Question about Garden
Iseki 2140 newish battery not charging & so cannot start without jump leads from car. Altrenator bracket broke but now fixed, starter motor frequently dead until tapped. Charge light lit, also water temp light lit. Where do I start?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 21 Answers
Fuses. always check fuses first. test for power at the
Posted on Apr 12, 2014
  • 81 Answers
SOURCE: Starter flywheel is not engaging motor
If you blew a fuse you could have a grounded wire someplace. Check the wiring on the solinoid, on the battery, on the lights and anyplace there could have been a bear spot rubbed. If the flywheel does not engage check the flywheel gear on the end of the started to see if it is chewed and worn. These can be replaced easily,
Posted on Jun 20, 2009
  • 74 Answers
SOURCE: I have an RZT50 Cub Cadet Mower that only starts with jump
it sounds like the starter motor is pulling to many amps for the battery to cope with. if its a 12v system it should not pull the battery down to less than 8.5 volts on cranking if it does the starter-motor is defective you can check this with a volt meeter across the battery terminals and see what it read as you crank the engine. hope this helps
Posted on May 12, 2009
  • 86 Answers
SOURCE: I have a Toro LX425 riding mower with a new
Your most likely talking new starter,never jump start a lawnmower with car,to much amps.fries your starter resulting in like low battery condition,If interested can give you a place you can get a resonable price ,Most places will shock you over 120 dollers.
  • 12 Answers
SOURCE: battery wont stay charged
HAVE YOU CHECKED THE CHARGING SYSTEM? YOU COULD HAVE A BAD VOLTAGE REGULATOR. ITS REAL SIMPLE TO DO.START THE MOWER,PUT IT AT FULL THROTTLE.TURN A MULTI-METER TO VOLTS AND TOUCH THE BATTERY.YOU SHOULD READ 13.5-14.6 VOLTS.IF NOT GOOD CHANCE THE VOLTAGE REGULATOR IS NO GOOD.
Posted on Jul 29, 2009
jcameo7270
  • 675 Answers
SOURCE: I have a countax K18
there is a coil under the flywheel that is supposed to charge the battery...if you look at the engine there should be a wire coming from under the flywheel that is supposed to go to either a diode or a regulator and then to the battery...you can put a meter on this lead and one on the engine ground to see if it is putting out voltage...you may need to put the meter on AC VOLTS as the voltage may be AC...if there is a regulator(it looks like a heatsink module,square with fins on it..).this may be defective. The ac coming out of the stator(this is the tech term for the alternator) is present..(it will vary with eng speed)..then the regulator is probably bad
Posted on May 16, 2011
I have a D5805 STARTER-UP 400 Jump Starter and need instructions for it. where can I get them.
you can buy one at any good car sale shop and make sure you
read all the instructions before useing it as jump starting is always fit red [POS] cable to both cars or batterys first and then fit the black cable lead last,when finished remove the Earth lead [black]First with car doing the charging turned off.
When charging car to car let engine run for approx 4 minutes at 800 rpm then let it idle for 2 minutes before starting the second car
Nov 16, 2014 | Cars & Trucks
Hi, My 2006 ford focus wouldn't start this morning. After starting it first time with jump leads I drove it for 20 minutes before stopping for 1 minute. When I tried to start it again I got nothing but a...
The clicking sound is the starter motor trying to engage, but does not engage because of low electrical current. Knowing that you started your motor with jump leads this morning indicates that your car's battery needs charging/replacement.
Hope this helps.
Nov 06, 2013 | Cars & Trucks
How do I get truck started after its been sitting for months
Charge up the battery with a battery charger or jump start the truck with a good battery. Connect the jumper leads from the good battery to the battery on the truck.
Connect the red lead from the + terminal on the good battery to the + (plus) terminal on the truck.
Connect the black lead from the - terminal on the good battery to the - (minus) terminal on the truck.
The good battery will supply power to the starter motor.
Then you can turn the key to start the truck.
