Question about SuperMicro COMPUTER EATX MBD X7DBE 5000P DCXEON FBD DDR2 SATA2 VGA (X7DBE+O) Motherboard
X7DBE no boot after configuring the adaptec RAID controller
I have X7DBE MB with a graphic card ZOTAK GT218IONGPU-A-E (I don't use the internal card). When I configured the adaptec RAID (0) with 2 HDD's and rebooted the system and after the fans reduced their speed, the only thing I saw was a DOS blinking cursor on the left and that's all. When I removed the graphic card and used the internal the system continued booting. Is there a conflict on the addresses or IRQ? What's the reason and how can it be solve? I saw "Known Limitations" that says: The ASR-2405 and ASR-2045 do not support the SuperMicro X7DBE. motherboard. Adaptec recommends using the SuperMicro X7DBE+. Is there a connection?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • SuperMicro Master
  • 2,226 Answers
The drivers
Posted on Jun 02, 2014
sparky1500
  • 1066 Answers
SOURCE: Hi,
there will be no dos prompt on a machine with a newer version of windows. if you have wndows 2000 or later, you can use the windows disk to repair the boot sector.
Posted on Oct 09, 2009
CPU solution
  • 164 Answers
SOURCE: Where do I get raid drivers for Supermicro
you can find the drivers you seek here...www.supermicro.com/support/Bios good luck!
Posted on Dec 18, 2009
  • 396 Answers
SOURCE: Supermicro X6DAL-TG boot problem
I have 3 of these boards; however, they all have the Nocona Xeon with a Front Side Bus speed of 800MHz. The manual does not say anything about using a 533fsb. A second thought was if your power supply is an ATX with a 24 pin power connector and two +12 connectors one 8 pin and one 4 pin? The manual states all three need to be connected for the Xeon Processor.
Posted on Jan 21, 2010
jcameo7270
  • 675 Answers
SOURCE: Hello, I have buy a Supermicro
I dont have specific info on this board, but most of the time you may need to set up a jumper to support 2 cpu's or with the 1 installed go into bios and see if there is a setting there that you can set. Another possibility may be the other chip is bad...swap the 2 out to see if it works...then you can rule that out...go to www.supermicro.com/manuals/motherboard/5500/MNL-1060.pdf...this is the manual for it...
Posted on Dec 20, 2010
ekcnoel
  • 998 Answers
SOURCE: Hello, I have a X5DPE-G2 supermicro
There is loosed connection in the mother board replace the H.D.D connector. it will fix the problem good day and best regards.
Posted on Aug 17, 2011
Intel Raid Card axxrmsll040 configure problem
need to download driver for raid driver https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Server%20Board%20s1200bt%20Family
May 05, 2013 | Intel Computers & Internet
Dell Precision 670 RAID1 Install on Windows 7
The RAID configuration maybe setup in the BIOS settings.
Mar 31, 2012 | Dell Precision Workstation 670 PC Desktop
My laptop screen keeps going blank after i start up. can you please tell me what the problem could be?
Is there anything displayed on the screen during boot up such as a manufacturer's logo?
Aug 21, 2011 | Adaptec AAC-364/DELL2 RAID Card p/n...
I have Max computers, Supermicro server with 4 Seagate 120 GB drives, an Adaptec Serial ATA RAID controller card. I formatted the drives with the built in utility, now when I try to load Windows Server...
You need to load the RAID driver for your controller. Go to Adaptec's website and download the 2003 driver for it. You will put the files on a floppy disk and load them at the F6 prompt during Windows Setup (right after it boots from CD). If you don't have a floppy drive/disk, then use nLiteOS.com to integrate the drivers (text-mode) into your installation media.
Aug 17, 2010 | SuperMicro (SYS-5014C-T) (SYS5014CT)...
Hi. We have a ML110 server with RAID 5 (4x250gb HD SATA) in a Adaptec 2610SA. The RAID has 2 Arrays (#00 Operating System and #01 Data). We have tried to replace a failed HD and since then the Windows...
Did you make sure that your hard drive has been made into a "dynamic volume" instead to the usual "simple volume"? It has to be "dynamic" before your can put it into a RAID configuration. You will have to use your RAID Controller to create a dynamic volume or to make the hard drive part of a dynamic volume.
Aug 04, 2010 | Adaptec 2610SA (0H2052) Serial ATA...
Boot problem with IBM xseries 206 - SCSI Drive and SATA drive
Refer to user's manual how to set the boot order in BIOS.
Jul 17, 2009 | IBM eServer xSeries 206
Not getting a drive letter from Compaq SCSI RAID setup
Did you see any new drives in the disk managemen screen? To get to the disk management, hold window key down and hit 'R', then type diskmgmt.msc and hit enter.
If you do see the drive in the lower half of the screen, you need to initialize the drive either as dynamic disk or basic disk. Then you need to add a new partition and format it.
Good luck.
Jul 04, 2009 | Compaq (128293B21) (128293-b21) SCSI...
Raid 1
there must be some key on the startup to enter into the raid menu. And in that raid menu you can create raid .
Jun 23, 2009 | IBM x3400 Server
IBM Blue Screen
I had the same problem with an Intellistation 6868 for years. It just wouldn't load XP but ran fine on Windows 2000 SP4. I tried 3 different XP Installation CD's with no luck. After several attempts at installing XP I bought a clean XP Upgrade from ebay.
It took me 3 goes to install it but eventually I got it in there. If you can get XP to start on the 6868 press F8 and start it in safe mode first then when it's booted fully, shut it down and and then start it clean again. It worked for me. I've been running it for 5 months now and it's fine.
I couldn't get it to work at all on the 6868's onboard IDE so I installed a PCI Raid Card and it boots fine on that.
System:
IBM 6868 52A M-Pro Intellistation
2 x Intel P3 866 CPU's 256 mb cache
2 GB ECC RD Ram
2 x Seagate 320 GB 8MB Cache HDD on a Sunix ATA133 PCI Raid Card
2 x Seagate 10000 rpm SCSI HDD on Adaptec Raid Card
ATI 9520 AGP 128mb Graphics
Win2000 Professional SP4 - Upgraded to XP Professional Edition SP3
Dual Boots with Xandros Linux Desktop Destop 3.01C
Sep 08, 2008 | IBM IntelliStation M Pro 6868 PC Desktop
SCSI BIOS not installed / ML150G2, exchanged mainboard, RAID
hi..
my guess is no but since i haven't dealt with this type of server i'm going to suggest you go to hp.
if you just goto hp.com and search on live chat and a link will come up.. they should be able to help unless it's too old since i'm not sure what generation we are on now..
good luck, hope this helps a little..d
Feb 23, 2008 | Adaptec (2120S) SCSI Controller
SuperMicro COMPUTER   EATX MBD X7DBE 5000P DCXEON FBD DDR2 SATA2 VGA (X7DBE+O) Motherboard Logo
105 people viewed this question
Top SuperMicro Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Tony
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
