Question about Mustang Rzt 50" Zero Turn Riding Lawn Mower
Countax 4.1 whole upper body leaning to the right
The body is leaning to the right this has nothing to do with the cutting blades I repeat the body of the tractor is lob sided
  • Mustang Master
  • 2,478 Answers
First thing, check your tires pressures
Posted on Apr 13, 2014
  • Vanessa Barnes Apr 14, 2014
    Thank you Dennis you are absolutly right this was indeed the problem
Countax k15 need to tension the cutting blade belt how do i do this
there should tension pulley on the deck if its tight replace streached belt with new one that is what is w2rong not unless your pulley tesnioner spring broke the n replace that
Sep 03, 2014 | Garden
Engine runs but blades dont move
John:
My bet is that the drive gears are stripped. Lay the machine on it's back and see the 4 screws that hold the sole plate on to the body of the machine, (The sole plate is also the bottom cutting frame that the blade slides against). Remove the 4 screws (be careful... there will be a small circular bushing under the sole plate and it likes to jump out, fall off of the table, and run under the nearest immovable object!) Remove the sole plate and blade and upper cutting frame as a unit. You can now see the gears that drive the blade, and one (or both) of the gears will be stripped of it's teeth. Go to the manufacturer's website and you might be able to buy new gears.
Nov 30, 2013 | Ryobi 18V Hedge Trimmer
Countax c400h noisy when engage deck
In all likely hood, you have a bad bearing on one of the blade spindles. A very common problem and a easy repair. You don't have to replace the whole unit. You can just take them apart and put in new bearings ( upper and lower ). The bearings have numbers on them nand you can get them at any bearing store.
Jul 05, 2013 | Garden
How to replace the upper cutter on the baby lock? which screws to release the old blade?
I also have a babylock eclipse BLE1DX serger & here's how my book says to do it
to replace the upper cutting blade
1.open the front panel
2.remove the screw holding the upper blade
remove the upper blade
3.position the new blade in the blade slot, replace the screw.as you tighten the screw, hold the blade up in it's highest position
4.close blade cover. close front cover
hope this helps you
good luck
Sep 12, 2011 | Baby Lock Eclipse Serger
My countax C300H starts OK but when I engage the cutters it immediately cuts out. If I let the engine run for 10 minutes then engage the cutters they usually work ok but this is pretty annoying. Is there...
Just got one of these mowers myself - accidentally got a large stone caught in the blades which caused the same problem. It looked to me that there's a sensor on the flywheel that cuts the motor if the blades aren't rotating freely. You might find either that the sensor is broken (check it by pulling off the connectors and connecting them together) or that the blades aren't rotating for some reason.
Mar 26, 2011 | Honda Garden
Diagram showing assembly of 4 parts of cutting head
I solved the problem finally. I discovered that the plate which has the 2 large threaded holes which carry the fixed cutter, had to be locked in behind 2 spring fixing points (on the body of the clippers) before inserting the tongue into the body of the shaver. When I first removed the plate I used a screwdriver blade to spring the tongue away from the body and the whole caboodle (4 pieces) fell out on the bench, so I didn't see how it was assembled. Thanks for your interest anyway.
Jan 08, 2010 | Kitchen Appliances - Others
I want to know which knob I use to make the stitching narrower
there are generally two variable controls .. one adjusts the stitch length (distance between stitches measured in stitches per inch) ... the second is stitch width .. that adjusts how far the zigzag moves left and right .. thats usually just a number from 0 to 10 or so .. 10 would be maximum width .. 0 would be used for straight stitch ..
so you need to adjust the stitch width control to make the stitching narrower .. the controls are called different things on different brand sewing machines .. if you have the brand and model number then there may be instruction booklets available ...
Jan 04, 2010 | Sewing Machines
Blades not cutting checked all belts they are ok but not driving blades countax c300h tractor
Either the belts are worn making them too loose, or you may have a spindle issue there. Check the spindles to make sure they aren't seized. Also, check the blade center nuts to make sure they are tight. Good luck.
Oct 04, 2009 | Garden
Cub cadet not cutting correctly on right side
Try sharpening the blade.Or the blade may be twisted.
Aug 02, 2009 | Garden
I have a Countax K14 ride on mower the cutter deck
Hello ianh_2007:
Usually this Problem is Caused by a Blown Fuse or a Bad PTO Ground.
1-The Following is a Basic File I Made for Checking the PTO (Blade Engagement).
>>The Most Common Cause for this Problem is the PTO Ground. >>A Quick Ground Check is to Use Another Wire and Ground the PTO at the Harness Connection Nearest the PTO.
>>Be Careful and Do Not Ground the HOT Wire. Use a Multimeter and Locate the Ground Wire.
>>Clean the PTO Ground and All the Connections for the PTO Wiring Harness.
>>If you have an Ohmmeter, Disconnect the Wiring Harness from the Front of the Clutch and Check the Resistance of the Clutch. You should have around 4 or 5 OHMs. If at or near Zero, the Coil has Shorted.
2- >>The Following is a Basic File I made for Setting the PTO Clearance. Any Input is Appreciated. **Some of the Newer PTOs cannot be Adjusted.
>>If you can Get a Blade Style Feeler Gauge between the PTO Magnet and Clutch, then Set the Clearance at .015in. The Newer PTOs have the Same Set Up as the Older PTOs, except there is No Adjustments.
>>I Suggest also that you Rig a 12 Volt Light for Testing the Current Flow to the PTO while Operating the Mower. If the Light Blinks During Operation, then you have a Bad Connection somewhere to the PTO Clutch.
>>If the Light Stays Steady and the PTO Still Kicks in and Out, then it is the Adjustment.
>>You can Also Try Turning the Spring Loaded Adjuster Nuts 1/4 Turn and Operate the Mower. Do Not Adjust Over 1/2 Turn.
>>If you have Adjusted to 1/2 Turn and the Problem is Still Present and you Know the Voltage to the PTO is Steady, then Replace the PTO.**
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 12, 2009 | Garden
Mustang Rzt 50" Zero Turn Riding Lawn Mower Logo
67 people viewed this question
Top Mustang Garden Experts
Dennis Key
Dennis Key
Randy Schumann
Randy Schumann
Paul Sikkema
Paul Sikkema
Are you a Mustang Garden Expert? Answer questions, earn points and help others
