Question about Samsung NEW 55 Class 54.6 Diag. LED 6000 Series Smart TV Heavy Duty Articulating Dual Arm TV Wall Mount Bracket For 55 Inch Samsung
No sound on tv
When I turned on my tv today there was no sound.
    New Friend:
  • 12 Answers
Unplug your tv for a few minutes might help if it doesn't, turn your tv on, go to menu, reset to factory settings.
Posted on Apr 12, 2014
Yamaha HTR-5063 is connected with new LG smart TV with HDMI. Today no picture or sound on TV. How to fix it ?
First, you need to identify which box the problem is in. Does the TV work with other inputs? If not, problem in TV. If it does, then the problem is in the Yamaha.
Once you know where the problem is, you can proceed to fixing what's broken.
Jul 10, 2015 | Yamaha HTR-5063 Receiver
How do I get sound back on my samsung tv
if you are technical check the sound module the IC is blown you can get the same from any electronic component retailer and replcae
Jul 16, 2014 | Samsung Televison & Video
Why does the screen shut down after 1 sec while sound continues
It sounds like bad luck to me. You cannot change any settings on a TV by connecting a computer to it. In theory you can damage any monitor by setting the screen resolution of the computer higher than the monitors maximum res. The Sharp 26" has a resolution of 1366 x 768 (1080i) so (again in theory and I have never seen it happen) if you set the output to 1920 x 1024 (HD - 1080p) it can kill the screen. Perhaps this is what has happened. You will need to take it to a Sharp service centre.
May 29, 2014 | Sharp LC-26SD1E 26 in. LCD Television
No Picture now No Sound
main board faulty check tuner poss dry joints
Nov 22, 2012 | LG 37LC7D 37 in. LCD HDTV
Sound not working, Was working earlier today and after shutting off the tv, when we turned it back on, sound wasen't working
Sound issues and answersa short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD.
Apr 03, 2012 | Vizio 42 in. LCD TV
No sound on the TV whether playing through satellite, DVD player, or through antenna. Happend once today and when I turned the TV off and then back on, the sound came back. Just turned the TV on, and the...
Hi
Can you hear sound if a set of head phones are connected to head phone socket if so the head phone socket might need cleaning or replacing
Regards windyhouse
Mar 09, 2010 | Toshiba 32A33 32" TV
No sound on older samsung tv
techs call this a cold or a bad solder connection on the output transistor most likely, tap on it here and there when it happens on the bottom and side of tv, if sound comes in then stops again then it would be a loose connection due to heat over time, if your inclined u can be fixed it, if bad chip it would play first then shut off, or if u have a cable box or rca outputs on tv use them on an amp to get sound, that would bypass amp output and u will use the preamp section which is a different circuit, debgh@comcast.net
Jul 25, 2008 | RCA F19625 19" TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
Samsung NEW 55 Class 54.6 Diag. LED 6000 Series Smart TV Heavy Duty Articulating Dual Arm TV Wall Mount Bracket For 55 Inch Samsung Logo
154 people viewed this question
Henry  Thomas
Henry Thomas
