Question about Electronics - Others
Battery overheating How to heat invertor battery, if destril water fill up
Cannot diagnose or run temp. Sealer for what i believe is head blown because car wont start it cranks but sputters and kills battery?
Sounds like head gasket again, but may be more serious this time. Overheating is not something to take lightly.
Pull plugs. crank. Water come out of cylinders? Head gasket. Possible cracked block or head this time, too. I'd be looking at a replacement engine.
Oct 06, 2015 | Ford Cars & Trucks
Estate Washer Model TAWX700JQ0 Washer fills when started... Does not Wash, Spin, Rinse, or Drain. during the wash cycle the water fill solenoid sounds like it is energized but no water is entering the...
You say washer fills and then you say no water is entering the washer?? Burning smell is most likely motor overheating due to maybe something stuck in drain Pump.
Nov 14, 2017 | Estate TAWX700JQ Top Load Washer
No heat in 2003 buick lesabre but engine overheating
The first thing you need to do is check the cooling system coolant level. If it is low or empty, there is not sufficient coolant to cool the engine or to transfer through the heater core to supply the cabin with heat. Fill it up and check for leaks. Once leaks have been repaired, change the thermostat, engine oil and oil filter. If it is full, you may need to change the coolant due to its age, as well as the thermostat, engine oil and oil filter. The reason for the oil change is due to the thermal breakdown of the oil in overheating conditions. Also inspect the water pump to ensure it is being driven by the belt. You may also have air in the cooling system that is causing all your problems. Generally only happens when the cooling system is improperly filled. Make sure you add the correct mixture of coolant and water. Incorrect ratios will cause you similar problems.Coolant protects the cooling system and the water dissipates the heat.
Oct 07, 2012 | 2003 Buick LeSabre
Heat in my truck is not working. a/c is
Fill the coolant recovery tan full and run the engine until it gets heated up but not overheated, then run cold water over the radiator core to **** the coolant in and fill any voids in the block.
Oct 02, 2012 | 1990 Ford F150
2001 jeep grand cherokee over heating.building up alot of pressure.found crack in radiat5or and replaced it.changed thermostat and cooling sensor,still over heatd with alot of pressure.thought maybe i...
try to replace the radiator cap w/ new ones,then do not fully fill the water reservoir w/ water leave some space for the air to circulate when water boils.done this and still there's a overheating your need to replace your cylinder head gasket,frequent overheating damages the gasket.
Aug 14, 2012 | Jeep Grand Cherokee Cars & Trucks
Engine overheats and I've changed the water pump already along with the thermostat. What could be the problem?
many things can cause an engine to over heat
Look for any collasped water coolant hose. That will cause overheating'
If the inside of the engines oil cap looks to have a creamy filling in it that will be from coolant mixing with the engine oil. Head gasket leak and can cause overheating
A clogged up heater core or radiator can cause overheating
A loose or worn seal on the radiator fill cap can cause overheating as well
Jun 27, 2010 | Cars & Trucks
91 lx accord overheating issue
make sure your over flow/add coolant bottle is clean...check that the hose from bottle to radiator isnt clogged...also fill add bottle fluid level between add and full mark
Nov 15, 2009 | 1991 Honda Accord
1995 nissan maxima overheating
you possibly need a thermostat or even a water pump you can fill up the coolant at the radiator cap..its a silver cap near the front ov the car you need to push down on it and turn counter clockwise
Oct 28, 2008 | 2000 Nissan Maxima
Electronics - Others Logo
82 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
