Jun 16, 2008 | Motorola Mobility C168 Cellular Phone
Motorola h350 blue tooth headset microphone does not work
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H350 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
May 30, 2008 | Motorola Mobility Bluetooth Headset H3...
Cell Phones Logo
413 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
