Question about Xerox WORKCENTRE 6015/Ni Color
Xerox workcentre 6015 ni error code 092-651 - Xerox WORKCENTRE 6015/Ni Color
Printer CM205 b error code 092-651
Options My printer FUJI XEROX CM205b is showing an error code of 092-651 with a sub code of 2080000. I have no idea what this means or how to go about fixing it. this has been a great printer and would like to fix it if possible.
Thank you for the help.
Posted on Jan 28, 2015
  • 2072 Answers
SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Posted on Apr 03, 2008
  • 2072 Answers
SOURCE: Xerox WorkCentre M128 - 016 - 782
There is an error in the in the server password or a template setting.
Here is the documentation. Pretty straight forward
Login to the Server was not possible during Scan to Server file transfer.
arrwup.gifInitial Action Refer to BSD 16.1.
Power OFF/ON
arrwup.gif Procedure Set the login name and password in the destination server.
Set the attributes of the Job Template file correctly.
From a client PC, set the same account as the above as a resource using CW.
Posted on May 19, 2008
  • 3 Answers
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
Posted on Oct 07, 2008
SOURCE: LSU Error
Hi Dear
I am facing LSU Error on my Xerox workstation PE 220
I am not able to do anything, please let me wat to do
i have lot of work penindg
urs
mujahid
Posted on Oct 13, 2008
  • 2072 Answers
SOURCE: workcentre c2424 is showing system error 39,003.40:117010
That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
Posted on Oct 23, 2008
CRUM ID 093-926
That error signifies an unsupported black toner cartridge. Verify oem Xerox cartridge, try reseat cartridge. If not cartridge it will be the MCU Board, part number 960K60951.
http://www.iteminconline.com/960k60951_062k23373-960k60951-xerox-workcentre-wc6015-engine-controller-mcu.htm
Jan 31, 2016 | Xerox 6015/NI New Workcenter 6015/NI Laser...
My xerox 6015 will print documents that I have previously printed even tho I am not requesting it to be printed. Nothing is in the print queue to cancel. what is wrong with it?
I assuming you mean you get 2 prints when you only asked for one. Looks like the driver default settings are set to 2 copies.
If you can use the copy facility and print one copy that sort of eliminates the printer. The problem must be further up stream towards the computer sending the print.
You also. If he like to remove the print driver and reinstall it, the default must always be set to 1 copy.
Feb 21, 2015 | Xerox Workcentre 6015/Ni Color Laser...
How do you turn on wifi on a Xerox 6016 NI?
should be a menu options look for wifi and follow instructions, a summing it is wifi compliant
Jun 29, 2014 | Xerox Workcentre 6015/NI
How do you connect the 6015 wifi to a netwrok?
My guess is if it already listed as a device, delete your printer or your driver. I forgot how completely delete the driver, but you can research it on the internet. I've done it. Then you start it all over again. It really should connect automatically. If not, if it's a new machine and you still have the receipt, just return it and get a different one that will connect correctly. If it's not new, well...
I get error message 075-100 (Reload paper then press OK) on my WorkCentre 6015. Nothing I can find clears it. Any help would be appreciated.
just remove the papers and put your hand there and try to move the Roller that pulling the paper , it worked for me .
Sep 21, 2013 | Xerox Office Equipment & Supplies
Xerox workcentre 6015 092-651 error
That error indicates a bad ADC sensor. Try cleaning the adc sensor which is on the rear of the transfer belt. If that doesn't work, replace transfer belt as sensor is not sold separately.
Sep 18, 2013 | Xerox WORKCENTRE 6015/Ni Color
Error 016-311 xerox workcentre M128
This error code means the Scanner is not installed. The reason for this code could be a bad or diconnected interface cable, or corrupt system software. Check the cables for connectivity. If the problem persists, it will probably require a call to Xerox service. 800-821-2797
Nov 08, 2009 | Xerox WorkCentre M128 Copier
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WORKCENTRE 6015/Ni Color Logo
2,113 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
