Question about Microsoft Windows 7 Home Premium 64BIT Operating System Software OEM DVD
VPN router - setup
How difficult is it to set up a Net Gear router R7000 with Astrill VPN
    Master:
  • Microsoft Master
  • 349 Answers
Please give this video a try.
Posted on Oct 17, 2015
I have a D-Link DVG-G1402S router, I'm trying to setup VPN connect for a windows VPN server, which inside the network. I tried use modem directly connect to the server, it work, so it process my...
The router's PPTP passthrough and IPSec settings assume that you're connecting to an external VPN server on the public side of the network, but it sounds like you're hosting your VPN server inside your local network. If this is the case, you may just want to have your windows VPN box in a DMZ, or get a router that you can exert more control over. Be wary, if you're doing this at a residential location, your internet provider will probably block or "shape" this type of incoming traffic to your local network.
Mar 05, 2011 | D-Link DVG-G1402S Wireless Router...
How do I setup our router to allow VPN client?
you are trying to connect to the VPN client.
Which VPN software you are using ?
To connect to the VPN , you will need to trigger ports on the router.
open the set up page of the router and trigger the ports on the router. The port numbers will be. 1723 , 10000-20000 , 443-447 , 500. Also reduce the MTU settings to 1365.
Disable the Block Internet request, you will find this option under security tab.
Make sure that the firmware of the router is up to date.
Click here for more information about router and network
Feb 22, 2010 | Linksys WRT160N Wireless Router
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
VPN drops when using a D-Link Dir655 router
Hi! Try to logon to the configuration page of your router. then go to Advanced tab and click on Firewall settings on your left side.
At the bottom part you could see the Application Gateway Level section, Uncheck all the boxes under that and click on Save Settings at the top.
Mar 06, 2009 | D-Link Xtreme N DIR-655 Wireless Router
VPN tunnel between two DLINK VPN DIR-130
- Logon to the configuration page of your D-Link.
- Go to Advanced tab
- And Click on Firewall Settings on the left side
- Under that look for Application Gateway Level at the bottom and you must uncheck at the box on it and click on save settings at the top.
Mar 02, 2009 | D-Link (DIR-130) Router
Configure VPN
That 3Com really doesn't have a wahy of setting up a VPN.
As per the 3Com site it:
Support of VPN termination/initiation and passthrough allows secure connection to central office and/or secure access from remote workers.
So it will allow 3rd party VPN setups to pass through, but it doesn't have the ability to create one.
You might want to look into something like a Netgear Firewall
http://www.netgear.com/Products/VPNandSSL/WiredVPNFirewallRouters/FVS114.aspx
Aug 09, 2008 | 3Com OfficeConnect Cable/DSL Router 4 x...
2wire 1701HG Gateway Router VPN Setup
Go to http://gateway.2wire.net and click on the firewall icon. Click on firewall settings and, if prompted, enter your system password to reach the advanced settings page. select the computer that will function as the VPN server. In the left column, select PPTP server. click on Add, then done. or try changing the IP scheme to the 172.16.0.0/255.255.0.0 or 10.0.0.0/255.255.0.0 schemes by accessing gateway.2wire.net, go to home network icon, then advanced settings. but if you manually configure or disable dhcp, be sure to write down the subnet mask & IP assigned to the 2wire then click on save. if all else fails, run it on DMZPlus mode, however this solution will allow all inbound traffic to the computer. if it still doesn't work on DMZPlus mode, the VPN is either using the same IP scheme, is using IPSec 50 or 51, or will not work with the 2Wire gateway.
Jan 30, 2008 | 2wire (1000-400108-001) Router
DI 524 Router Not able to connect to office VPN on Wireless
I have the same model router at home, just checked the settings, you should be able to pass through the router with a normal vpn connection.
If you use a special VPN client, like a CheckPoint Secure VPN client, the router might block it. Also you might want to ask your office's sys admin if you are not blocked by the firewall or something similar. Your office's sys admin will prolly solve your problem since he knows your work network's configuration and setup and how to connect to it.
Nov 08, 2007 | D-Link AirPlus DI-524 Wireless Router
Microsoft Windows 7 Home Premium 64BIT Operating System Software  OEM DVD Logo
60 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