Feb 24, 2012 | 1991 Ford F150
I have a homelite 720 generator but cant fingd the instruction manual and i need to know if the charger leads only charge a battery or can be used as jump leads i know this might sound stupid but i wo
I can't find any reference to a Homelite model 720 generator but most battery charging systems do not supply enough amps to run a car starter. Battery chargers usually work in the two (trickle) to ten amp range. Car starters need way more amps to have enough power to turn an engine over, depending on the size and number of cylinders in the motor. Some chargers have a switch with a 60 amp 'start' position to help the battery turn the motor over, but without that there is little chance the charger side of your generator will supply enough amps to help your battery.
Feb 21, 2012 | Cars & Trucks
Car just clicks when tryingto start battery is good. Will not jump with another car
YOU HAVE A PROBLEM LIKE A LOT OF OTHERS BUT ITS EITHER,
the battery term on the = or+ on battery lead OR where the Earth lead on battery is fitted ORthe feed (+)on starter motor connection or the solinoid on starter,or starter jamed or engine siezed.
SO first jump start as +on battery on both cars and them (black lead)to a good earth on engine not on to battery on your engine,try to start if not fot red lead to starter motor feed and it should spin if not then replace the starter but first just turn engine over slightly by bottom pully,if it dosent turn then engine is no good.
Nov 16, 2010 | 1998 Ford Taurus
1997 explorer, awd, 8cyl replaced starter and starter solenoid but i still get one click from the starter, then nothing
does the motor spin ?? take starter out,,take wide flat head stick it between the teeth,& see if u can turn the motor over or get the metric socket for the crank bolt & turn it from there,,((it is easy if the spark plugs are out))
May 08, 2010 | 1997 Ford Explorer AWD
I put in a new battery, but the starter motor won't turn over. When try to start it everything dims. Do I need a new starter motor?
try this ? connect a jump lead to the earth/negative terminal on the battery then connect the other end of lead direct to a sutable eart point on the engine try engine mount ? then having done this try starting ? if starter work then your problem is either the batteries earth lead is fault /loose on engine or batt terminal ? make checks on all battery leads connections to starter and earth on engine ?this is reason lights go dim due to poor earth assume battery is full charged ?
Dec 31, 2009 | 2000 Mitsubishi Eclipse
2002 Chevy Suburban...Power/Battery?
Make sure battery is fully charged, try jump starting it, if it starts, and you can get a volt meter, put the test leads on the battery terminals, red positive black negative, have the dial on the meter at 12volts DC.
With the motor running, the meter should read between 14 and 15 volts, below that, the alternator isn't charging and needs replacing.
If it still clicks with a jump, the starter solenoid is bad and needs replacing. The solenoid is on top of the starter, which has to be removed to fix it.
Aug 28, 2009 | 2002 Chevrolet Suburban
1997 BMW316 compact wont start. Had to jump start it with leads recently but put it down to weather. Only use it during weeks so sometimes left a few days without driving. It ticks when trying to turn...
probably not starter but weak battery when battery low on charge you will hear solenoid on starter clicking when trying to start battery on cars do lose charge in frosty weather but it means battery old or cells in bat inop just replace bat
Feb 21, 2009 | 2001 BMW 5 Series
Honda CB 250 1998-will not start, just clicking, battery is ok
Hi, Your problem lies with the starter solenoid, although you maybe using a fully charged battery to jump it, it appears to be sticking or possibly faulty due to trying to start with poor battery.
The starter solenoid is usually located on or near the Battery compartment, it is cylindrical and has two heavy wires attached to it 1 goes to the starter motor the other to the battery. If you are carefull you can by pass the solenoid by touching the heavy wire going to the starter motor with the jumper lead. Make sure the jump battery is connected and both the NEGATIVE leads are well secure. Put the NEGATIVE lead from jump cable direct to a engine mount bolt or engine itself Not the battery.
There you are FixYa'd
Paul 'W'
Jan 05, 2009 | 1998 Honda CB 250 Nighthawk
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
