I have manually opened and shut the roof with the key, but the roof unsecure light stays on even though its been locked.
SOURCE: Auto roof stuck
You can try to close it manually using that key, then taking the fuse out, checking to make sure it is okay, then putting it back in. It may solve the problem.
SOURCE: Roof stuck half open.
There's a hidden side pannel that you pry open. It's located on the drivers side of the side-dash. Basically open the drivers side door and try to pry open the side of the dash console. It's right inside there with all the fuses and things.
Go sit in your truck and close all the doors. Light stays on right? Put your key in the ignition. Does the chime start going off when you put the key in? If so, door switch or the GEM thinks a door is open.
To find out which door... Leave the key in the ingntion. Turn to the on position. Even with doors closed, chime sounds once after a few seconds and door ajar light comes on and stays on right? Open each door one by one. The chime should sound each time you open a door. When you find the door that doesn't make the chime sound when you open it, that is the problem. (Don't forget to try the rear hatch and the hatch glass also!) To determine if the switch is bad or if the GEM is having a problem thinking the door is open, just unplug the suspected switch, close all the doors, and see if the problem stops. (don't forget to wait a second to give the lights time to go off) If unplugging the switch solves it, the replace it. If it doesn't, Ford can check your GEM to see if it is the problem.
I hope this helps
