Question about Sony Televison & Video
I have a 10 year old sony trinitron tv,modelkv35v36,and the picture blacked out but audio is fine
  • Sony Master
  • 5,568 Answers
There are several parts that could be at fault and most are in the high voltage power supply. If the flyback has failed it may not be available any more. This isn't a DIY repair, it requires a little test equipment and knowledge.
If you have a TV repair shop (those who understand these are all in our 'golden years') you might ask the cost of a diagnosis.
I would recommend repairing it even if you decide to buy a new one and putting it, along with a DTV converter in a nice dry place so you can drag it back out when your lousy flat-panel set dies. These are not lasting 10 years at all -
Posted on Jun 17, 2009
Tv blinks a black screen off and on, and also getting a green line at top and bottom at times any suggestions? 10 years old
I have same problem, over 10 years old, only started when turned on, but does it @ anytime now . any solutions ? and this thing does weigh a ton. never had a problem ever, great tv, great picture, etc., anytime a function is initiated screen blinks on off at will, stays on for the most part, no other problem, but can this be repaired or is it time to buy a new tv ?
Oct 17, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hi...I'm thinking about buying a 2 year old Sony KV32Fs-120, is this a good tv and are there maintenance costs involved in having a tv like this? Thanks, Nancy.
The Sony TV'S are one of the best sets you can by on the market, the Trinitron picture is world famous when it comes to picture and quality. Since it is two years old makes it a good buy, maintenance costs are low compared to most televisions.
Jan 09, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a 5 year old KLH DVD player. I had it hooked up through AV cable to a 6 year old SONY Trinitron 37" TV & it worked fine. I am now trying to hook it up to a new Westinghouse flat screen TV...
double check the wires are in the correct connections on both the tv and dvd player also the KHL dvd player may need to be put in progressive scan. Usually the red wire for video and the one for audio get plugged into the wrong input and causes this issue
Dec 10, 2010 | Televison & Video
My Sony trinitron tube Tv 36" seems to be going (its 10 years old
no ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Apr 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony wega trinitron(1999) KV-36FV15 Moved tv now audio no video
Seven blinks, pause, seven blinks, etc. means "Horizontal deflection stopped" and indicates a serious problem, probably on the D or DZ board (whichever is applicable).
If this is the case, the TV will have to be serviced by a professional.
I hope this helps :)
Best Regards,
James
Jul 29, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony trinitron is 14 years old. has no picture, sound is fine
In this situation many possibilities could be there like:but one thing is sure that the area of problem is "Vertical Section"
1-PF could be short/open
2- Collector volts are not present due to open/short
3- Capacitor could be popped.
If you are tech person then check the Vertical Section and you will find the caused component.
And if you are not an expert then i suggest you to contact any expert because fault finding is a bit difficult and can only perform by an expert.
Thanks for using fixya.
Jul 26, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
No sound/no picture
Never realised you needed Audio Cables w/ the HDMI
Jan 06, 2009 | Sony HDMI Single Disc DVD Player
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony TV Repair
crt going bad it is a common problem on sony old sets
Aug 06, 2008 | Televison & Video
Sony tv snow for first 5 minutes on
Probably dry solder joints in the tuner section.
When the set warms up, the faulty joint/s make contact, then lose contact again when it cools down.
Jan 20, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
96 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
