Question about Canon imageRUNNER 5000 Copier
My canon IR 2520 shows eror code 000001 - Canon imageRUNNER 5000 Copier
  • 75 Answers
Did you look up what the code means. You may need tech support.
Posted on Apr 12, 2014
  • 18 Answers
SOURCE: CANON IR 5000i
Uh oh! You probably will need a new hard drive for your 5000. A new drive will have to be installed by a tech, then formatted and new system software installed. The E602 with the 000001 sub code indicates a hard disk drive failure.
Posted on Aug 26, 2008
iservice
  • 318 Answers
SOURCE: E 000001-0002
The error code mean your fixing heater isnt getting warm in a specific time.But it can be caused by a power dip.
So try this.
Press the star button and then the no 2 and 8 together press star again.Then you are in service mode.
In service mode sellect "copier" and then "Function"and then"clear"ant then"error" and press the ok on the screen.Swiths the machine at the plug off and on.
And Katchiiing!!!
If it doen't help you will have to contact your Canon dealer to replace that Fixing.
Posted on Oct 29, 2008
SOURCE: error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Posted on Feb 11, 2010
canontech
  • 1219 Answers
SOURCE: Solution for canon ir 2520 error code E000020
E020 0000
The path between the sub hopper and the developing
assembly is clogged with toner.
1.Check the rotation of hopper motor gear. (If rotating, false
detection by the sensor is doubted. Feed the toner to the
developing unit in service mode: CLEAR>ENGIN>TNRINST.)
2.Replace the Developing Assembly Toner Sensor (TS1).
3.Replace the Sub Hopper Toner Sensor (TS2).
4.Replace the DC Controller PCB (PCB4).
SERVICE MODE:
* 28 * or MENU and #
Posted on Jul 01, 2010
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Posted on Jul 20, 2010
My CANON IR 2520 PRINTING VERY DARK SHEET AND SHOW ERROR CODE E000110 THANKS
Try removing ink cartridges and see if anything changes. If printer starts working fine, check which ink cartridge is bad by putting one at a time, or just change ink cartridges.
Jun 09, 2017 | Canon Office Equipment & Supplies
Conon ir 2520 erore code e000750
Cause of the error code is a version mismatch with the bootROM file and the bootable/language file.
Re-launch the firmware flash and follow this order of flashing machine.
  1. Flash BOOT
  2. Flash SYSTEM
  3. Flash Language
  4. Cycle power and let machine boot normally.
May 10, 2015 | Office Equipment & Supplies
E000 errors are usually a bad fuser (also called fixing assembly by canon) You should buy FM4-3367-000 (for US/ Canada / Mexico 110V version.
Sep 11, 2014 | Canon imageRUNNER 2520 Laser Multifunction...
Eror 000001-000002eror 000001-000002eror 000001-000002eror 000001-000002
The temperature of the fixing assembly is abnormally high.
You can try to reset error, change thermistor or PCB.
Aug 14, 2014 | Canon imageRUNNER iR C2880 Color Copier
Solution to errorE000003 0f ir 2520
Press the additionel function button & press 2&8 buttons at once and again press additionel function .select COPIER and FUNCTION and CLEAR and ERROR andpress OK button.
Feb 26, 2013 | Office Equipment & Supplies
CANON IR2520 SHOWING ERROR CODE 804
In my experience the 804 error code relates to the location/availability of a file. If you are trying to print/access a particular file check the path and make sure you have permission to access it.
Dec 28, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
What it a finisher for canon ir 2520
it is the "device" which is mounted on ir 2520 or any other copier, with purpose to stack, collate or staple the copies. :-)
Hope that helps!
Jan 10, 2011 | Office Equipment & Supplies
CANON IR 5000i
Aug 15, 2008 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
59 people viewed this question
old marine
old marine
